Poor performance issue - gnome gvfsd-dav spawner
Hi, I'm actually using Manjaro GNOME on a SSD but I found the experience really poor.
Like you can see in the video, every action are so long to achieve.
I don't really know how I can solve it. Is it normal for GNOME.
PS: Here is my configuration specs
CPU: AMD Athlon X4 860K
GPU: AMD RX 460
RAM: 8Go DDR3
Do you have experience with other software on this PC? Other linuxes, other environments (KDE, XFCE, ?) Are they all slow?
I mean your CPU is slow in the first place. I am wondering what you could theroretically expect from that HW.
This will provide a lot more detailed information regarding your hardware.
inxi -Fxzc0
  Host: aurnytorainks-pc-family Kernel: 5.1.4-1-MANJARO x86_64 bits: 64
  compiler: gcc v: 8.3.0 Desktop: Gnome 3.32.2 Distro: Manjaro Linux
  Type: Desktop Mobo: ASRock model: A88M-G/3.1 serial: <filter>
  UEFI: American Megatrends v: P1.40 date: 05/05/2016
  Topology: Quad Core model: AMD Athlon X4 860K bits: 64 type: MCP
  arch: Steamroller rev: 1 L2 cache: 2048 KiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 31958
  Speed: 3934 MHz min/max: 1700/4000 MHz Core speeds (MHz): 1: 3734 2: 3938
  3: 3905 4: 3978
  Device-1: AMD Baffin [Radeon RX 460/560D / Pro
  450/455/460/555/555X/560/560X]
  vendor: PC Partner Limited driver: amdgpu v: kernel bus ID: 01:00.0
  Display: x11 server: X.Org 1.20.4 driver: ati,radeon unloaded: modesetting
  resolution: 1920x1080~60Hz
  OpenGL: renderer: AMD Radeon RX 460 Graphics (POLARIS11 DRM 3.30.0
  5.1.4-1-MANJARO LLVM 8.0.0)
  v: 4.5 Mesa 19.0.4 direct render: Yes
  Device-1: AMD FCH Azalia vendor: ASRock driver: snd_hda_intel v: kernel
  bus ID: 00:14.2
  Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
  vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus ID: 01:00.1
  Sound Server: ALSA v: k5.1.4-1-MANJARO
  vendor: ASRock driver: r8168 v: 8.047.01-NAPI port: d000 bus ID: 03:00.0
  Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel port: d000
  bus ID: 05:00.0
  IF: wlp5s0 state: up mac: <filter>
  IF-ID-1: br-0b7e1cda1ee1 state: down mac: <filter>
  IF-ID-2: docker0 state: down mac: <filter>
  Local Storage: total: 1.58 TiB used: 655.00 GiB (40.4%)
  ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS545050A7E680
  ID-2: /dev/sdb vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB
  ID-3: /dev/sdc vendor: Seagate model: ST1000DX001-1NS162 size: 931.51 GiB
  ID-1: / size: 216.60 GiB used: 51.63 GiB (23.8%) fs: ext4 dev: /dev/sdb3
  ID-2: /home size: 915.89 GiB used: 603.33 GiB (65.9%) fs: ext4
  dev: /dev/sdc1
  ID-3: swap-1 size: 2.00 GiB used: 41.8 MiB (2.0%) fs: swap dev: /dev/sdb2
  System Temperatures: cpu: 44.5 C mobo: 33.0 C gpu: amdgpu temp: 39 C
  Fan Speeds (RPM): fan-1: 1246 fan-2: 0 fan-3: 1150 fan-4: 0 fan-5: 2389
  gpu: amdgpu fan: 1159
  Voltages: 12v: N/A 5v: N/A 3.3v: 3.31 vbat: 3.38
  Processes: 252 Uptime: 1h 04m Memory: 7.79 GiB used: 6.90 GiB (88.6%)
  Init: systemd Compilers: gcc: 8.3.0 clang: 8.0.0 Shell: fish v: 3.0.2
  inxi: 3.0.34
can you check ( see memory used )
an another TTY ( Ctrl + Alt + F3 , or Fn )
htop
WTF is that ?
I haven't seen that before
are you using dav or mountpoint with dav or http with webdav?
https://artisan.karma-lab.net/gnome-224-gvfs-et-gio
Euh now I have this new thing who consume all my ram
Actually it's sucking my ressources I can't move my cursor
I believe that's the gnome search engine indexer. You probably want to disable that.
I'm using davs://
Here is the log that I've obtained when listen to music stored on my cloud
Btw, I connect my cloud using the gnome-online-account application in the gnome-settings
aurnyto+  3330  1189  0 11:48 ?        00:00:01 /usr/lib/gvfsd-dav --spawner :1.16 /org/gtk/gvfs/exec_spaw/2
aurnyto+  3615   638  4 11:51 ?        00:00:01 /usr/bin/vlc --started-from-file /run/user/1000/gvfs/dav:host=aurnytoraink.ddns.net,ssl=true,user=Aurnytoraink,prefix=%2Fremote.php%2Fwebdav/Musique/Nekfeu/Les étoiles vagabondes/10 Dans l'univers.flac
Well, I can disable it (if you can explain me how) but what will I miss ?
I don't use gnome. I am a KDE user. I know how to disable the KDE indexer, not the Gnome one.
To learn how to do something the best way to find the information is to use the forums search engine. This was the most likely candidite I found with a quick search. I suggest you avail yourself of the search engine yourself in the future.
