Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 wm: kwin_wayland vt: 3 dm: SDDM
Type: Desktop Mobo: Micro-Star model: H410M PRO-VH (MS-7C89) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.80
date: 11/16/2020
RAM: total: 15.57 GiB used: 2.82 GiB (18.1%)
RAM Report:
Info: quad core model: Intel Core i3-10100F bits: 64 type: MT MCP
smt: enabled arch: Comet Lake rev: 3 cache: L1: 256 KiB L2: 1024 KiB
L3: 6 MiB
Speed (MHz): avg: 2515 high: 4181 min/max: 800/4300 cores: 1: 800 2: 800
3: 800 4: 2920 5: 4136 6: 4181 7: 3479 8: 3005 bogomips: 57616
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire driver: amdgpu v: kernel pcie: speed: 8 GT/s lanes: 16
ports: active: DP-2 empty: DP-1, DVI-D-1, HDMI-A-1, HDMI-A-2
bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
compositor: kwin_wayland driver: X: loaded: amdgpu,ati
unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu display-ID: 0
Monitor-1: DP-2 res: 1920x1080 size: N/A
OpenGL: renderer: AMD Radeon RX 570 Series (POLARIS10 DRM 3.42.0
5.15.25-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.7 direct render: Yes
Device-1: Intel Comet Lake PCH-V cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a3f0
class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Sapphire driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d55 class-ID: 0200
driver: btusb v: 0.8 bus-ID: 1-5.3:4 chip-ID: 0a12:0001 class-ID: fe01
Local Storage: total: 2.04 TiB used: 441.31 GiB (21.1%)
ID-1: /dev/sda vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: R013 scheme: GPT
ID-2: /dev/sdb vendor: Western Digital model: WD10EZRX-00L4HB0
size: 931.51 GiB speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A01 scheme: GPT
ID-3: /dev/sdc type: USB model: External USB3.0 size: 931.51 GiB
type: N/A serial: <filter> rev: 0204 scheme: GPT
ID-1: / size: 113.48 GiB used: 12.18 GiB (10.7%) fs: ext4 dev: /dev/sda6
label: N/A uuid: cda6c44b-834f-44c1-a498-b652a52d7795
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/sda5 label: NO_LABEL uuid: 16F4-6AD2
ID-3: /run/media/vikas/Data size: 839.84 GiB used: 429.13 GiB (51.1%)
fs: ntfs dev: /dev/sdc1 label: Data uuid: A666699466696651
ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sda1 size: 100 MiB fs: vfat label: N/A uuid: 12E3-916B
ID-2: /dev/sda2 size: 16 MiB fs: <superuser required> label: N/A
uuid: N/A
ID-3: /dev/sda3 size: 106.81 GiB fs: ntfs label: N/A
uuid: 6CDEEAC7DEEA88A2
ID-4: /dev/sda4 size: 509 MiB fs: ntfs label: N/A uuid: 7E4A79D34A798923
ID-5: /dev/sdb1 size: 931.39 GiB fs: ntfs label: data
uuid: 26C6AECEC6AE9D95
ID-6: /dev/sdc2 size: 91.67 GiB fs: ext4 label: timeshift
uuid: ef797067-6d9b-42b0-8957-049f399b1e02
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Hub-2: 1-5:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-5.1:3 info: Pixart Imaging Gaming Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 093a:2530 class-ID: 0301
Device-2: 1-5.3:4
info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 100mA
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Device-1: 2-3:2 info: JMicron / USA JMS578 SATA 6Gb/s type: Mass Storage
driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 152d:0578 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 27.8 C mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 976
Processes: 248 Uptime: 23m wakeups: 0 Init: systemd v: 250 Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1070 Shell: Zsh v: 5.8.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
I am on plasma wayland and have this issue since i started using wayland in 5.23 and waited for 5.24 hoping it might solve this. The problem is there is a delay in click and response, Please consult the video, any help or explanation will be appreciated.
