Here is additional info.
$ pa-info
________________
> pulseaudio_ps_do
tanig956 0.0 0.3 1358908 14436 ? S<sl 07:13 0:00 /usr/bin/pulseaudio --daemonize=no --log-target=journal
tanig991 0.2 1.3 733568 51784 ?Sl 07:13 0:05 /usr/lib/xfce4/panel/wrapper-2.0 /usr/lib/xfce4/panel/plugins/libpulseaudio-plugin.so 9 16777233 pulseaudio PulseAudio Plugin Adjust the audio volume of the PulseAudio sound system
tanig 2900 0.0 0.0 3168 872 pts/0S+ 07:56 0:00 grep pulseaudio
________________
> which pulseaudio
/usr/bin/pulseaudio
________________
> pidof pulseaudio
956
________________
> pulseaudio --version
pulseaudio 14.2
________________
> pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 34
Server Protocol Version: 34
Is Local: yes
Client Index: 12
Tile Size: 65472
User Name: tanig
Host Name: A215S4697
Server Name: pulseaudio
Server Version: 14.2
Default Sample Specification: s16le 2ch 44100Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_00_14.2.analog-stereo
Default Source: alsa_output.pci-0000_00_14.2.analog-stereo.monitor
Cookie: 445d:7a42
________________
> pactl list
Module #0
Argument:
Usage counter: n/a
Properties:
module.author = "Lennart Poettering"
module.description = "Automatically restore the volume/mute state of devices"
module.version = "14.2"
Module #1
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore the volume/mute/device state of streams"
Module #2
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore profile of cards"
Module #3
Argument:
Usage counter: n/a
Properties:
module.description = "Augment the property sets of streams with additional static information"
Module #4
Argument:
Usage counter: n/a
Properties:
module.author = "David Henningsson"
module.description = "Switches ports and profiles when devices are plugged/unplugged"
Module #5
Argument:
Usage counter: n/a
Properties:
module.description = "Detect available audio hardware and load matching drivers"
Module #6
Argument: device_id="0" name="pci-0000_00_14.2" card_name="alsa_card.pci-0000_00_14.2" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
Usage counter: 0
Properties:
module.description = "ALSA Card"
Module #7
Argument: channels=2
Usage counter: n/a
Properties:
module.description = "Adds JACK sink/source ports when JACK is started"
Module #8
Argument:
Usage counter: n/a
Properties:
module.author = "Frédéric Dalleau, Pali Rohár"
module.description = "Policy module to make using bluetooth devices out-of-the-box easier"
Module #9
Argument:
Usage counter: n/a
Properties:
module.author = "João Paulo Rechi Vita"
module.description = "Detect available Bluetooth daemon and load the corresponding discovery module"
Module #10
Argument:
Usage counter: n/a
Properties:
module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers"
Module #11
Argument:
Usage counter: n/a
Properties:
module.author = "Tanu Kaskinen"
module.description = "D-Bus interface"
Module #12
Argument:
Usage counter: n/a
Properties:
module.description = "Native protocol (UNIX sockets)"
Module #13
Argument:
Usage counter: n/a
Properties:
module.author = "Sylvain Baubeau"
module.description = "GSettings Adapter"
Module #14
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore the default sink and source"
Module #15
Argument:
Usage counter: n/a
Properties:
module.author = "Colin Guthrie"
module.description = "Always keeps at least one sink loaded even if it's a null one"
Module #16
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically set device of streams based on intended roles of devices"
Module #17
Argument:
Usage counter: n/a
Properties:
module.description = "When a sink/source is idle for too long, suspend it"
Module #18
Argument:
Usage counter: n/a
Properties:
module.description = "Create a client for each ConsoleKit session of this user"
Module #19
Argument:
Usage counter: n/a
Properties:
module.description = "Create a client for each login session of this user"
Module #20
Argument:
Usage counter: n/a
Properties:
module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
Module #21
Argument:
Usage counter: n/a
Properties:
module.description = "Mute & cork streams with certain roles while others exist"
Module #22
Argument:
Usage counter: n/a
Properties:
module.description = "Detect when various filters are desirable"
Module #23
Argument:
Usage counter: n/a
Properties:
module.description = "Load filter sinks automatically when needed"
Module #24
Argument: display=:0.0 xauthority=/home/tanig/.Xauthority
Usage counter: n/a
Properties:
module.description = "X11 credential publisher"
Module #25
Argument: display=:0.0 xauthority=/home/tanig/.Xauthority session_manager=local/A215S4697:@/tmp/.ICE-unix/863,unix/A215S4697:/tmp/.ICE-unix/863
Usage counter: n/a
Properties:
module.description = "X11 session management"
Module #28
Argument:
Usage counter: n/a
Properties:
module.description = "Command line interface protocol (UNIX sockets)"
Sink #0
State: SUSPENDED
Description: Built-in Audio Analog Stereo
Driver: module-alsa-card.c
Owner Module: 6
Mute: no
Volume: front-left: 54394 / 83% / -4.86 dB, front-right: 54394 / 83% / -4.86 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.pci-0000_00_14.2.analog-stereo.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC268 Analog"
alsa.id = "ALC268 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "0"
alsa.card_name = "HDA ATI SB"
alsa.long_card_name = "HDA ATI SB at 0xf8700000 irq 16"
device.bus_path = "pci-0000:00:14.2"
sysfs.path = "/devices/pci0000:00/0000:00:14.2/sound/card0"
device.bus = "pci"
device.vendor.id = "1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
device.product.id = "4383"
device.product.name = "SBx00 Azalia (Intel HDA)"
device.string = "front:0"
device.buffering.buffer_size = "352768"
device.buffering.fragment_size = "176384"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Built-in Audio Analog Stereo"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Ports:
analog-output-speaker: Speakers (type: Speaker, priority: 10000, availability unknown)
analog-output-headphones: Headphones (type: Headphones, priority: 9900, not available)
Active Port: analog-output-speaker
Formats:
pcm
Source #0
State: SUSPENDED
Description: Monitor of Built-in Audio Analog Stereo
Owner Module: 6
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Monitor of Sink: alsa_output.pci-0000_00_14.2.analog-stereo
Flags: DECIBEL_VOLUME LATENCY
Properties:
device.description = "Monitor of Built-in Audio Analog Stereo"
device.class = "monitor"
alsa.card = "0"
device.bus = "pci"
device.string = "0"
Formats:
pcm
Client #0
Driver: module-systemd-login.c
Owner Module: 19
Properties:
application.name = "Login Session 2"
systemd-login.session = "2"
Client #1
Driver: protocol-native.c
Owner Module: 12
Properties:
application.name = "xfwm4"
native-protocol.peer = "UNIX socket client"
native-protocol.version = "34"
window.x11.display = ":0"
window.x11.screen = "0"
application.process.id = "940"
application.process.user = "tanig"
application.process.host = "A215S4697"
application.process.binary = "xfwm4"
application.language = "en_US.utf8"
application.process.machine_id = "580743c2b64f432dbaca33241fa37491"
application.process.session_id = "2"
Client #2
Owner Module: 12
Properties:
application.name = "xfce4-pulseaudio-plugin"
application.version = "0.4.3"
application.id = "org.xfce.pulseaudio-plugin"
application.icon_name = "multimedia-volume-control"
application.process.id = "991"
application.process.binary = "wrapper-2.0"
Client #5
Driver: module-x11-xsmp.c
Owner Module: 25
Properties:
application.name = "XSMP Session on xfce4-session as 212867fc1-0f03-4a97-a9de-48206d3b889b"
xsmp.vendor = "xfce4-session"
xsmp.client.id = "212867fc1-0f03-4a97-a9de-48206d3b889b"
Client #6
Owner Module: 12
Properties:
application.name = "Chrome input"
application.process.id = "1016"
application.process.binary = "pcloud"
window.x11.display = ":0.0"
Client #9
Owner Module: 12
Properties:
application.name = "Firefox"
application.process.id = "1879"
application.process.binary = "firefox"
application.icon_name = "firefox"
Client #13
Owner Module: 12
Properties:
application.name = "pactl"
application.process.id = "2905"
application.process.binary = "pactl"
application.language = "C"
Card #0
Owner Module: 6
Properties:
alsa.card = "0"
device.bus = "pci"
device.string = "0"
device.description = "Built-in Audio"
Profiles:
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: no)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: no)
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
Active Profile: output:analog-stereo
Ports:
analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, not available)
Properties:
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo
analog-output-speaker: Speakers (type: Speaker, priority: 10000, latency offset: 0 usec, availability unknown)
Properties:
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, not available)
Properties:
