Having issues finding the correct naming for the libsdl2 library to install
I need to install libsdl2 for Devilution and I am having trouble locating the library in the package lists. Does anyone know what the library would be called and more importantly how I would find this information?
I don’t know what SDL or Devilution is but the package thst provides this library is simply called sdl2.
Edit: Is this this package that’s already in the AUR? AUR (en) - devilutionx
Then, you can just install it directly.
pamac build devilutionx
… will pull in all the required dependencies (but not the optional ones).
Contact the AUR maintainer via comments or email if you have issues. I’ve made suggestions in the past, there have been improvements. I’ve lost track since I haven’t used this package.
