I’m using Manjaro KDE6 on Wayland, fully updated to the latest Manjaro stable packages.
Today I noticed that in plasma-systemmonitor , the per-process network download speed is no longer displayed (upload speed still shows correctly).
At the same time, the per-process I/O speed is also missing.
I’m not sure when this issue started, but it wasn’t happening before.
Has anyone else encountered this problem, or knows what might be causing it? Any suggestions or fixes would be greatly appreciated.
inxi -zv8 ✔
Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=f9a8d7df-aa23-49d0-b6f9-94f4a7930551 rw rootflags=subvol=@
quiet splash udev.log_priority=3 nvidia_drm.modeset=1
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.18.0
wm: kwin_wayland with: krunner vt: 1 dm: SDDM Distro: Manjaro
base: Arch Linux
Type: Laptop System: MECHREVO product: Jiaolong16K Series GM6BG0Q
v: Standard serial: <superuser required>
Mobo: MECHREVO model: GM6BG0Q v: Standard serial: <superuser required>
part-nu: 0001 uuid: <superuser required> Firmware: UEFI vendor: American
Megatrends LLC. v: N.1.21MRO18 date: 10/10/2023
ID-1: BAT0 charge: 41 Wh (100%) condition: 41/62.3 Wh (65.9%) volts: 16.16
min: 15.2 model: standard type: Li-ion serial: <filter> charging:
status: full cycles: N/A
Device-1: hidpp_battery_0 model: Logitech G304 Lightspeed Wireless Gaming
Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 16 GiB available: 14.87 GiB used: 9.54 GiB (64.2%)
Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: 4800 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Samsung
part-no: M425R1GB4BB0-CQKOL serial: <filter>
Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 7735H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3+ gen: 3 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404108
desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2298 min/max: 400/4829 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2298 2: 2298 3: 2298
4: 2298 5: 2298 6: 2298 7: 2298 8: 2298 9: 2298 10: 2298 11: 2298 12: 2298
13: 2298 14: 2298 15: 2298 16: 2298 bogomips: 102232
xsaves xtopology
affected
Device-1: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile]
vendor: AIstone Global driver: nvidia v: 580.82.09
alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-11) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s ports: active: none
empty: DP-1,HDMI-A-1,eDP-1 bus-ID: 01:00.0 chip-ID: 10de:28a0
class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
vendor: AIstone Global driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: eDP-2 empty: DP-2, DP-3, DP-4, DP-5, Writeback-1
bus-ID: 05:00.0 chip-ID: 1002:1681 class-ID: 0300 temp: 56.0 C
Device-3: Kingcome HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 2b7e:b680
compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
gpu: amdgpu display-ID: 0
Monitor-1: eDP-2 model: BOE Display 0x0a1f built: 2021 res:
mode: 2560x1600 hz: 165 scale: 150% (1.5) to: 1707x1067 dpi: 189 gamma: 1.2
chroma: red: x: 0.643 y: 0.333 green: x: 0.298 y: 0.624 blue: x: 0.149
y: 0.059 white: x: 0.314 y: 0.329 size: 344x215mm (13.54x8.46")
diag: 406mm (16") ratio: 16:10 modes: 2560x1600, 1920x1200, 1920x1080,
1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768,
800x600, 640x480
EDID-Warnings: 1: parse_edid: unknown tag 112
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm:
drv: kms_swrast surfaceless: drv: nvidia wayland: drv: radeonsi x11:
drv: radeonsi inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.2.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 680M (radeonsi rembrandt
LLVM 20.1.8 DRM 3.61 6.12.48-1-MANJARO) device-ID: 1002:1681
memory: 500 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 9 device: 0 type: integrated-gpu name: AMD
Radeon 680M (RADV REMBRANDT) driver: mesa radv v: 25.2.3-arch1.2
device-ID: 1002:1681 surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 4060 Laptop GPU driver: nvidia v: 580.82.09
device-ID: 10de:28a0 surfaces: N/A
Device-1: NVIDIA AD107 High Definition Audio vendor: AIstone Global
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
