Here you go
Kernel: 6.12.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=1af7d577-7a3d-40df-8777-abb0c23f052b rw quiet splash
resume=UUID=81df31f6-ebbe-4838-b6c2-e466416e55b6 udev.log_priority=3
Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A wm: kwin_x11 with: krunner
dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop System: ASUS product: All Series v: N/A serial: N/A
Mobo: ASUSTeK model: Z97-PRO v: Rev 1.xx serial: <filter> part-nu: All
uuid: 11783220-d7db-11dd-aaba-08626628835a UEFI: American Megatrends v: 2702
date: 10/27/2015
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 32 GiB available: 31.29 GiB used: 11.91 GiB (38.1%)
Array-1: capacity: 32 GiB slots: 4 modules: 4 EC: None
Device-1: DIMM_A1 type: DDR3 detail: synchronous size: 8 GiB speed:
spec: 1600 MT/s actual: 1333 MT/s volts: curr: 1.35 min: 1.35 max: 1.5
width (bits): data: 64 total: 64 manufacturer: Crucial
part-no: CT102464BD160B.M16 serial: <filter>
Device-2: DIMM_A2 type: DDR3 detail: synchronous size: 8 GiB speed:
Device-3: DIMM_B1 type: DDR3 detail: synchronous size: 8 GiB speed:
part-no: BLT8G3D1608ET3LX0. serial: <filter>
Device-4: DIMM_B2 type: DDR3 detail: synchronous size: 8 GiB speed:
Slot: 1 type: PCIe status: available length: short volts: 3.3
bus-ID: 08:00.0
Slot: 2 type: PCIe status: in use length: long volts: 3.3 bus-ID: 01:00.0
Slot: 3 type: PCIe status: available length: short volts: 3.3
bus-ID: 07:00.0
Slot: 4 type: PCIe status: available length: short volts: 3.3
bus-ID: 07:00.0
Slot: 5 type: PCIe status: in use length: long volts: 3.3 bus-ID: 02:00.0
Slot: 6 type: PCIe status: available length: short volts: 3.3
bus-ID: ff:00.0
Slot: 7 type: PCIe status: available length: long volts: 3.3
bus-ID: ff:00.0
Info: model: Intel Core i7-4790K socket: BGA1155 (1150) note: check bits: 64
type: MT MCP arch: Haswell gen: core 4 level: v3 note: check built: 2013-15
process: Intel 22nm family: 6 model-id: 0x3C (60) stepping: 3
microcode: 0x28
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4400 base/boost: 4000/3800 scaling:
driver: intel_cpufreq governor: schedutil volts: 1.2 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
bogomips: 63985
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid
x2apic xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: Gigabyte driver: nvidia
v: 550.144.03 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
status: current (as of 2025-01; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 ports: active: none off: DP-1,DP-2,DP-3
empty: DVI-I-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:13c2 class-ID: 0300
Device-2: NVIDIA GM204 [GeForce GTX 970] vendor: Gigabyte driver: nvidia
process: TSMC 28nm built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none empty: DP-4,
DP-5, DP-6, DVI-I-2, HDMI-A-2 bus-ID: 02:00.0 chip-ID: 10de:13c2
class-ID: 0300
Device-3: KYE Systems (Mouse Systems) PC-LM1E Camera
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 5-1.5:5 chip-ID: 0458:6006 class-ID: 0102
serial: <filter>
Display: unspecified server: X.Org v: 21.1.15 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 92 s-size: 1590x301mm (62.60x11.85")
s-diag: 1618mm (63.71")
Monitor-1: DP-1 pos: left res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 93 size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-2: DP-3 pos: right res: mode: 1920x1080 hz: 60 scale: 100% (1)
Monitor-3: DP-5 pos: primary,center res: mode: 1920x1080 hz: 60
scale: 100% (1) dpi: 93 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 1
drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia inactive: gbm,wayland
API: OpenGL v: 4.6.0 vendor: nvidia v: 550.144.03 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 970/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.4.303 layers: 6 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 970 driver: N/A device-ID: 10de:13c2
surfaces: xcb,xlib device: 1 type: discrete-gpu
surfaces: N/A
Device-1: Intel 9 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
class-ID: 0403
Device-2: NVIDIA GM204 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
Device-3: NVIDIA GM204 High Definition Audio vendor: Gigabyte
link-max: lanes: 16 bus-ID: 02:00.1 chip-ID: 10de:0fbb class-ID: 0403