________________
> cat /etc/pulse/daemon.conf
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify
# it under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
## Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for
## more information. Default values are commented out. Use either ; or # for
## commenting.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
; resample-method = speex-float-1
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; remixing-produce-lfe = no
; remixing-consume-lfe = no
; lfe-crossover-freq = 0
; flat-volumes = no
; rescue-streams = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
; default-sample-format = s16le
; default-sample-rate = 44100
; alternate-sample-rate = 48000
; default-sample-channels = 2
; default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
________________
> cat /etc/pulse/client.conf
## Configuration file for PulseAudio clients. See pulse-client.conf(5) for
## commenting.
; default-sink =
; default-source =
; default-server =
; default-dbus-server =
autospawn = no
; autospawn = yes
; daemon-binary = /usr/bin/pulseaudio
; extra-arguments = --log-target=syslog
; cookie-file =
; enable-shm = yes
; auto-connect-localhost = no
; auto-connect-display = no
________________
> cat /etc/pulse/default.pa
#!/usr/bin/pulseaudio -nF
# PulseAudio is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# This startup script is used only if PulseAudio is started per-user
# (i.e. not in system mode)
.fail
### Automatically restore the volume of streams and devices
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
### Automatically augment property information from .desktop files
### stored in /usr/share/application
load-module module-augment-properties
### Should be after module-*-restore but before module-*-detect
load-module module-switch-on-port-available
### Load audio drivers statically
### (it's probably better to not load these drivers manually, but instead
### use module-udev-detect -- see below -- for doing this automatically)
#load-module module-alsa-sink
#load-module module-alsa-source device=hw:1,0
#load-module module-oss device="/dev/dsp" sink_name=output source_name=input
#load-module module-oss-mmap device="/dev/dsp" sink_name=output source_name=input
#load-module module-null-sink
#load-module module-pipe-sink
### Automatically load driver modules depending on the hardware available
.ifexists module-udev-detect.so
load-module module-udev-detect
.else
### Use the static hardware detection module (for systems that lack udev support)
load-module module-detect
.endif
### Automatically connect sink and source if JACK server is present
.ifexists module-jackdbus-detect.so
.nofail
load-module module-jackdbus-detect channels=2
.fail
.endif
### Automatically load driver modules for Bluetooth hardware
.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy
.endif
.ifexists module-bluetooth-discover.so
load-module module-bluetooth-discover
.endif
### Load several protocols
load-module module-dbus-protocol
.ifexists module-esound-protocol-unix.so
load-module module-esound-protocol-unix
.endif
load-module module-native-protocol-unix
### Network access (may be configured with paprefs, so leave this commented
### here if you plan to use paprefs)
#load-module module-esound-protocol-tcp
#load-module module-native-protocol-tcp
#load-module module-zeroconf-publish
### Load the RTP receiver module (also configured via paprefs, see above)
#load-module module-rtp-recv
### Load the RTP sender module (also configured via paprefs, see above)
#load-module module-null-sink sink_name=rtp format=s16be channels=2 rate=44100 sink_properties="device.description='RTP Multicast Sink'"