bus-ID: 01:00.1 chip-ID: 10de:22be class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor
vendor: AIstone Global driver: snd_pci_acp6x v: kernel
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: AIstone Global driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
vendor: AIstone Global driver: r8168 v: 8.055.00-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:0608
class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 0e8d:0608
Local Storage: total: 953.87 GiB used: 394.66 GiB (41.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Yangtze Memory
model: ZHITAI TiPlus7100 1TB size: 953.87 GiB block-size: physical: 512 B
fw-rev: ZTA22002 temp: 43.9 C scheme: GPT
ID-1: / raw-size: 621.56 GiB size: 621.56 GiB (100.00%)
used: 394.32 GiB (63.4%) fs: btrfs dev: /dev/nvme0n1p8 maj-min: 259:6
label: btrfs uuid: f9a8d7df-aa23-49d0-b6f9-94f4a7930551
used: 67.8 MiB (22.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: ESP_EFI uuid: C4EC-DA15
ID-3: /home raw-size: 621.56 GiB size: 621.56 GiB (100.00%)
ID-4: /var/cache raw-size: 621.56 GiB size: 621.56 GiB (100.00%)
ID-5: /var/log raw-size: 621.56 GiB size: 621.56 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.43 GiB used: 4.25 GiB (57.2%)
priority: 100 comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842
max-streams: 16 dev: /dev/zram0
ID-2: swap-2 type: partition size: 32 GiB used: 286 MiB (0.9%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:5 label: N/A
uuid: aca98503-a2cb-490c-8c12-2744cfb27f98
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 200 GiB fs: ntfs
label: Win11Pro X64 uuid: E622F00722EFDB17
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 100 GiB fs: ntfs
label: Zhitai 7100Plus Data uuid: 9BC5A49940E4360D
Device-1: 1-3:2 info: Kingcome HD Webcam type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 2b7e:b680 class-ID: 0e02 serial: <filter>
Device-2: 1-4:3 info: Logitech USB Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c53f class-ID: 0300
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
Device-1: 3-3:2 info: MediaTek Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 0e8d:0608 class-ID: e001 serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-6: 5-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1
Hub-7: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
Hub-8: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-9: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-10: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-11: 10-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 67.2 C mobo: 48.5 C gpu: amdgpu temp: 58.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1914 libs: 397 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
2: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 462
1: cpu: 33.1% command: firefox pid: 39712 mem: 1021.4 MiB (6.7%)
2: cpu: 19.0% command: firefox pid: 67789 mem: 461.9 MiB (3.0%)
3: cpu: 16.0% command: steam pid: 12202 mem: 50.8 MiB (0.3%)
4: cpu: 15.3% command: firefox pid: 39959 mem: 288.7 MiB (1.8%)
5: cpu: 12.8% command: kwin_wayland pid: 1070 mem: 234.0 MiB (1.5%)
Memory top: 5 of 462
1: mem: 1021.4 MiB (6.7%) command: firefox pid: 39712 cpu: 33.1%
2: mem: 908.1 MiB (5.9%) command: firefox pid: 55903 cpu: 3.2%
3: mem: 625.0 MiB (4.1%) command: firefox pid: 41356 cpu: 3.6%
4: mem: 569.7 MiB (3.7%) command: firefox pid: 63650 cpu: 3.6%
5: mem: 540.1 MiB (3.5%) command: plasmashell pid: 1361 cpu: 3.3%
Processes: 462 Power: uptime: 3h 55m states: freeze,mem,disk suspend: s2idle
image: 5.86 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 257 default: graphical tool: systemctl
Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
inxi: 3.3.40
~ getcap /usr/lib/ksysguard/ksgrd_network_helper ✔
/usr/lib/ksysguard/ksgrd_network_helper cap_net_raw=ep
~ sudo setcap cap_net_raw+ep /usr/lib/ksysguard/ksgrd_network_helper ✔
[sudo] cyo57 的密码:
Now I’m temporarily using nethogs to check the network speed of processes, and using sudo iotop to check the I/O speed of processes. These two tools are working normally
