I’m expriencing this odd visual glitch on Firefox (so far only Firefox), I have attached a GIF of this below:
This happens to input text (right now as I’m typing this) and also tab titles, but tabs are affected only when the window is maximized!
Here’s my inxi:
Kernel: 5.4.74-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/vmlinuz-5.4-x86_64
root=UUID=223b5c19-4a60-494f-ab41-a90693e7ee01 rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.38.2
Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: H61M-S2P-R3 v: H61M-S2P-R3
serial: <filter> Chassis: type: 3 v: H61M-S2P-R3 serial: <filter>
Mobo: Gigabyte model: H61M-S2P-R3 serial: <filter> UEFI: American Megatrends
v: F2 date: 04/26/2013
Info: Dual Core model: Intel Pentium G2030 bits: 64 type: MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 11977
Speed: 1997 MHz min/max: 1600/3000 MHz Core speeds (MHz): 1: 1771 2: 1703
Type: l1tf
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: ASUSTeK driver: nvidia
v: 455.38 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:128b
Display: x11 server: X.org 1.20.9 compositor: gnome-shell driver: nvidia
resolution: <xdpyinfo missing>
OpenGL: renderer: GeForce GT 710/PCIe/SSE2 v: 4.6.0 NVIDIA 455.38
direct render: Yes
vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:1c20
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 10de:0e0f
Sound Server: ALSA v: k5.4.74-1-MANJARO
vendor: Gigabyte driver: r8168 v: 8.048.03-NAPI modules: r8169 port: d000
bus ID: 04:00.0 chip ID: 10ec:8168
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.05 TiB used: 757.78 GiB (36.2%)
ID-1: /dev/sda vendor: Toshiba model: DT01ACA200 size: 1.82 TiB block size:
physical: 4096 B logical: 512 B speed: 3.0 Gb/s rotation: 7200 rpm
serial: <filter> rev: ABB0 scheme: GPT
ID-2: /dev/sdb vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter>
rev: 4B6Q scheme: GPT
ID-1: / raw size: 100.00 GiB size: 100.00 GiB (100.00%)
used: 11.47 GiB (11.5%) fs: btrfs dev: /dev/sdb3
ID-2: /boot raw size: 1024.0 MiB size: 975.9 MiB (95.30%)
used: 61.3 MiB (6.3%) fs: ext4 dev: /dev/sdb2
ID-3: /home raw size: 100.00 GiB size: 97.93 GiB (97.93%)
used: 7.81 GiB (8.0%) fs: ext4 dev: /dev/sdb4
ID-1: swap-1 type: partition size: 16.00 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda1
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 47 C
Processes: 261 Uptime: 29m Memory: 11.66 GiB used: 1.75 GiB (15.0%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1312 pacman: 1302
lib: 358 flatpak: 7 snap: 3 Shell: Zsh v: 5.8 running in: gnome-terminal
inxi: 3.1.08
Here’s dmseg
[ 0.232892] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 1.149624] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT1._GTF.DSSP], AE_NOT_FOUND (20190816/psargs-330)
[ 1.149636] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT1._GTF due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
[ 1.150345] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT0._GTF.DSSP], AE_NOT_FOUND (20190816/psargs-330)
[ 1.150357] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT0._GTF due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
[ 1.150445] ata1.00: supports DRM functions and may not be fully accessible
[ 1.151172] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT1._GTF.DSSP], AE_NOT_FOUND (20190816/psargs-330)
[ 1.151184] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT1._GTF due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
[ 1.151836] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT4._GTF.DSSP], AE_NOT_FOUND (20190816/psargs-330)
[ 1.151844] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT4._GTF due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
[ 1.152839] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT4._GTF.DSSP], AE_NOT_FOUND (20190816/psargs-330)
[ 1.152851] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT4._GTF due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
[ 1.153809] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT0._GTF.DSSP], AE_NOT_FOUND (20190816/psargs-330)
[ 1.153821] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT0._GTF due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
[ 1.153902] ata1.00: supports DRM functions and may not be fully accessible
[ 2.432873] systemd[1]: /usr/lib/systemd/system/plymouth-start.service:15: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[ 2.913889] nvidia: loading out-of-tree module taints kernel.
[ 2.913898] nvidia: module license 'NVIDIA' taints kernel.
[ 2.913899] Disabling lock debugging due to kernel taint
[ 3.178484] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 455.38 Thu Oct 22 06:06:59 UTC 2020
[ 4.209880] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20190816/utaddress-204)
[ 4.209888] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[ 4.209892] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[ 4.209895] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000051F (\LED) (20190816/utaddress-204)
[ 4.209897] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[ 4.209900] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 4.357995] r8168 Copyright (C) 2020 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 5.294793] kauditd_printk_skb: 40 callbacks suppressed
[ 7.689119] bluetooth hci0: Direct firmware load for brcm/BCM20702A1-0a5c-21ec.hcd failed with error -2
[ 10.623483] kauditd_printk_skb: 23 callbacks suppressed
[ 22.118915] kauditd_printk_skb: 4 callbacks suppressed
And finally here’s Xorg.log
[ 7.689] (--) Log file renamed from "/var/log/Xorg.pid-813.log" to "/var/log/Xorg.0.log"
[ 7.689] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 7.689]
X.Org X Server 1.20.9
[ 7.689] Build Operating System: Linux Manjaro Linux
[ 7.690] Current Operating System: Linux bumblebee 5.4.74-1-MANJARO #1 SMP PREEMPT Sun Nov 1 13:43:13 UTC 2020 x86_64
[ 7.690] Kernel command line: BOOT_IMAGE=/vmlinuz-5.4-x86_64 root=UUID=223b5c19-4a60-494f-ab41-a90693e7ee01 rw rootflags=subvol=@ quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 7.690] Build Date: 02 September 2020 07:39:17AM
[ 7.690]
[ 7.690] Current version of pixman: 0.40.0
[ 7.690] Before reporting problems, check http://wiki.x.org
[ 7.690] Markers: (--) probed, (**) from config file, (==) default setting,
[ 7.690] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Nov 18 23:10:31 2020
[ 7.691] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 7.691] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 7.692] (==) ServerLayout "layout"
[ 7.692] (**) |-->Screen "Screen0" (0)
[ 7.692] (**) | |-->Monitor "Monitor0"
[ 7.692] (**) | |-->Device "Device0"
[ 7.692] (==) Automatically adding devices
[ 7.692] (==) Automatically enabling devices
[ 7.692] (==) Automatically adding GPU devices
[ 7.692] (==) Automatically binding GPU devices
[ 7.692] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 7.696] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[ 7.696] Entry deleted from font path.
