Plasmashell completely broken.
kf.plasma.quick: Applet preload policy set to 1
trying to show an empty dialog
file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:146:19: QML Loader: Binding loop detected for property “height”
qt.svg: :406:376: Could not add child element to parent element because the types are incorrect.
qt.svg: :407:130: Could not add child element to parent element because the types are incorrect.
qt.svg: :408:130: Could not add child element to parent element because the types are incorrect.
qt.svg: :408:393: Could not add child element to parent element because the types are incorrect.
qt.svg: :409:130: Could not add child element to parent element because the types are incorrect.
qt.svg: :410:129: Could not add child element to parent element because the types are incorrect.
qt.svg: :411:129: Could not add child element to parent element because the types are incorrect.
qt.svg: :412:129: Could not add child element to parent element because the types are incorrect.
qt.svg: :413:129: Could not add child element to parent element because the types are incorrect.
qt.svg: :413:379: Could not add child element to parent element because the types are incorrect.
qt.svg: :413:631: Could not add child element to parent element because the types are incorrect.
Error: cannot change the containment to AppletsLayout
file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderItemDelegate.qml:323:17: QML Label: Binding loop detected for property “width”
file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:531:9: QML Label: Binding loop detected for property “height”
file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:486:13: QML Label: Binding loop detected for property “height”
file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:30:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property “minimumWidth”
file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:553:5: QML Label: Binding loop detected for property “height”
file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:213: Error: Invalid write to global property “prefix”
Cyclic dependency detected between “file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml” and “file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml”
libkcups: CUPS-Get-Printers last error: 1282 Descrittore di file errato
libkcups: Create-Printer-Subscriptions last error: 1282 Descrittore di file errato
libkcups: Request failed 1282 -1
libkcups: Get-Jobs last error: 1282 Descrittore di file errato
KCrash: Attempting to start /usr/bin/plasmashell
KCrash: crashing… crashRecursionCounter = 2
KCrash: Application Name = plasmashell path = /usr/bin pid = 4267
KCrash: Arguments: /usr/bin/plasmashell
Errore di segmentazione (core dump creato)
At first latte-dock was not starting up. Once i added the default panel… everything got screwed… plasmashell is not starting anymore.
Managed to reinstall plasma, create a new user, etc.
Nothing happened… still same error.
Any help would be much appreciated.
