Made A Dome error. Now i made the right click on KDE menu with no Botton task bar just a drop down list showing what i can select. No Bottom task bar ate all.
Do you mean that the task manager has been replaced by a window list menu? If so, just right-click the icon and select “Show Alternatives”. Then pick either the classic task manager or the icons-only task manager, depending on which one you want.
Im also trying to get Oracle_VM_VirtualBox_Extension_Pack-6.1.30 , / VBoxGuestAdditions_6.1.30.iso to load and there not letting me do accept file.
