Hi, having an issue where when I unplug a headphone jack (or plug one in, for that matter), the device port (in the KDE Plasma “Audio Volume” menu) doesn’t automatically change to the integrated speakers on my laptop. Instead, I have to go to the port and change from “headphones” to “speaker” manually. Since “auto-mute” is enabled in alsamixer
, no sound plays until I switch the port to the correct one. I believe I’m having the same issue as this topic but I’m running pulse audio version 15.0.
Here’s a picture of the menu I’m talking about:
Any help much appreciated!
Here’s my inxi
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=5cd0efe7-0bc3-40fe-9334-0cb2d5228078 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Convertible System: LENOVO product: 81C4 v: Lenovo YOGA C930-13IKB
serial: <filter> Chassis: type: 31 v: Lenovo YOGA C930-13IKB
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter>
UEFI: LENOVO v: 8GCN37WW date: 11/23/2020
ID-1: BAT1 charge: 44.5 Wh (99.1%) condition: 44.9/60.0 Wh (74.9%)
volts: 8.6 min: 7.7 model: Simplo BASE-BAT type: Li-poly serial: <filter>
status: Unknown
RAM: total: 15.38 GiB used: 3.79 GiB (24.6%)
Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: EA cache: L2: 8 MiB bogomips: 32012
Speed: 2388 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 2388 2: 1170
3: 1939 4: 1810 5: 1481 6: 1850 7: 1613 8: 1945
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 3a:00.0 chip-ID: 1002:67df
class-ID: 0300
Device-3: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-1:2
chip-ID: 5986:2115 class-ID: 0e02
Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-6.1.2:7 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
loaded: amdgpu,intel unloaded: modesetting display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2")
s-diag: 1052mm (41.4")
Monitor-1: HDMI-A-0 res: 1920x1080 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
Monitor-2: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.42.0
5.14.10-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_soc_skl
v: kernel alternate: snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0401
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 3a:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.38 running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 6b:00.0
chip-ID: 8086:2526 class-ID: 0280
IF: wlp107s0 state: up mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 4-1.2:4 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp55s0u1u2 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-8:5 chip-ID: 8087:0025 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 462.05 GiB used: 129.44 GiB (28.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB256HAHQ-000L2
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 0L1QEXD7 temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Kingston model: SA400S37240
size: 223.57 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: SBFK scheme: MBR
ID-1: / raw-size: 127.98 GiB size: 125.72 GiB (98.24%)
used: 28.78 GiB (22.9%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 5cd0efe7-0bc3-40fe-9334-0cb2d5228078
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 29.1 MiB (11.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM_DRV uuid: BAA4-116D
ID-3: /run/media/ydeng/Windows-SSD raw-size: 109.25 GiB
size: 109.25 GiB (100.00%) used: 100.64 GiB (92.1%) fs: ntfs
dev: /dev/nvme0n1p3 maj-min: 259:3 label: Windows-SSD uuid: 98A2A485A2A46988
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs label: WINRE_DRV
uuid: CA74A4EB74A4DC07
ID-3: /dev/sda1 maj-min: 8:1 size: 223.57 GiB fs: vfat label: ADDITIONAL
uuid: E0BC-2389
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-1:2 info: Acer Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:2115
class-ID: 0e02
Device-2: 1-5:3 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:0081
class-ID: ff00 serial: <filter>
Hub-2: 1-6:4 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2813 class-ID: 0900
Hub-3: 1-6.1:6 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Device-1: 1-6.1.2:7 info: Logitech Webcam C270 type: Video,Audio
power: 500mA chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Hub-4: 1-6.1.3:8 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-6.1.3.1:10 info: Microdia USB DEVICE type: Keyboard,Mouse
power: 100mA chip-ID: 0c45:8520 class-ID: 0301
Device-2: 1-6.1.4:9 info: SINOWEALTH Game Mouse type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 480mA chip-ID: 258a:1007 class-ID: 0301
Device-3: 1-8:5 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Hub-5: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-6: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-7: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-8: 4-1:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 2109:0813 class-ID: 0900
Hub-9: 4-1.1:3 info: Realtek Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 0bda:0411 class-ID: 0900
Device-1: 4-1.2:4 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 256mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
Device-2: 4-1.3:5 info: VIA Labs VL817 SATA Adaptor type: Mass Storage
driver: uas interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 8mA
chip-ID: 2109:0715 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 52.5 C mobo: 29.8 C gpu: amdgpu temp: 72.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 824
Processes: 315 Uptime: 1h 37m wakeups: 9 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1330
lib: 346 flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8
running-in: yakuake inxi: 3.3.08
