Output log from Konsole provided:
[morningstar@acerlaptopsuleman ~]$ kstart5 plasmashell
Omitting both --window and --windowclass arguments is not recommended
[morningstar@acerlaptopsuleman ~]$ kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_printer_manager.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_powerdevilactivitiesconfig.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/libkcm_qtquicksettings.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kio_fonts.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kio_fonts.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_usb.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/krossmodulekdetranslation.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/krossmodulekdetranslation.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_mailtransport.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_locale.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_proxy.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/akonadi_serializer_addressee.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_netpref.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/akonadi_serializer_contactgroup.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_krunner_spellcheck.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_timedate.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_dolphingeneral.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/krossqts.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/krossqts.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kwincompositing.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_powerdevilprofilesconfig.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/cursorthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/cursorthumbnail.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kget_checksumsearchfactory.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kdeconnect_runcommand_config.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/korg_datenums.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/opendocumentthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/opendocumentthumbnail.so'"
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/jpegthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/jpegthumbnail.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_clock.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kdeconnect_findthisdevice_config.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_cookies.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/plasma-geolocation-ip.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kget_mmsfactory.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kded_apperd.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevilwirelesspowersavingaction_config.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/ffmpegthumbs.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/djvuthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/djvuthumbnail.so'"
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kritathumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kritathumbnail.so'"
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/audiothumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/audiothumbnail.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwin_scripts.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_hotkeys.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/akonadi_serializer_kalarm.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/svgthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/svgthumbnail.so'"
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/textthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/textthumbnail.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kfontviewpart.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_view1394.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevildpmsaction_config.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_keyboard.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_dolphinnavigation.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_kernel.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kget_bittorrentfactory.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kmplayerpart.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_plasmasearch.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_solid_actions.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwintouchscreen.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/libplasmanetworkmanagement_openconnectui.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_desktoppaths.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_mhwd.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_krunner_dictionary.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/akonadi_serializer_mail.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_systemd.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/blenderthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/blenderthumbnail.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kgamma.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/comicbookthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/comicbookthumbnail.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_krunner_pimcontacts.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kamera.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/korg_picoftheday.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwinoptions.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/rawthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/rawthumbnail.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kdeconnect_sendnotifications_config.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/imagethumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/imagethumbnail.so'"
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/windowsexethumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/windowsexethumbnail.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_activities.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_joystick.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/krossmoduleforms.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/krossmoduleforms.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_keyboard.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_devinfo.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/baloofilepropertiesplugin.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kio_obexftp.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kio_obexftp.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_dolphinviewmodes.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevilsuspendsessionaction_config.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/akonadi_serializer_kcalcore.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwintabbox.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_users.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_trash.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_info.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_krunner_charrunner.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevilrunscriptaction_config.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/gsthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/gsthumbnail.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kdeconnect_pausemusic_config.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kget_browser_integration.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevilbrightnesscontrolaction_config.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevildimdisplayaction_config.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/attica_kde.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kio_iso.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kio_iso.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kstyle_breeze_config.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/ebookthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/ebookthumbnail.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/accountwizard_plugin.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kio_bluetooth.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kio_bluetooth.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_networkmanagement.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/miloutextplugin.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_powerdevilglobalconfig.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/okularpart.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kfileaudiopreview.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_krunner_kill.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kstyle_oxygen_config.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevilkeyboardbrightnesscontrolaction_config.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/exrthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/exrthumbnail.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_ssl.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevilhandlebuttoneventsaction_config.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_webshortcuts.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kget_mirrorsearchfactory.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_memory.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kio_krarc.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kio_krarc.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_opengl.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/appimagethumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/appimagethumbnail.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_language_packages.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_smb.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kget_multisegkiofactory.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kdeconnect_share_config.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kmailpart.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwinscreenedges.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_about_distro.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_filetypes.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/windowsimagethumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/windowsimagethumbnail.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcmspellchecking.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kget_metalinkfactory.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_pci.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_fontinst.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/korg_thisdayinhistory.so" does not have a valid 'MetaData' object
kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/fontthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/fontthumbnail.so'"
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kdeconnect.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_mouse.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/libkcm_device_automounter.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwallet5.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/plasma-geolocation-gps.so" does not have a valid 'MetaData' object
kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kded_touchpad.so" does not have a valid 'MetaData' object
kf.plasma.quick: Applet preload policy set to 1
trying to show an empty dialog
file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:146:19: QML Loader: Binding loop detected for property "height"
file:///home/morningstar/.local/share/plasma/plasmoids/org.kde.activeWindowControl/contents/ui/AppMenu.qml:49:9: QML Connections: Cannot assign to non-existent property "onRequestActivateIndex"
QCoreApplication::postEvent: Unexpected null receiver
file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:30:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
libkcups: CUPS-Get-Printers last error: 1282 Bad file descriptor
libkcups: Get-Jobs last error: 1282 Bad file descriptor
libkcups: Create-Printer-Subscriptions last error: 1282 Bad file descriptor
libkcups: Request failed 1282 -1
Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Plasma Shell startup completed
libpng warning: iCCP: known incorrect sRGB profile
file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/LeaveButtons.qml:69:5: QML ToolButton: Binding loop detected for property "display"
Any ideas as to how to get it running?
