Please Help me, my screen was:?!?!?
The 'error' (?)
Please help me, out of nothing the screen looked like this. What can I do to fix this? If I format, this can happen again, what do I do?
I'm using a Core i3, onboard (Yes, I know, a potato).
you resized the bar to take up 3/4 of the screen. im assuming you could right click on it and get into it's settings it's been a little while since i used xfce desktop and even then it was brief. resize the bar and you should be fine.
when you get a splinter do you cut off the hand? :sweat_smile: .
I installed a few hours ago this wonderful Distro, and I'm a newbie in the Linux world. Please, if not bothered could you explain me how to do this with the screen almost all 'cut' screen.
P-please, senpai
To customize the panel(s), you just have to right click on the panel and select “Panel -> Panel Preferences”.
Managing Panels:
