Just accidentally discovered that ‘/’ can be accessed by ‘back clicking’ with the mouse when dolphin is first opened at the Home position. Rather than selecting ‘>’ at the top of the window. Is this new??
What is this?
A special button?
There has always been common movement commands …
such as Alt+ ← for ‘back’ and Alt+↑ for ‘parent directory’ .
A full list can be viewed and edited in
Dolphin > Settings > Configure Keyboard and Shortcuts
Do you mean the < and > that you can use as back and forward?
I just tried, it is not happening on my system.
A clean dolphin that opens in home, both buttons are greyed out, but if you have also added the ^ button, THAT button can obviously be pressed, but should bring you to your /home directory (backing up one directory from /home/username
