Since plex-media-player is deprecated I switched to plex-desktop (1.58.1-1) and so far the main difference is that plex-desktop does not work.
Cannot load libcuda.so.1
[44496:44547:1213/125839.719414:ERROR:simple_index_file_posix.cc(61)] Could not get file info for /home/thijs/.cache/Plex/QtWebEngine/Default/Cache/44d9ac0242a6e_0
[44496:44547:1213/125839.720227:ERROR:simple_index_file_posix.cc(61)] Could not get file info for /home/thijs/.cache/Plex/QtWebEngine/Default/Cache/376abfeb577d8_0
[44496:44565:1213/125840.247610:ERROR:ssl_client_socket_impl.cc(960)] handshake failed; returned -1, SSL error code 1, net_error -202
[44496:44565:1213/125840.247652:ERROR:ssl_client_socket_impl.cc(960)] handshake failed; returned -1, SSL error code 1, net_error -202
I have no NVIDIA GPU so I don’t know why the library is needed. Maybe the plex-desktop is NVIDIA only for some reason?
I have unchecked Use Hardware Decoding and this does not fix the problem.
These are the server side log lines taken from Console in the Plex web interface, filtered on Info, Warning and Error, these lines are logged when I use and crash my client.
Dec 13, 2022 19:31:07.341 [0xffff77b84aa0] Info — [Req#1398] AutoUpdate: no updates available
Dec 13, 2022 19:31:07.900 [0xffff77b84aa0] Warning — [Req#145c] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Dec 13, 2022 19:31:07.900 [0xffff77b84aa0] Warning — [Req#145c] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Dec 13, 2022 19:31:08.017 [0xffff7757baa0] Warning — [Req#14b0] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Dec 13, 2022 19:31:08.017 [0xffff7757baa0] Warning — [Req#14b0] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Dec 13, 2022 19:31:08.133 [0xffff77b84aa0] Warning — [Req#14c4] QueryParser: Invalid field 'sectionID' found, ignoring.
Dec 13, 2022 19:31:08.133 [0xffff77b84aa0] Warning — [Req#14c4] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Dec 13, 2022 19:31:08.133 [0xffff77b84aa0] Warning — [Req#14c4] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Dec 13, 2022 19:31:08.136 [0xffff79715aa0] Warning — [Req#14ab] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Dec 13, 2022 19:31:08.137 [0xffff79715aa0] Warning — [Req#14ab] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Dec 13, 2022 19:31:08.329 [0xffff78cacaa0] Warning — [Req#14db] QueryParser: Invalid field 'sectionID' found, ignoring.
Dec 13, 2022 19:31:08.330 [0xffff78cacaa0] Warning — [Req#14db] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Dec 13, 2022 19:31:08.330 [0xffff78cacaa0] Warning — [Req#14db] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Dec 13, 2022 19:31:08.341 [0xffff7757baa0] Warning — [Req#1417] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Dec 13, 2022 19:31:08.341 [0xffff7757baa0] Warning — [Req#1417] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Dec 13, 2022 19:31:08.443 [0xffff77b84aa0] Warning — [Req#14c4] SLOW QUERY: It took 410.000000 ms to retrieve 50 items.
Dec 13, 2022 19:31:08.629 [0xffff78cacaa0] Warning — [Req#14db] SLOW QUERY: It took 330.000000 ms to retrieve 50 items.
Dec 13, 2022 19:31:09.171 [0xffff78cacaa0] Warning — [Req#1721] QueryParser: Invalid field 'sectionID' found, ignoring.
Dec 13, 2022 19:31:09.172 [0xffff78cacaa0] Warning — [Req#1721] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Dec 13, 2022 19:31:09.172 [0xffff78cacaa0] Warning — [Req#1721] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