Device-4: JOUNIVO JV610P driver: snd-usb-audio type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1.2:4 chip-ID: 5610:1010
class-ID: 0300 serial: <filter>
Device-5: KYE Systems (Mouse Systems) PC-LM1E Camera
serial: <filter>
API: ALSA v: k6.12.11-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: n/a (root, process) with:
Device-1: Intel Ethernet I218-V vendor: ASUSTeK driver: e1000e v: kernel
port: f040 bus-ID: 00:19.0 chip-ID: 8086:15a1 class-ID: 0200
IF-ID-1: docker0 state: down mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-6:2
chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
Local Storage: total: 12.28 TiB used: 1.47 TiB (11.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40D temp: 24.9 C
scheme: GPT
SMART: yes health: PASSED on: 139d 21h cycles: 27
read-units: 8,227,898 [4.21 TB] written-units: 6,833,495 [3.49 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD3003FZEX-00Z4SA0 family: Black size: 2.73 TiB block-size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: 1A01 temp: 28 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 8y 9d 20h cycles: 1157
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 2TB
family: based SSDs size: 1.82 TiB block-size: physical: 512 B logical: 512 B
sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 3B6Q
temp: 19 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 139d 9h cycles: 26
written: 1.6 TiB
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 500GB
family: based SSDs size: 465.76 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 2B6Q temp: 17 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 6y 215d 5h cycles: 539
written: 11.75 TiB
ID-5: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 870 EVO 2TB
sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 2B6Q
temp: 22 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 42d 13h cycles: 29
written: 11.12 TiB
ID-6: /dev/sde maj-min: 8:64 vendor: Crucial model: CT4000BX500SSD1
size: 3.64 TiB block-size: physical: 512 B logical: 512 B sata: 3.3
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 081 temp: 21 C
scheme: GPT
SMART: yes state: enabled health: PASSED on: 139d 2h cycles: 24
Optical-1: /dev/sr0 vendor: ASUS model: BC-12B1ST b rev: 1.00
dev-links: cdrom
Features: speed: 1 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 1.1 TiB size: 1.09 TiB (98.34%) used: 57.86 GiB (5.2%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p7 maj-min: 259:7
label: linux-root uuid: 1af7d577-7a3d-40df-8777-abb0c23f052b
used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p5
maj-min: 259:5 label: BOOT-EFI uuid: 632B-2165
ID-3: /home raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
used: 689.33 GiB (18.8%) fs: ext4 block-size: 4096 B dev: /dev/sde1
maj-min: 8:65 label: linux-home uuid: abb65471-4f29-48b0-8ce9-b257c7d092cd
ID-4: /home/<filter>/1tb-ssd-samsung-old raw-size: 931.32 GiB
size: 915.63 GiB (98.32%) used: 2 MiB (0.0%) fs: ext4 block-size: 4096 B
dev: /dev/sdd1 maj-min: 8:49 label: old-2tbssd-linux
uuid: abd31381-81da-40fa-bdf2-ef362b168618
ID-5: /home/<filter>/2tb-ssd-samsung-games raw-size: 1.82 TiB
size: 1.79 TiB (98.37%) used: 754.56 GiB (41.2%) fs: ext4 block-size: 4096 B
dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 1d43cbca-cc0c-41be-b622-1885d93b2afe
ID-1: swap-1 type: partition size: 2 GiB used: 48.3 MiB (2.4%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6 label: swap
uuid: 81df31f6-ebbe-4838-b6c2-e466416e55b6
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 400 MiB fs: vfat label: N/A
uuid: ACBB-E819
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 728.46 GiB fs: ntfs
label: windows system uuid: 5E9CBCEB9CBCBEB9
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 546 MiB fs: ntfs label: N/A
uuid: C6C6BB7BC6BB6A77
ID-5: /dev/sda1 maj-min: 8:1 size: 1.31 TiB fs: ext4 label: archhome
uuid: bf509221-e254-420f-8a9a-4d0d84c2d9e3
ID-6: /dev/sda2 maj-min: 8:2 size: 8.33 GiB fs: swap label: linuxswap
uuid: 268b5253-6dd5-40d3-bb88-f37a37970b59
ID-7: /dev/sda3 maj-min: 8:3 size: 1.41 TiB fs: ntfs label: windowshome
uuid: 53BD5C853798AB1F
ID-8: /dev/sdc1 maj-min: 8:33 size: 500 MiB fs: vfat label: N/A
