Plasma lock screen is missing Restart and other power options
i only have sleep,switch user and a third one.
it’s needed,
please add them
Thanks.
Mod edit: updated topic title to reflect that the issue is with the lock screen, not SDDM login screen:
Topic moved from feedback to support.
Those options are not part of the theme — they are part of sddm.
If they are missing from the Breath theme, then they will normally also be missing from any other theme, and then you’ve got other problems, probably related to your power settings.
i have no issues,i need these options and i recall them being there before at some point.
do you have them?
do you know how to add them?i looked around but couldn’t find.
I am using the Breeze theme, and I do indeed have several options, although sleep and hibernate have been disabled here — this is a desktop, not a laptop.
i forgot to mention;i don’t have the power option i mentioned when waking from sleep,but when i log in i have them.
Power options aren’t supposed to be in the lock screen.
