So I set up Systemd Boot with Plymouth on a LUKS parttion. Plymouth doesn’t display anything until LUKS wants the password, it’s like 4 seconds of blank but backlit screen.
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(piix ide_disk reiserfs)
MODULES="crc32c-intel i915"
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=("/usr/bin/btrfs")
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES=""
# HOOKS
# This is the most important setting in this file. The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
## This setup specifies all modules in the MODULES setting above.
## No raid, lvm2, or encrypted root is needed.
# HOOKS=(base)
## This setup will autodetect all modules for your system and should
## work as a sane default
# HOOKS=(base udev autodetect block filesystems)
## This setup will generate a 'full' image which supports most systems.
## No autodetection is done.
# HOOKS=(base udev block filesystems)
## This setup assembles a pata mdadm array with an encrypted root FS.
## Note: See 'mkinitcpio -H mdadm' for more information on raid devices.
# HOOKS=(base udev block mdadm encrypt filesystems)
## This setup loads an lvm2 volume group on a usb device.
# HOOKS=(base udev block lvm2 filesystems)
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr, fsck and shutdown hooks.
HOOKS="base systemd sd-plymouth keyboard keymap sd-vconsole block sd-encrypt autodetect modconf filesystems"
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
#COMPRESSION="zstd"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
here’s my systemdboot
title Manjaro Linux 5.10
linux /vmlinuz-5.10-x86_64
initrd /intel-ucode.img
initrd /initramfs-5.10-x86_64.img
options root=UUID=8e129ee4-9e55-4558-b4ea-33eb08f6b95e rw rootflags=subvol=/@ cryptdevice=UUID=d14ab16d-26ae-4dc1-933c-fa516232997c:cryptrootluks.name=d14ab16d-26ae-4dc1-933c-fa516232997c=cryptroot ro elevator=kyber rootflags=subvol=@ quiet splash apparmor=1 security=apparmor udev.log_priority=3 threadirqs
and
# config file for sdboot-manage
# kernel options to be appended to the "options" line
LINUX_OPTIONS="luks.name=d14ab16d-26ae-4dc1-933c-fa516232997c=cryptroot ro elevator=kyber rootflags=subvol=@ quiet splash apparmor=1 security=apparmor udev.log_priority=3 threadirqs"
LINUX_FALLBACK_OPTIONS="luks.name=d14ab16d-26ae-4dc1-933c-fa516232997c ro rootflags=subvol=@"
# when LINUX_USE_DEVICE_FOR_RESUME is set to "yes", the specified device will be used for hibernation
#LINUX_USE_DEVICE_FOR_RESUME=/dev/sda4
#LINUX_USE_DEVICE_FOR_RESUME=UUID=device_uuid
# when LINUX_USE_SWAP_FOR_RESUME is set to "yes", the first detected available swap device will be used for hibernation
# i.e. the "resume=UUID=swap_device" parameter would be appended to the kernel command line
#LINUX_USE_SWAP_FOR_RESUME="no"
# the DEFAULT_ENTRY option determines if and how the default entry in loader.conf should be managed
# "latest" The most recent Manjaro kernel will be used(the one with the highest version number)
# "oldest" The oldest Manjaro kernel will be used(the one with the lowest version number)
# "manual" Don't modify the default setting
#DEFAULT_ENTRY="latest"
# ENTRY_ROOT is a template that describes the beginning of the name for system-boot entries
# The ENTRY_ROOT will be followed by the kernel version number
# For example, if ENTRY_ROOT="manjaro" and you are using kernel 4.19 your entry will be named "manjaro4.19.conf"
#ENTRY_ROOT="manjarolinux"
# ENTRY_TITLE is a template that describes the beginning of the title of (i.e. the text displayed in the loader screen for) systemd-boot entries
# For example, if ENTRY_TITLE="Manjaro" and you are using kernel 4.19, the title of your entry will be "Manjaro Linux 4.19"
#ENTRY_TITLE="Manjaro Linux"
# when ENTRY_APPEND_KVER is set to "yes", the kernel version number will be appended to both the filename and the title of systemd-boot entries
#ENTRY_APPEND_KVER="yes"
# Use this pattern to match kernels which should be considered native OS kernels
#KERNEL_PATTERN="vmlinuz-[0-9]*-*" \
# setting REMOVE_EXISTING to "yes" will remove all your existing systemd-boot entries before building new entries
#REMOVE_EXISTING="yes"
# unless OVERWRITE_EXISTING is set to "yes" existing entries for currently installed kernels will not be touched
# this setting has no meaning if REMOVE_EXISTING is set to "yes"
#OVERWRITE_EXISTING="no"
# when REMOVE_OBSOLETE is set to "yes" entries for kernels no longer available on the system will be removed
#REMOVE_OBSOLETE="yes"
# if PRESERVE_FOREIGN is set to "yes", do not delete entries starting with $ENTRY_ROOT
#PRESERVE_FOREIGN="no"
# setting NO_AUTOUPDATE to "yes" will stop the updates to systemd-boot when systemd is updated - not recommended unless you are seperately updating systemd-boot
#NO_AUTOUPDATE="no"
# setting NO_AUTOGEN to "yes" will stop the automatic creation of entries when kernels are installed or updated
#NO_AUTOGEN="no"
# add discard option to cryptdevice parameters
#DISCARD="no"
# add discard option to boot parameters for filesystems (rootflags=discard) for continuous TRIM
# see: https://wiki.archlinux.org/index.php/Solid_state_drive#Continuous_TRIM
#CDISCARD="no"
What can I do to get Plymouth showing at the beginning instead of a blank screen?