#load-module module-rtp-send source=rtp.monitor
### Load additional modules from GSettings. This can be configured with the paprefs tool.
### Please keep in mind that the modules configured by paprefs might conflict with manually
### loaded modules.
.ifexists module-gsettings.so
.nofail
load-module module-gsettings
.fail
.endif
### Automatically restore the default sink/source when changed by the user
### during runtime
### NOTE: This should be loaded as early as possible so that subsequent modules
### that look up the default sink/source get the right value
load-module module-default-device-restore
### Make sure we always have a sink around, even if it is a null sink.
load-module module-always-sink
### Honour intended role device property
load-module module-intended-roles
### Automatically suspend sinks/sources that become idle for too long
load-module module-suspend-on-idle
### If autoexit on idle is enabled we want to make sure we only quit
### when no local session needs us anymore.
.ifexists module-console-kit.so
load-module module-console-kit
.endif
.ifexists module-systemd-login.so
load-module module-systemd-login
.endif
### Enable positioned event sounds
load-module module-position-event-sounds
### Cork music/video streams when a phone stream is active
load-module module-role-cork
### Modules to allow autoloading of filters (such as echo cancellation)
### on demand. module-filter-heuristics tries to determine what filters
### make sense, and module-filter-apply does the heavy-lifting of
### loading modules and rerouting streams.
load-module module-filter-heuristics
load-module module-filter-apply
### Make some devices default
#set-default-sink output
#set-default-source input
________________
> cat /etc/pulse/system.pa
# This startup script is used only if PulseAudio is started in system
# mode.
.else
### Use the static hardware detection module (for systems that lack udev/hal support)
.endif
.endif
### during runtime
________________
> ls -alt /dev/snd/*
crw-rw----+ 1 root audio 116, 3 Apr 13 2021 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116, 6 Apr 13 2021 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 5 Apr 13 2021 /dev/snd/hwC0D3
crw-rw----+ 1 root audio 116, 4 Apr 13 2021 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116, 33 Apr 13 2021 /dev/snd/timer
crw-rw----+ 1 root audio 116, 1 Apr 13 2021 /dev/snd/seq
crw-rw----+ 1 root audio 116, 2 Apr 13 07:46 /dev/snd/pcmC0D0p
/dev/snd/by-path:
total 0
lrwxrwxrwx 1 root root 12 Apr 13 2021 pci-0000:00:14.2 -> ../controlC0
drwxr-xr-x 2 root root 60 Apr 13 2021 .
drwxr-xr-x 3 root root 200 Apr 13 2021 ..
________________
> lsof /dev/snd/*
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
pulseaudi 956 tanig 16u CHR 116,6 0t0 382 /dev/snd/controlC0
pulseaudi 956 tanig 23u CHR 116,6 0t0 382 /dev/snd/controlC0
________________
> jacks_do
card=0
numid=14,iface=CARD,name='Front Headphone Jack'
; type=BOOLEAN,access=r-------,values=1
: values=off
numid=13,iface=CARD,name='Mic Jack'
: values=off
numid=15,iface=CARD,name='Speaker Phantom Jack'
: values=on
________________
> aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
sysdefault:CARD=SB
HDA ATI SB, ALC268 Analog
Default Audio Device
front:CARD=SB,DEV=0
Front output / input
surround21:CARD=SB,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=SB,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=SB,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=SB,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=SB,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=SB,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
usbstream:CARD=SB
HDA ATI SB
USB Stream Output
________________
> arecord -L
null
samplerate
speexrate
jack
oss
Open Sound System
pulse
speex
upmix
vdownmix
default
sysdefault:CARD=SB
front:CARD=SB,DEV=0
usbstream:CARD=SB
HDA ATI SB
USB Stream Output
________________
> alsa_info_do
dmesg: read kernel buffer failed: Operation not permitted
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.65
!!Script ran on: Tue Apr 13 14:56:33 UTC 2021
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: TOSHIBA
Product Name: Satellite A215
Product Version: PSAEGU-00V00U
Firmware Version: V2.30
System SKU:012345678912345678912345678
