i dont know why i got this problem…i am clueless
Can you add a little more context to your problem? What system you are using? What do you expect to work?
You may try with the kernel parameter nomodeset
to see if not loading video drivers by the kernel and use BIOS modes instead until X is loaded might help you.
I have this same error, so had a little look in to it a few weeks ago when I first installed Manjaro. From what I can tell, MSFT0101 is related to tpm_tis.c (linux/tpm_tis.c at master · torvalds/linux · GitHub) and tpm_crb.c (linux/tpm_crb.c at master · torvalds/linux · GitHub). I believe this is Intel TPM (Trusted Platform Module) driver, so figured it was probably nothing to worry about. As the previous poster mentioned, is there an issue that has manifested that you believe is due to this, or have you just noticed this in your log? I’m just curious, as I had shrugged it off as a non-issue myself - if there is a problem it would be great to know! Thanks.
