I just switched from KDE to Xfce, and I noticed that certain apps don’t look good on Xfce. Examples: VirtualBox and Okular. I think it is the non-GTK apps. The font is small and a little blurry, and the general appearance is unappealing.
Is there anything to do about it?
See if you have qt5ct
installed, as well as kvantum-qt5
. Use those to select a different theme and/or adjust font sizes for KDE/Qt applications.
Thanks. I have those packages installed. Can you maybe point me to a wiki or tutorial or thread discussing how to configure KDE/Qt applications using those tools?
The Arch Wiki has some tutorials that might help:
Kvantum GUI is available from the main Xfce settings menu, and it’s easy enough to choose a different theme or make various tweaks using the GUI.
