When computer is going to sleep mode by itself it’s impossible to wake it without having to shutdown the computer with the power button (it goes black screen, or lock screen but only the hour is shown, etc…)
Here is the inxi -Faz output :
Kernel: 5.15.76-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=f859abfe-853f-46a6-b8f4-0c823528b001 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 21BVCTO1WW v: ThinkPad T16 Gen 1
Mobo: LENOVO model: 21BVCTO1WW v: SDK0T76463 WIN
serial: <superuser required> UEFI: LENOVO v: N3MET06W (1.03 )
date: 07/11/2022
ID-1: BAT0 charge: 86.1 Wh (99.1%) condition: 86.9/86.0 Wh (101.0%)
volts: 17.8 min: 15.5 model: Sunwoda 5B10W51873 type: Li-poly
serial: <filter> status: charging cycles: 4
Device-1: hidpp_battery_0 model: Logitech MK700 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: discharging
Info: model: 12th Gen Intel Core i5-1240P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x421
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1162 high: 1963 min/max: 400/4400:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 1033 2: 646 3: 1963
4: 1662 5: 1027 6: 1199 7: 951 8: 1055 9: 1211 10: 1055 11: 1190 12: 1037
13: 997 14: 1098 15: 1256 16: 1225 bogomips: 67600
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: DP-6,DP-7,eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5
bus-ID: 00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-4:3 chip-ID: 04f2:b761 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 5760x1200 s-dpi: 96 s-size: 1524x317mm (60.00x12.48")
s-diag: 1557mm (61.28")
Monitor-1: not-matched mapped: DP-3-2 pos: right res: 1920x1200 hz: 60
dpi: 94 size: 518x324mm (20.39x12.76") diag: 611mm (24.05") modes: N/A
Monitor-2: not-matched mapped: DP-3-3 pos: center res: 1920x1200 hz: 60
Monitor-3: eDP-1 pos: primary,left model: ChiMei InnoLux 0x1614
built: 2021 res: 1920x1200 hz: 60 dpi: 142 gamma: 1.2
size: 344x215mm (13.54x8.46") diag: 406mm (16") ratio: 16:10
modes: 1920x1200
API: OpenGL v: 4.6 Mesa 22.2.1 renderer: Mesa Intel Graphics (ADL GT2)
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl bus-ID: 3-6.3.3.2:14
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 17ef:a396 chip-ID: 8086:51c8 class-ID: 0300 class-ID: 0403
serial: <filter>
Device-2: Lenovo ThinkPad USB-C Dock Gen2 USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k5.15.76-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1f class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-3: Lenovo USB-C Dock Ethernet type: USB driver: r8152
bus-ID: 2-3.1:5 chip-ID: 17ef:a387 class-ID: 0000 serial: <filter>
IF: enp0s13f0u3u1 state: down mac: <filter>
IF-ID-1: br-48224bdb7487 state: down mac: <filter>
IF-ID-2: br-4a0cc2ea6aa6 state: down mac: <filter>
IF-ID-3: br-4d5dbece4f81 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-4: br-885dbdaf901b state: down mac: <filter>
IF-ID-5: docker0 state: down mac: <filter>
IF-ID-6: vethd41155e state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-7: vethe89ff09 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:7
chip-ID: 8087:0033 class-ID: e001
Local Storage: total: 476.94 GiB used: 39.78 GiB (8.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS512GDE9X081N
lanes: 4 type: SSD serial: <filter> rev: 41730C20 temp: 48.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 39.78 GiB (8.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 56.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 1860
Processes: 381 Uptime: 1h 0m wakeups: 15 Memory: 31.06 GiB
used: 6.37 GiB (20.5%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1256 libs: 318 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.23
