Hello, I’m seeing odd behavior on my Plasma desktop: about once every 3-5 boots I get into my desktop & my left-hand monitor displays my usual panel (task manager, pager, clock), but the desktop space is completely black while it usually displays an image from a slideshow. My right-hand monitor displays normally. If I then use the display configuration widget I can reverse my displays via “extend to right”, pause to let the displays re-arrange – and immediately both my desktops show up correctly. I can then click the “extend to left” button, pause again and my desktops are back to normal.
I don’t know why this is happening; I’ve tried to search in my ~/.config/ to see what settings files are getting updated when I do this, but so far no luck. I see similar things with my clock widget; I had temporarily turned on seconds display so I could try to pin any file updates to a specific time – but turned them off once I thought (incorrectly) that I’d figured it out. But on my next boot this morning they’re back.
The only file change I’ve noticed this morning that looks close to the time I last changed my display configuration was dolphinrc – but I think this is a side-effect of my Dolphin window being moved from one monitor to another.
Can someone please point me in the right direction? I’m trying to lock in my monitor & desktop settings, or at least figure out what’s causing them to drift.
Thanks in advance for any insight or pointers you can offer.