uuid: 1490-61EC
ID-9: /dev/sdc2 maj-min: 8:34 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-10: /dev/sdc3 maj-min: 8:35 size: 464.4 GiB fs: ntfs label: N/A
uuid: 9AC28FD9C28FB851
ID-11: /dev/sdc4 maj-min: 8:36 size: 879 MiB fs: ntfs label: N/A
uuid: 9062763362761DE2
ID-12: /dev/sdd2 maj-min: 8:50 size: 931.69 GiB fs: ntfs
label: old-2tbssd-windows uuid: 0ADCEAD71C0AB884
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel ports: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 chip-ID: 8087:8009 class-ID: 0900
Hub-3: 2-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 2-6:2 info: ASUSTek Broadcom BCM20702A0 Bluetooth
type: Bluetooth driver: btusb interfaces: 4 rev: 2.0
Hub-4: 2-10:3 info: VIA Labs VL812 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2812
Device-1: 2-10.4:5 info: Metadot Das Keyboard 4 type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 24f0:0140 class-ID: 0300
Device-2: 2-11:4 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-3: 2-12:6 info: Logitech Cordless Mouse Receiver type: mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c537 class-ID: 0300
Hub-5: 3-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-6: 3-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8001
Hub-7: 4-0:1 info: super-speed hub ports: 6 rev: 3.0
Hub-8: 4-6:2 info: VIA Labs VL812 Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0812
Hub-9: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-10: 5-1:2 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
chip-ID: 1a40:0201 class-ID: 0900
Device-1: 5-1.1:3 info: SiGma Micro USB Keyboard type: keyboard,HID
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 1c4f:0027 class-ID: 0300
Device-2: 5-1.2:4 info: JOUNIVO JV610P type: audio,HID
driver: snd-usb-audio interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 84mA chip-ID: 5610:1010 class-ID: 0300
serial: <filter>
Device-3: 5-1.5:5 info: KYE Systems (Mouse Systems) PC-LM1E Camera
type: video,audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 256mA
chip-ID: 0458:6006 class-ID: 0102 serial: <filter>
Device-4: 5-1.6:6 info: Natural Point TrackIR 5 Pro Head Tracker type: N/A
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 366mA chip-ID: 131d:0158 class-ID: 0000
Hub-11: 5-1.7:7 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 5-1.7.1:8 info: Good Work Systems GWS IDI Device
type: mouse,HID,keyboard driver: hid-generic,usbhid interfaces: 4 rev: 1.1
chip-ID: 1095:0400 class-ID: 0300 serial: <filter>
Device-2: 5-1.7.2:9 info: Genesys Logic Logilink CR0012 type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 05e3:0745 class-ID: 0806
serial: <filter>
Device-3: 5-1.7.3:10 info: Valve Wireless Steam Controller
type: keyboard,HID driver: hid-steam,usbhid interfaces: 5 rev: 2.0
chip-ID: 28de:1142 class-ID: 0300
Device-4: 5-1.7.4:11 info: HP LaserJet 1022 type: printer driver: usblp
power: 98mA chip-ID: 03f0:2c17 class-ID: 0701 serial: <filter>
Hub-12: 6-0:1 info: super-speed hub ports: 2 rev: 3.0
System Temperatures: cpu: 37.0 C mobo: N/A gpu: nvidia temp: 37 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 51%
Packages: pm: pacman pkgs: 1801 libs: 511 tools: pamac pm: flatpak pkgs: 0
1: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
4: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
5: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 434
1: cpu: 10.8% command: Xorg pid: 185780 mem: 217.6 MiB (0.6%)
2: cpu: 3.4% command: chrome pid: 276587 mem: 398.0 MiB (1.2%)
3: cpu: 3.0% command: chrome pid: 187676 mem: 521.9 MiB (1.6%)
4: cpu: 2.6% command: [nv_queue] pid: 622 mem: 0.00 MiB (0.0%)
5: cpu: 2.0% command: chrome pid: 277629 mem: 440.2 MiB (1.3%)
Memory top: 5 of 434
1: mem: 837.4 MiB (2.6%) command: chrome pid: 186425 cpu: 1.3%
2: mem: 801.1 MiB (2.5%) command: plasmashell pid: 185956 cpu: 0.1%
3: mem: 544.9 MiB (1.7%) command: ./steamwebhelper pid: 202215 cpu: 0.4%
4: mem: 531.1 MiB (1.6%) command: steamwebhelper pid: 202291 cpu: 0.5%
5: mem: 521.9 MiB (1.6%) command: chrome pid: 187676 cpu: 3.0%
Processes: 434 Power: uptime: 3d 1h 22m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2 default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.37
Thanks
Jason