Board Vendor: TOSHIBA
Board Name:IALAA
!!ACPI Device Status Information
/sys/bus/acpi/devices/LNXVIDEO:00/status 15
/sys/bus/acpi/devices/LNXVIDEO:01/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0C01:00/status 15
/sys/bus/acpi/devices/PNP0C0A:00/status 31
/sys/bus/acpi/devices/PNP0C0F:00/status 9
/sys/bus/acpi/devices/PNP0C0F:01/status 9
/sys/bus/acpi/devices/PNP0C0F:02/status 9
/sys/bus/acpi/devices/PNP0C0F:03/status 9
/sys/bus/acpi/devices/PNP0C0F:04/status 9
/sys/bus/acpi/devices/PNP0C0F:05/status 9
/sys/bus/acpi/devices/PNP0C0F:06/status 9
/sys/bus/acpi/devices/PNP0C0F:07/status 9
/sys/bus/acpi/devices/PNP0C32:00/status 15
/sys/bus/acpi/devices/PNP0C32:01/status 15
/sys/bus/acpi/devices/TOS1900:00/status 11
/sys/bus/acpi/devices/device:16/status 15
/sys/bus/acpi/devices/device:1a/status 15
/sys/bus/acpi/devices/device:1d/status 15
/sys/bus/acpi/devices/device:20/status 9
/sys/bus/acpi/devices/device:23/status 11
!!Kernel Information
Kernel release:5.10.26-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.10.26-1-MANJARO
Library version:1.2.4
Utilities version: 1.2.4
!!Loaded ALSA modules
snd_hda_intel
!!Sound Servers on this system
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [SB ]: HDA-Intel - HDA ATI SB
!!PCI Soundcards installed in the system
00:14.2 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 Azalia (Intel HDA) [1002:4383]
Subsystem: Toshiba Corporation Device [1179:ff08]
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 0
power_save_controller : N
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
!!HDA-Intel Codec information
--startcollapse--
Codec: LSI Generic HDMI
Address: 0
MFG Function Id: 0x2 (unsol 1)
Vendor Id: 0x11c11040
Subsystem Id: 0x11790001
Revision Id: 0x100200
Modem Function Group: 0x1
Codec: Realtek ALC268
Address: 3
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0268
Subsystem Id: 0x1179ff0c
Revision Id: 0x100003
No Modem Function Group found
Default PCM:
rates [0x560]: 44100 48000 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3
Power: setting=D0, actual=D0
GPIO: io=4, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[3]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x1d: Stereo Amp-Out
Control: name="Speaker Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Amp-Out caps: ofs=0x40, nsteps=0x40, stepsize=0x03, mute=0
Amp-Out vals: [0x3b 0x3b]
Converter: stream=5, channel=0
PCM:
formats [0x1]: PCM
Node 0x03 [Audio Output] wcaps 0x1d: Stereo Amp-Out
Control: name="Headphone Playback Volume", index=0, device=0
Device: name="ALC268 Analog", type="Audio", device=0
Amp-Out vals: [0x00 0x00]
PCM:
formats [0x1]: PCM
Node 0x04 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x05 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x06 [Audio Output] wcaps 0x211: Stereo Digital
Converter: stream=0, channel=0
Digital:
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
rates [0x5e0]: 44100 48000 88200 96000 192000
bits [0x1e]: 16 20 24 32
formats [0x1]: PCM
Node 0x07 [Audio Input] wcaps 0x100111: Stereo
Converter: stream=1, channel=0
SDI-Select: 0
PCM:
rates [0x160]: 44100 48000 96000
bits [0x6]: 16 20
formats [0x1]: PCM
Connection: 1
0x24
Node 0x08 [Audio Input] wcaps 0x100111: Stereo
SDI-Select: 0
PCM:
bits [0x6]: 16 20
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0a [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0b [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0d [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0e [Audio Mixer] wcaps 0x20010a: Mono Amp-In
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x00 0x00]
Connection: 1
0x02
Node 0x0f [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Control: name="Beep Playback Switch", index=0, device=0
ControlAmp: chs=3, dir=In, idx=1, ofs=0
Amp-In vals: [0x00 0x00] [0x80 0x80]
Connection: 2
0x02 0x1d
Node 0x10 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x00 0x00] [0x80 0x80] [0x80 0x80]
Connection: 3
0x03 0x1d 0x02
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Pin Complex] wcaps 0x400001: Stereo
Pincap 0x00000020: IN
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x13 [Pin Complex] wcaps 0x400001: Stereo
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x14 [Pin Complex] wcaps 0x40018d: Stereo Amp-Out
