I just wanted to install poetry for python
❯ curl -sSL https://install.python-poetry.org | python -
curl: (77) error setting certificate verify locations: CAfile: /home/user/.cache/yay/anaconda/pkg/anaconda/opt/anaconda/ssl/cacert.pem CApath: none
But for some reason curl started to use a weird anaconda path and i literally don’t know why it does that, but sadly it is not only curl because the corresponding python script also isn’t able to verify the certificates anymore.
I tried reinstalling certificates multiple times. Tried desperately searching with rip grep for the path if it is in some random config file of something.
But nothing worked so far and i am slowly going insane. Because it happens for every single https connection i try to establish over the terminal.
❯ curl -sSL https://install.python-poetry.org --insecure | python -
i can run it like this or create a .curlrc
where i set it to the normal certificates file but then it soon goes to
File "/opt/anaconda/lib/python3.11/urllib/request.py", line 1351, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1002)>
I don’t understand enough about the ssl structure in arch to know what is going on here and why it suddenly tries to access this completely non existent certificate which i never even used in the first place and why would it even be in the yay cache, that makes even less sense.
So yeah if fsomeone has any idea on what i should do or where i should look for this i would be very happy because not being able to use curl or in general https requests in something other than my browser is kind of not good.
EDIT1:
❯ sudo find / -maxdepth 4 -xdev -type f -print0 | sudo xargs -r -0 rg "/home/user/.cache/yay/anaconda/pkg/anaconda/opt/anaconda/ssl/cacert.pem"
/opt/anaconda/lib/libcurl.so.4.8.0: binary file matches (found "\0" byte around offset 7)
I tried this one but this seems kind of weird
