Plasma session management hardly exists
I am running Plasma Wayland. I would like to login the DE with the apps (Dolphin, Konsole, browser, etc) started and running exactly as when I last logged out or when I last saved the session.
So in the settings → Startup and Shutdown → Desktop Session:
I set "On login, launch apps that were open: " to either “On last logout” or “When session was manually save”. Neither has any effect, the session starts empty. With the latter setting, I’m supposed to get a prompt to save the session when I log out (or reboot), but in the logout confirmation screen I don’t get that prompt.
Any ideas on what is going on?
BTW, the X11 DE seems to be able to save a session when I log out, though.
➜  ~ sudo inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 6.1.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=06f2f8c6-47ea-444a-97a1-44629f02874f rw quiet splash
    resume=UUID=0fc478b2-1d95-466e-bafd-6de6515a989b udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_wayland dm: SDDM
  Type: Laptop System: Apple product: MacBookPro12,1 v: 1.0 serial: <filter>
    Chassis: type: 9 v: Mac-E43C1C25D4880AD6 serial: <filter>
  Mobo: Apple model: Mac-E43C1C25D4880AD6 v: MacBookPro12,1 serial: <filter>
    UEFI: Apple v: 430.140.3.0.0 date: 04/18/2022
  ID-1: BAT0 charge: 75.9 Wh (99.6%) condition: 76.2/72.3 Wh (105.3%)
    volts: 12.2 min: 11.3 model: SMP bq20z451 type: Li-ion serial: N/A
    status: full cycles: 6
  System RAM: available: 7.67 GiB used: 5.09 GiB (66.4%)
  Array-1: capacity: 8 GiB slots: 2 EC: None max-module-size: 4 GiB
    note: est.
  Device-1: DIMM0 type: DDR3 detail: synchronous size: 4 GiB speed: 1867 MT/s
    volts: N/A width (bits): data: 64 total: 64 manufacturer: 0x80AD
    part-no: 0x483943434E4E4E424C54414C41522D4E5544 serial: <filter>
  Device-2: DIMM0 type: DDR3 detail: synchronous size: 4 GiB speed: 1867 MT/s
  Info: model: Intel Core i5-5257U socket: BGA1168 (U3E1) note: check bits: 64
    type: MT MCP arch: Broadwell gen: core 5 level: v3 note: check built: 2015-18
    process: Intel 14nm family: 6 model-id: 0x3D (61) stepping: 4
    microcode: 0x2F
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 3100 min/max: 500/3100 base/boost: 3100/2700 scaling:
    driver: intel_cpufreq governor: schedutil volts: 1.1 V ext-clock: 25 MHz
    cores: 1: 3100 2: 3100 3: 3100 4: 3100 bogomips: 21611
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
    avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
    nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
    pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
    smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
    tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
    xtopology xtpr
    vulnerable
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel Iris Graphics 6100 vendor: Apple driver: i915 v: kernel
    arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
    empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:162b
    class-ID: 0300
  Display: server: X.Org v: 23.1.2 with: Xwayland v: 23.1.2
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :1 screens: 1
  Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
    s-diag: 798mm (31.43") monitors: <missing: xrandr>
  Monitor-1: eDP-1 model: Apple Color LCD built: 2013 res: 2560x1600 dpi: 227
    gamma: 1.2 size: 286x179mm (11.26x7.05") diag: 337mm (13.3") ratio: 16:10
    modes: 2560x1600
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel Iris Graphics 6100
    (BDW GT3) direct-render: Yes
  Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel
    v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
  Device-2: Intel Wildcat Point-LP High Definition Audio
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
    class-ID: 0403
  Device-3: Broadcom 720p FaceTime HD Camera driver: N/A pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:1570 class-ID: 0480
  API: ALSA v: k6.1.38-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.73 status: n/a (root, process) with: wireplumber
    status: active tools: pw-cli,wpctl
  Server-3: PulseAudio v: 16.1 status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
  Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
    driver: brcmfmac v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 03:00.0 chip-ID: 14e4:43ba class-ID: 0280
  Device-1: Apple Bluetooth Host Controller driver: btusb,hid-generic,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2
    chip-ID: 05ac:8290 class-ID: fe01
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 233.76 GiB used: 74.49 GiB (31.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0256G
    family: SD/SM/TS...E/F/G SSDs size: 233.76 GiB block-size: physical: 4096 B
    logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: PA0Q temp: 39 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 187d 10h cycles: 39784
  ID-1: / raw-size: 48.83 GiB size: 47.76 GiB (97.81%) used: 15.55 GiB (32.6%)
    fs: ext4 block-size: 4096 B dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: 06f2f8c6-47ea-444a-97a1-44629f02874f
  ID-2: /boot/efi raw-size: 1001 MiB size: 999 MiB (99.80%)
    used: 288 KiB (0.0%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
    label: N/A uuid: C52E-DD5A
  ID-3: /home raw-size: 174.19 GiB size: 170.4 GiB (97.82%)
    used: 58.94 GiB (34.6%) fs: ext4 block-size: 4096 B dev: /dev/sda4
    maj-min: 8:4 label: N/A uuid: 3c05e9c8-a423-467e-b26c-b3e64d78c4b5
  ID-1: swap-1 type: partition size: 9.77 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 0fc478b2-1d95-466e-bafd-6de6515a989b
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 11 rev: 2.0
  Device-1: 1-3:2 info: Apple Bluetooth Host Controller
    type: keyboard,mouse,bluetooth driver: btusb,hid-generic,usbhid interfaces: 6
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 05ac:8290
    class-ID: fe01
  Device-2: 1-5:3 info: Apple Internal Keyboard/Trackpad (ISO)
    type: HID,keyboard,mouse driver: apple,bcm5974,usbhid interfaces: 5 rev: 2.0
    chip-ID: 05ac:0273 class-ID: 0300 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 103.0 C pch: 78.5 C mobo: N/A
  Processes: 257 Uptime: 14h 24m wakeups: 3 Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1277 libs: 375 tools: pamac,yay pm: flatpak
  pkgs: 0 Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.27
Yes, see 436318 – Save session doesn't work under Wayland
Wow, more than two years, and no one cares about this.
Any workarounds?
Probably suspending or hibernating … but those also have some undesirable behavior in some cases.