Control: name="Speaker Playback Switch", index=0, device=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Pincap 0x0001003c: IN OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x99130910: [Fixed] Speaker at Int ATAPI
Conn = ATAPI, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Unsolicited: tag=00, enabled=0
Connection: 1
0x0f
Node 0x15 [Pin Complex] wcaps 0x40018d: Stereo Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
Amp-Out vals: [0x80 0x80]
EAPD 0x2: EAPD
Pin Default 0x02214020: [Jack] HP Out at Ext Front
Conn = 1/8, Color = Green
DefAssociation = 0x2, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP
Unsolicited: tag=01, enabled=1
Connection: 1
0x10
Node 0x16 [Pin Complex] wcaps 0x40010c: Mono Amp-Out
Amp-Out vals: [0x80]
Pincap 0x00000010: OUT
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Connection: 1
0x0e
Node 0x17 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x18 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Control: name="Mic Boost Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Amp-In caps: ofs=0x00, nsteps=0x02, stepsize=0x4f, mute=0
Pincap 0x00003734: IN OUT Detect
Vref caps: HIZ 50 GRD 80 100
Pin Default 0x02a19840: [Jack] Mic at Ext Front
Conn = 1/8, Color = Pink
DefAssociation = 0x4, Sequence = 0x0
Pin-ctls: 0x21: IN VREF_50
Unsolicited: tag=02, enabled=1
Connection: 1
0x02
Node 0x19 [Pin Complex] wcaps 0x40008b: Stereo Amp-In
Pincap 0x00003724: IN Detect
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN VREF_HIZ
Node 0x1a [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Misc = NO_PRESENCE
Connection: 1
0x02
Node 0x1b [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1c [Pin Complex] wcaps 0x400001: Stereo
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x1d [Pin Complex] wcaps 0x400000: Mono
Control: name="Beep Playback Volume", index=0, device=0
Pin Default 0x4016852d: [N/A] Speaker at Ext N/A
Conn = Digital, Color = Purple
DefAssociation = 0x2, Sequence = 0xd
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400380: Mono Digital
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=10
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x23 [Audio Selector] wcaps 0x30010d: Stereo Amp-Out
Amp-Out caps: ofs=0x0b, nsteps=0x1f, stepsize=0x05, mute=1
Amp-Out vals: [0x01 0x01]
Connection: 7
0x18 0x19 0x1a 0x1c 0x14 0x15* 0x12
Node 0x24 [Audio Selector] wcaps 0x30010d: Stereo Amp-Out
Control: name="Capture Volume", index=0, device=0
Control: name="Capture Switch", index=0, device=0
Amp-Out vals: [0x13 0x13]
Connection: 7
0x18* 0x19 0x1a 0x1c 0x14 0x15 0x13
--endcollapse--
!!ALSA Device nodes
/dev/snd/by-path:
total 0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: SB [HDA ATI SB], device 0: ALC268 Analog [ALC268 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card SB
Card hw:0 'SB'/'HDA ATI SB at 0xf8700000 irq 16'
Mixer name : 'LSI Generic HDMI'
Components : 'HDA:11c11040,11790001,00100200 HDA:10ec0268,1179ff0c,00100003'
Controls : 18
Simple ctrls : 8
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 64
Mono: Playback 59 [92%] [-5.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 0 [0%] [-64.00dB] [off]
Front Right: Playback 0 [0%] [-64.00dB] [off]
Simple mixer control 'Speaker',0
Mono:
Front Left: Playback 64 [100%] [0.00dB] [on]
Front Right: Playback 64 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic Boost',0
Capabilities: volume
Limits: 0 - 2
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Beep',0
Limits: Playback 0 - 12
Mono:
Front Left: Playback 0 [0%] [-24.00dB] [off]
Front Right: Playback 0 [0%] [-24.00dB] [off]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 31
Front Left: Capture 19 [61%] [12.00dB] [on]
Front Right: Capture 19 [61%] [12.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
!!Alsactl output
--startcollapse--
state.SB {
control.1 {
iface MIXER
name 'Headphone Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 -6400
dbvalue.1 -6400
control.2 {
iface MIXER
name 'Headphone Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
name 'Speaker Playback Volume'
value.0 64
value.1 64
comment {
access 'read write'
type INTEGER
count 2
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.4 {
