Thank ou guys again. I have installed all of your suggested addons and am waiting to see the performance tomorrow.
Would you also mind if I ask what do you think about these specs? …There is a student discount for this specific model at the local store and I am considering to buy it.
Display size 43.9 cm (17.3")
Resolution 1920 x 1080 pixels (Full HD)
Display type anti-glare display
Luminance 250 Nits
HDTV Full HD (1080p)
Processor
Intel® Core™ i5 (10th generation)
10210U Processor
Clock frequency 4x 1.60 GHz
TurboBoost up to 4.20 GHz
Cache 6 MB
Comet Lake
Technology Intel® Hyper-Threading Technology
Graphic
Manufacturer Intel®
Graphics card UHD Graphics
Working memory
Size 8 GB DDR4 1 of 1
max. expansion to 12 GB
OnBoard (firmly soldered) 4 GB
Hard disk
Format M.2
Type SSD
Quantity 1
Capacity (SSD) 256 GB
Connection type (SSD) PCI Express 3.0 (x2)
Expansion slot 2.5" SATA3
Drive
without drive
Interfaces
HDMI Yes
USB 2.0 2x
USB 3.1 (Type-A) 1x Type-A Gen 1
USB 3.1 (Type-C) 1x Type-C Gen 1
Card Reader microSD
Communication
Bluetooth 4.2
Wireless Lan (WLAN) Wireless LAN 802.11 a/b/g/n/ac
Already fully networked? Here you will find everything for High-Speed-DSL and W-LAN!
Sound
Special features Audio by ICEpower®, Sonic Master
Integrated microphone Yes
Features Combo Audio/Mic jack (3.5mm)
Other features Audio system with two speakers
It’s ofcourse a lot better as what you have now, but if you can spare it i would change the CPU immediately because that has a very low speed and is only quad code (4x)
Don’t let your self be fooled by the “TurboBoost” advertising language which is bullshit
You might even suggest them to replace the SSD for a normal HD and improve the CPU with the cost difference
