Hello, currently trouble shooting performance problems on kernel 5.14. I am getting unstable frame-rates and horrible frame-time lag, the frame-time lag is especially interesting as if I move my mouse around frame-time will spike to around 30+ milliseconds, with no mouse movement frame-time settles but overall FPS is about half of what I have been getting prior to 5.14.
I poked around a bit at tried forcing power profiles to high performance with no change. Reverting to kernel 5.13 restores expected performance. I am fine with staying on 5.13 but I am concerned about how long I can if the root issue is not resolved prior to 5.13’s EOL. My hardware does not work well with the latest 5.10 LTS.
I understand this is an upstream issue but I am also unsure about where to file a bug report / or where most of these conversations are happening.
This issue persists. So as I had feared I am stuck between what I think are broken (for 6900xt?) drivers on 5.14, I can no longer use 5.13 due to EOL, and 5.10 is incompatible with my hardware.
inxi (under 5.13)
~]$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=967fbe57-dccb-4c21-97c3-6538726a1c72 rw
cryptdevice=UUID=27fdcc04-1c50-4f1e-8d76-a7df28ed5ac8:luks-27fdcc04-1c50-4f1e-8d76-a7df28ed5ac8
root=/dev/mapper/luks-27fdcc04-1c50-4f1e-8d76-a7df28ed5ac8 apparmor=1
security=apparmor
resume=/dev/mapper/luks-5abbce8b-5d41-49dd-85ee-585f050a6573
udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: ROG STRIX TRX40-XE GAMING v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 1402 date: 01/15/2021
RAM: total: 125.66 GiB used: 7.85 GiB (6.3%)
Info: 24-Core (3-Die) model: AMD Ryzen Threadripper 3960X bits: 64
type: MT MCP MCM arch: Zen 2 family: 17 (23) model-id: 31 (49) stepping: 0
microcode: 8301039 cache: L2: 12 MiB bogomips: 374544
Speed: 3900 MHz min/max: 2200/3900 MHz boost: disabled Core speeds (MHz):
1: 3900 2: 3900 3: 3900 4: 3900 5: 3900 6: 3900 7: 3900 8: 3900 9: 3900
10: 3900 11: 3900 12: 3900 13: 3900 14: 3900 15: 3900 16: 3900 17: 3900
18: 3900 19: 3900 20: 3900 21: 3900 22: 3900 23: 3900 24: 3900 25: 3900
26: 3900 27: 3900 28: 3900 29: 3900 30: 3900 31: 3900 32: 3900 33: 3900
34: 3900 35: 3900 36: 3900 37: 3900 38: 3900 39: 3899 40: 3900 41: 3900
42: 3900 43: 3900 44: 3900 45: 3900 46: 3900 47: 3900 48: 3900
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: AMD Navi 21 [Radeon RX 6900 XT] vendor: XFX Limited driver: amdgpu
v: kernel bus-ID: 03:00.0 chip-ID: 1002:73af class-ID: 0300
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.7x15.0")
s-diag: 1245mm (49")
Monitor-1: DisplayPort-0 res: 2560x1440 hz: 60
Monitor-2: DisplayPort-1 res: 1920x1080 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: AMD Radeon RX 6900 XT (SIENNA_CICHLID DRM 3.41.0
5.13.19-2-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK driver: N/A
alternate: snd_hda_intel bus-ID: 22:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Sennheiser EPOS GSA 70 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 9-2.2:5 chip-ID: 1395:0300
class-ID: 0300 serial: <filter>
Device-4: ASUSTek USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 9-6:7 chip-ID: 0b05:1917
class-ID: 0300
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: c000 bus-ID: 43:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp67s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: b000 bus-ID: 44:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp68s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 45:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp69s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 7-6:5
Device-1: luks-27fdcc04-1c50-4f1e-8d76-a7df28ed5ac8 maj-min: 254:0
type: LUKS dm: dm-0 size: 1.68 TiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 1.68 TiB
Device-2: luks-5abbce8b-5d41-49dd-85ee-585f050a6573 maj-min: 254:1
type: LUKS dm: dm-1 size: 138.3 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 138.3 GiB
Local Storage: total: 1.82 TiB used: 811.07 GiB (43.5%)
model: WDS200T1X0E-00AFY0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 613000WD temp: 48.9 C scheme: GPT
ID-1: / raw-size: 1.68 TiB size: 1.66 TiB (98.37%) used: 811.07 GiB (47.8%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-27fdcc04-1c50-4f1e-8d76-a7df28ed5ac8 label: N/A
uuid: 967fbe57-dccb-4c21-97c3-6538726a1c72
used: 440 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 9F26-5C4D
ID-1: swap-1 type: partition size: 138.3 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-5abbce8b-5d41-49dd-85ee-585f050a6573 label: N/A
uuid: fc800bb8-e5cb-4537-a792-053289270b01
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-7: 7-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 7-1:2 info: Logitech M105 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Device-2: 7-3:3 info: Corsair K95 RGB Platinum Keyboard [RGP0056]
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1b2d class-ID: 0300
serial: <filter>
Hub-8: 7-5:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 7-5.3:6 info: NZXT USB Device type: HID driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 1e71:2007
Device-2: 7-6:5 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-9: 8-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-10: 9-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-11: 9-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-12: 9-2:3 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 174c:2074 class-ID: 0900
Device-1: 9-2.2:5 info: Sennheiser EPOS GSA 70 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
speed: 12 Mb/s power: 96mA chip-ID: 1395:0300 class-ID: 0300
serial: <filter>
Device-2: 9-4:4 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0b05:1872 class-ID: 0300 serial: <filter>
Device-3: 9-5:6 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Device-4: 9-6:7 info: ASUSTek USB Audio type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 0b05:1917 class-ID: 0300
Hub-13: 10-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-14: 10-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s power: 8mA chip-ID: 174c:3074 class-ID: 0900
System Temperatures: cpu: 50.2 C mobo: 35.0 C gpu: amdgpu temp: 56.0 C
mem: 58.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1155 fan-3: 2319 fan-5: 0 fan-6: 0
fan-7: 1027 gpu: amdgpu fan: 0
Processes: 743 Uptime: 11m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1448 pacman: 1436 lib: 382
flatpak: 6 snap: 6 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.07