iface MIXER
name 'Speaker Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Auto-Mute Mode'
value Enabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.6 {
iface MIXER
name 'Capture Volume'
value.0 19
value.1 19
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -1650
dbmax 3000
dbvalue.0 1200
dbvalue.1 1200
control.7 {
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.8 {
iface MIXER
name 'Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 2'
dbmin 0
dbmax 4000
dbvalue.0 0
dbvalue.1 0
control.9 {
iface MIXER
name 'Beep Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 12'
dbmin -2400
dbmax 0
dbvalue.0 -2400
dbvalue.1 -2400
control.10 {
iface MIXER
name 'Beep Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.11 {
iface MIXER
name 'Master Playback Volume'
value 59
comment {
access 'read write'
type INTEGER
count 1
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 -500
control.12 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.13 {
iface CARD
name 'Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.14 {
iface CARD
name 'Front Headphone Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.15 {
iface CARD
name 'Speaker Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.16 {
iface PCM
name 'Playback Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.17 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.18 {
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
--endcollapse--
!!All Loaded Modules
ac97_bus
agpgart
ata_generic
ath
ath5k
ccm
ccp
cec
cfg80211
cqhci
crc16
crc32c_generic
crc_itu_t
crypto_user
drm
drm_kms_helper
edac_mce_amd
ext4
fb_sys_fops
firewire_core
firewire_ohci
fuse
i2c_algo_bit
i2c_piix4
industrialio
ip6_tables
ip6t_REJECT
ip6t_rt
ip6table_filter
ip_tables
ipt_REJECT
iptable_filter
irqbypass
jbd2
joydev
k8temp
kvm
kvm_amd
ledtrig_audio
libarc4
libcrc32c
libphy
loop
mac80211
mac_hid
mbcache
mdio_devres
mmc_core
mousedev
nf_conntrack
nf_conntrack_broadcast
nf_conntrack_ftp
nf_conntrack_netbios_ns
nf_defrag_ipv4
nf_defrag_ipv6
nf_log_common
nf_log_ipv4
nf_log_ipv6
nf_nat
nf_nat_ftp
nf_reject_ipv4
nf_reject_ipv6
pata_acpi
pata_atiixp
pcmcia
pcmcia_core
pcmcia_rsrc
pcspkr
powernow_k8
psmouse
r8169
radeon
realtek
rfkill
rng_core
sdhci
sdhci_pci
serio_raw
snd
snd_compress
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_pcm_dmaengine
snd_soc_core
snd_timer
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sp5100_tco
sparse_keymap
squashfs
syscopyarea
sysfillrect
sysimgblt
tifm_7xx1
tifm_core
toshiba_acpi
ttm
uinput
usbhid
video
wmi
x_tables
xt_LOG
xt_addrtype
xt_conntrack
xt_hl
xt_limit
xt_tcpudp
yenta_socket
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC0D3/init_pin_configs:
0x12 0x411111f0
0x13 0x411111f0
0x14 0x99130910
0x15 0x02214020
0x16 0x411111f0
0x18 0x02a19840
0x19 0x411111f0
0x1a 0x411111f0
0x1c 0x411111f0
0x1d 0x4016852d
0x1e 0x411111f0
/sys/class/sound/hwC0D3/driver_pin_configs:
/sys/class/sound/hwC0D3/user_pin_configs:
/sys/class/sound/hwC0D3/init_verbs:
/sys/class/sound/hwC0D3/hints:
!!ALSA/HDA dmesg
$ aplay -L
null
samplerate
speexrate
jack
oss
Open Sound System
pulse
speex
upmix
vdownmix
default
sysdefault:CARD=SB
front:CARD=SB,DEV=0
usbstream:CARD=SB
HDA ATI SB
USB Stream Output
$ lsmod | grep "snd"
snd_hda_codec_realtek 147456 1
snd_hda_codec_generic 98304 1 snd_hda_codec_realtek
ledtrig_audio 16384 1 snd_hda_codec_generic
snd_hda_codec_hdmi 73728 1
snd_hda_intel 57344 2
snd_intel_dspcfg 28672 1 snd_hda_intel
soundwire_intel 45056 1 snd_intel_dspcfg
snd_hda_codec 172032 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
snd_hda_core 106496 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
snd_hwdep 16384 1 snd_hda_codec
snd_soc_core 323584 1 soundwire_intel
snd_compress 32768 1 snd_soc_core
ac97_bus 16384 1 snd_soc_core
snd_pcm_dmaengine 16384 1 snd_soc_core
snd_pcm 147456 8 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,soundwire_intel,snd_compress,snd_soc_core,snd_hda_core,snd_pcm_dmaengine
snd_timer 45056 1 snd_pcm
snd 114688 14 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_compress,snd_soc_core,snd_pcm
soundcore 16384 1 snd
$ lspci -v | grep Audio
00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 Azalia (Intel HDA)
$ pulseeffects
r300: driver missing
