After this release GitHub - Zren/plasma-hud: Provides a way to run menubar commands in KDE Plasma through rofi, much like the Unity 7 Heads-Up Display (HUD). stopped working for me. Anyone has a workaround? I suspect the hotkey binding stopped working because of some Plasma update. Thanks!
The last release was from 2019. Care to guess why it no longer works?
FYI, I moved your reply to a new thread as third-party and/or AUR packages are off-topic for Announcements posts.
Thanks Yochanan.
I guess it broke because a Plasma 6 update, I found a fix so I am posting it so it may help someone:
System Settings → Keyboard → Shortcuts → Add New → Command or Script
Paste the command qdbus com.github.zren.PlasmaHUD /PlasmaHUD com.github.zren.PlasmaHUD.toggleHUD
Set the custom shortcut as Alt
