Plasmashell crashes frequently
but these references are old imho
Rather provide:
journalctl --user --no-pager --priority=warning --grep=wayland
that’s a very long list, any suggestions to shorten it?
Try:
journalctl --user --no-pager --priority=warning --grep=wayland --boot=-1
still a very long list of crashdump
journalctl --user --priority=warning --grep=wayland --boot=-1
Feb 24 23:41:47 the-beast systemd-coredump[2819]: [šŸ”•] Process 2645 (plasmashell) of user 1000 dumped core.
                                                  Stack trace of thread 2768:
                                                  #0  0x00007fc52f6a7a2c n/a (libc.so.6 + 0x98a2c)
                                                  #1  0x00007fc52f64d1a0 raise (libc.so.6 + 0x3e1a0)
                                                  #2  0x00007fc52f6345fe abort (libc.so.6 + 0x255fe)
                                                  #3  0x00007fc52f89a41f _ZSt21__glibcxx_assert_failPKciS0_S0_ (libstdc++.so.6 + 0x9a>
                                                  #4  0x00007fc4d3fdb0c6 n/a (envcan.so + 0x70c6)
                                                  #5  0x00007fc52fdd8f0f n/a (libQt6Core.so.6 + 0x1d8f0f)
                                                  #6  0x00007fc531f8cb13 _ZN4KJob6resultEPS_NS_14QPrivateSignalE (libKF6CoreAddons.so>
                                                  #7  0x00007fc531f91edc n/a (libKF6CoreAddons.so.6 + 0x7cedc)
                                                  #8  0x00007fc52fdd8f0f n/a (libQt6Core.so.6 + 0x1d8f0f)
                                                  #9  0x00007fc52f5b5a26 n/a (libKF6KIOCore.so.6 + 0x11ca26)
                                                  #10 0x00007fc52f5ab945 n/a (libKF6KIOCore.so.6 + 0x112945)
                                                  #11 0x00007fc52f5aea94 n/a (libKF6KIOCore.so.6 + 0x115a94)
                                                  #12 0x00007fc52fdd8f0f n/a (libQt6Core.so.6 + 0x1d8f0f)
                                                  #13 0x00007fc52fdc6474 _ZN7QObject5eventEP6QEvent (libQt6Core.so.6 + 0x1c6474)
                                                  #14 0x00007fc532103380 _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (l>
                                                  #15 0x00007fc52fd6bf48 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (li>
                                                  #16 0x00007fc52fd6c320 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11>
                                                  #17 0x00007fc530051e78 n/a (libQt6Core.so.6 + 0x451e78)
                                                  #18 0x00007fc52e97ff4d n/a (libglib-2.0.so.0 + 0x5ef4d)
                                                  #19 0x00007fc52e981617 n/a (libglib-2.0.so.0 + 0x60617)
                                                  #20 0x00007fc52e981825 g_main_context_iteration (libglib-2.0.so.0 + 0x60825)
                                                  #21 0x00007fc53004fcb2 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLo>
                                                  #22 0x00007fc52fd76cf6 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt>
                                                  #23 0x00007fc52fe9277e _ZN7QThread4execEv (libQt6Core.so.6 + 0x29277e)
                                                  #24 0x00007fc52ff31c7a n/a (libQt6Core.so.6 + 0x331c7a)
                                                  #25 0x00007fc52f6a597a n/a (libc.so.6 + 0x9697a)
                                                  #26 0x00007fc52f7292bc n/a (libc.so.6 + 0x11a2bc)
                                                  Stack trace of thread 2662:
i counted 17 coredumps of plasmashell , only pasted the first one tho
That, unfortunately, doesn’t tell me much…
And…
journalctl --user --unit="*.plasmashell@*.service" --priority=warning --no-pager --boot=-1
Even if it’s long, please provide it all, or upload it to pastebin, or some such.
Failed to add filter for units: No data available
OK, I have officially run out of knowledge. Also regarding this. In short
:man_shrugging:
Sorry
:sob:
no worries, thanks for trying, this is a strange one for sure ..
i am on the system, so it is stable and running , except this one thing lol
It is difficult to try to troubleshoot something, if you don’t want to update to latest packages, or switch the display server for example. Troubleshooting within your imposed parameters is not efficient at all, good luck.
sorry, i can’t copy/paste a 1.7 gig file
One thing I’ll comment on … and it could well be a contributing factor:
(emphasis added by me).
Even with hundreds of tabs open, I’m currently only seeing around 5G memory usage here. Although it starts leaking like a sieve when playing YouTube videos and requires a browser restart every so often, otherwise it will start getting really laggy & can sometimes cause e.g. a plasmashell crash.
yeah, noticed, Firefox is leaky, but so far, when it get’s too much , i just restart it , it keeps the tabs for me, but even there, firefox seldom if ever gets oomd , and i know it’s leaking. I had memory leak issues years ago with pavocontrol , fortunately that got fixed after a while
The crash looks like an assertion failure in envcan.so Canadian Weather - Environment Canada
So maybe a buggy plasmoid? I searched and got a suggestion it could be related to ā€˜weather canada’…
Same issue with a clean USER?
Occasionally an update will render existing settings outdated, the same goes for plasmoids, so it might be prudent to apply the same measures we applied upgrading from Plasma 5 to Plasma 6 and do extensive housekeeping.
thanks, i do use the weather widget , but from the bbc , but i would get rid of it again for the sake of experiment, hmm, interesting catch
Environment Canada with Plasma was very crashy, but it’s fixed now with Plasma 6.6.
Take a look at this:
Very simple way to create, test, remove a test user.
I had Plasma crash on me once or twice a day. Removed the weather from task bar and it haven’t crashed since. Plasma 6.5.5 here.
