system gets stuck before splash screen after a clean reinstall of KDE 5.27.4, kernel 6.1.29-1
Cannot load any terminals or restart the display. ctrl+alt+delete works, what restarts the system. then loads system without any errors
May 21 19:45:53 user sddm[556]: Could not start Display server on vt 1
May 21 19:45:53 user sddm[556]: Attempt 3 starting the Display server on vt 1 failed
May 21 19:45:53 user sddm[556]: Display server stopping...
May 21 19:45:53 user sddm[556]: Failed to read display number from pipe
May 21 19:45:53 user sddm[556]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{<UUID>} -noreset -displayfd 17
May 21 19:45:53 user sddm[556]: Adding cookie to "/var/run/sddm/{<UUID>}"
May 21 19:45:53 user sddm[556]: Display server starting...
May 21 19:45:51 user sddm[556]: Attempt 2 starting the Display server on vt 1 failed
May 21 19:45:51 user sddm[556]: Display server stopping...
May 21 19:45:51 user sddm[556]: Failed to read display number from pipe
May 21 19:45:51 user sddm[556]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{<UUID>} -noreset -displayfd 17
May 21 19:45:51 user sddm[556]: Adding cookie to "/var/run/sddm/{<UUID>}"
May 21 19:45:51 user sddm[556]: Display server starting...
May 21 19:45:49 user sddm[556]: Attempt 1 starting the Display server on vt 1 failed
May 21 19:45:49 user sddm[556]: Display server stopping...
May 21 19:45:49 user sddm[556]: Failed to read display number from pipe
May 21 19:45:48 user sddm[556]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{<UUID>} -noreset -displayfd 17
May 21 19:45:48 user sddm[556]: Adding cookie to "/var/run/sddm/{<UUID>}"
May 21 19:45:48 user sddm[556]: Display server starting...
May 21 19:45:48 user sddm[556]: Loading theme configuration from ""
May 21 19:45:48 user sddm[556]: Adding new display on vt 1 ...
May 21 19:45:48 user sddm[556]: Logind interface found
May 21 19:45:48 user sddm[556]: Starting...
May 21 19:45:48 user sddm[556]: Initializing...
May 21 19:45:48 user systemd[1]: Started Simple Desktop Display Manager.
May 21 19:45:48 user systemd[1]: Failed to start Terminate Plymouth Boot Screen.
May 21 19:45:48 user systemd[1]: plymouth-quit.service: Failed with result 'timeout'.
May 21 19:45:48 user systemd[1]: plymouth-quit.service: start operation timed out. Terminating.
