Plasmashell restarting with multiple applications open
Hello everybody,
yesterday and today i had two crashes with the same setup. As such i think it’s a bug and not an anomaly.
The setup consisted of Firefox and Thunderbird open on Virtual Desktop 1, Anki on Desktop 2, Anbox Snap running the App Reaction Flash on Desktop 3, and GIMP on Desktop 4. In the background i had KeepassXC and Nextcloud running. I don’t think i have been running out of Memory, although i can’t say for sure.
The crash looked like this: The Screen freezes and then turns to black. Shortly after that i get thrown back into my normal Desktop 1 but with no programs open, only the ones in Autostart (KeepassXC). No log out and no complete restart of the device.
I would provide my inxi output. Is there anything else like a crash report, and where would i supply it best?
  Kernel: 5.13.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=7e80cf66-70c0-4121-892f-b6b2b6a2f2d7 ro quiet
    cryptdevice=UUID=2f1f276b-9eb0-4569-a04c-ff770d89e352:luks-2f1f276b-9eb0-4569-a04c-ff770d89e352
    root=/dev/mapper/luks-2f1f276b-9eb0-4569-a04c-ff770d89e352 apparmor=1
  Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_wayland
    vt: 2 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: Panasonic product: CF-AX2LDCHCE v: 001
    serial: <superuser required> Chassis: type: 10 v: 001
  Mobo: Panasonic model: CFAX2-1 v: 1 serial: <superuser required>
    UEFI: American Megatrends v: 1.50L15 date: 05/17/2018
  ID-1: BAT1 charge: 21.7 Wh (96.9%) condition: 22.4/29.5 Wh (75.8%)
    volts: 7.4 min: 7.2 model: Panasonic CF-VZSU81 type: Li-ion serial: <filter>
    status: N/A
  ID-2: BAT2 charge: 8.7 Wh (100.0%) condition: 8.7/14.8 Wh (58.9%)
    volts: 7.4 min: 7.2 model: Panasonic 2-653864-B01 type: Li-ion
    serial: <filter> status: N/A
  RAM: total: 3.7 GiB used: 3.14 GiB (84.7%)
  RAM Report:
  Info: model: Intel Core i5-3427U bits: 64 type: MT MCP arch: Ivy Bridge
    family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2271 high: 2535 min/max: 800/2800 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 2229 2: 2535 3: 1935
    4: 2386 bogomips: 18361
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
    erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
    lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
    rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
    x2apic xsave xsaveopt xtopology xtpr
  Type: l1tf
  Type: srbds status: Vulnerable: No microcode
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Matsushita
    driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
  Device-2: Acer USB HD Webcam type: USB driver: uvcvideo bus-ID: 1-1.2:4
    chip-ID: 5986:0297 class-ID: 0e02 serial: <filter>
  Display: wayland server: X.Org 1.21.1.3 compositor: kwin_wayland driver:
    loaded: modesetting alternate: fbdev,vesa display-ID: :1 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
    s-diag: 414mm (16.3")
  Monitor-1: XWAYLAND0 res: 1366x768 hz: 60 dpi: 155
    size: 224x126mm (8.8x5.0") diag: 257mm (10.1")
  Device-1: Intel 7 Series/C216 Family High Definition Audio
    vendor: Matsushita driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1e20 class-ID: 0403
  Sound Server-1: ALSA v: k5.13.11-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.40 running: yes
  Device-1: Intel 82579LM Gigabit Network vendor: Matsushita driver: e1000e
    v: kernel port: f080 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
  IF: enp0s25 state: down mac: <filter>
  Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
    v: kernel bus-ID: 03:00.0 chip-ID: 8086:0082 class-ID: 0280
  IF-ID-1: anbox0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
  IP v4: <filter> scope: global
  IP v6: <filter> scope: link
  IF-ID-2: vethN8FTCS state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-3: wwp0s26u1u1c2i5 state: down mac: <filter>
  Device-1: Alps UGNZH type: USB driver: btusb v: 0.8 bus-ID: 2-1.5:3
    chip-ID: 044e:301d class-ID: e001
  Device-1: luks-2f1f276b-9eb0-4569-a04c-ff770d89e352 maj-min: 254:0
    type: LUKS dm: dm-0 size: 446.83 GiB
  Components:
  p-1: sda2 maj-min: 8:2 size: 446.83 GiB
  Local Storage: total: 447.13 GiB used: 178.47 GiB (39.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SUV500MS480G
    size: 447.13 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 56RR scheme: GPT
  ID-1: / raw-size: 446.83 GiB size: 438.82 GiB (98.21%)
    used: 178.41 GiB (40.7%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-2f1f276b-9eb0-4569-a04c-ff770d89e352 label: N/A
    uuid: 7e80cf66-70c0-4121-892f-b6b2b6a2f2d7
  ID-2: /boot raw-size: 300 MiB size: 299.4 MiB (99.80%)
    used: 64.2 MiB (21.5%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 6B0E-C817
  ID-1: swap-1 type: file size: 8 GiB used: 1005 MiB (12.3%) priority: -2
    file: /swapfile
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
    speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Device-1: 1-1.1:5 info: Sierra Wireless MC8305 Modem
    type: Communication,CDC-Data driver: cdc_mbim interfaces: 2 rev: 2.0
    speed: 480 Mb/s power: 500mA chip-ID: 1199:9011 class-ID: 0a00
  Device-2: 1-1.2:4 info: Acer USB HD Webcam type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 256mA chip-ID: 5986:0297
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Device-1: 2-1.5:3 info: Alps UGNZH type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s chip-ID: 044e:301d class-ID: e001
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-3:2 info: D-WAV Scientific eGalaxTouch EXC7903-02v10
    type: Mouse driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 0eef:7903 class-ID: 0301
  Device-2: 3-4:3 info: ROHM LSI Systems USA LLC HID Sensor Board DFUP2183ZA
    type: HID driver: hid-generic,hid-sensor-hub,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 04b5:0680 class-ID: 0300
    serial: <filter>
  Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 48.6 C mobo: 48.6 C
  Processes: 286 Uptime: 41m wakeups: 1 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: 1628 pacman: 1625 lib: 462 flatpak: 0
  snap: 3 Shell: Zsh v: 5.8 default: Bash v: 5.1.12 running-in: konsole
  inxi: 3.3.11
Thank you everybody in advance.
If all bug report is only this description it’s rather worthless – you should also provide logs from this time, for this see man journalctl. You can paste logs here, we decide if this is bug or something else :wink:
Well, maybe you can’t, but I can. :grinning:
:arrow_down:
… And you’re running all that in Plasma, which is not exactly the lightest of all desktop environments.
Thank you very much for your answers. :smiley:
The reason i thought i haven’t been running out was because i casually checked ram capacity with htop after the first crash, and i stayed within 2-3 GB in RAM and 2-3 GB in Swap according to htop. Also i would suspect some laggines when running out of memory, whcoh doesn’t happen, it’s butter smooth and freezes instantly.
Supplied are the last 3 hours of journalctl. I had 1 or 2 crashes since then.
https://zerobin.net/?46061f8710cd5a6f#ISBIfnX6JeefM51RvFm574kO5t5mkjr37qbY+KhgY28=
Edit:
Okay, i tried to specify it a bit more. I think one crash happend at Dec 26 15:11 as the log says i started Firefox and Anbox at Dec 26 15:12 which fits to my behaviour.
Maybe this information makes it easier.
I’ve edited your topic title as it was…
…asking about your attempted solution rather than your actual problem.
The XY Problem