[ 7.696] (Run 'mkfontdir' on "/usr/share/fonts/misc").
[ 7.697] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 7.697] Entry deleted from font path.
[ 7.697] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 7.697] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 7.697] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 7.697] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 7.697] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 7.697] (==) FontPath set to:
[ 7.697] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 7.697] (**) Extension "COMPOSITE" is enabled
[ 7.697] (II) The server relies on udev to provide the list of input devices.
[ 7.697] (II) Module ABI versions:
[ 7.697] X.Org ANSI C Emulation: 0.4
[ 7.697] X.Org Video Driver: 24.1
[ 7.697] X.Org XInput driver : 24.1
[ 7.697] X.Org Server Extension : 10.0
[ 7.698] (++) using VT number 1
[ 7.700] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 7.703] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 7.703] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[ 7.704] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[ 7.706] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 7.706] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 7.707] (--) PCI:*(1@0:0:0) 10de:128b:1043:8572 rev 161, Mem @ 0xf6000000/16777216, 0x710000000/134217728, 0x718000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 7.707] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 7.707] (II) LoadModule: "glx"
[ 7.709] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 7.725] (II) Module glx: vendor="X.Org Foundation"
[ 7.725] compiled for 1.20.9, module version = 1.0.0
[ 7.725] ABI class: X.Org Server Extension, version 10.0
[ 7.725] (II) LoadModule: "nvidia"
[ 7.725] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 7.751] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 7.751] compiled for 1.6.99.901, module version = 1.0.0
[ 7.751] Module class: X.Org Video Driver
[ 7.751] (II) NVIDIA dlloader X Driver 455.38 Thu Oct 22 06:02:31 UTC 2020
[ 7.751] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 7.751] (II) systemd-logind: releasing fd for 226:0
[ 7.752] (II) Loading sub module "fb"
[ 7.752] (II) LoadModule: "fb"
[ 7.753] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 7.754] (II) Module fb: vendor="X.Org Foundation"
[ 7.754] compiled for 1.20.9, module version = 1.0.0
[ 7.754] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7.754] (II) Loading sub module "wfb"
[ 7.754] (II) LoadModule: "wfb"
[ 7.754] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 7.755] (II) Module wfb: vendor="X.Org Foundation"
[ 7.755] compiled for 1.20.9, module version = 1.0.0
[ 7.755] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7.755] (II) Loading sub module "ramdac"
[ 7.755] (II) LoadModule: "ramdac"
[ 7.755] (II) Module "ramdac" already built-in
[ 7.756] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 7.756] (==) NVIDIA(0): RGB weight 888
[ 7.756] (==) NVIDIA(0): Default visual is TrueColor
[ 7.756] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 7.756] (**) Option "AllowNVIDIAGpuScreens"
[ 7.756] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 7.756] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 7.756] (**) NVIDIA(0): Enabling 2D acceleration
[ 7.756] (II) Loading sub module "glxserver_nvidia"
[ 7.756] (II) LoadModule: "glxserver_nvidia"
[ 7.757] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 7.952] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 7.953] compiled for 1.6.99.901, module version = 1.0.0
[ 7.953] Module class: X.Org Server Extension
[ 7.953] (II) NVIDIA GLX Module 455.38 Thu Oct 22 06:01:10 UTC 2020
[ 7.953] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 8.644] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 8.644] (--) NVIDIA(0): CRT-0 (boot)
[ 8.644] (--) NVIDIA(0): DFP-0
[ 8.644] (--) NVIDIA(0): DFP-1
[ 8.645] (II) NVIDIA(0): NVIDIA GPU GeForce GT 710 (GK208) at PCI:1:0:0 (GPU-0)
[ 8.645] (--) NVIDIA(0): Memory: 2097152 kBytes
[ 8.645] (--) NVIDIA(0): VideoBIOS: 80.28.a6.00.01
[ 8.645] (II) NVIDIA(0): Detected PCI Express Link width: 8X
[ 8.674] (--) NVIDIA(GPU-0): Samsung SMB1930N (CRT-0): connected
[ 8.674] (--) NVIDIA(GPU-0): Samsung SMB1930N (CRT-0): 400.0 MHz maximum pixel clock
[ 8.674] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 8.674] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 8.674] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 8.674] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 8.674] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 8.674] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 8.677] (==) NVIDIA(0):
[ 8.677] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 8.677] (==) NVIDIA(0): will be used as the requested mode.
[ 8.677] (II) NVIDIA(0): Validated MetaModes:
[ 8.677] (II) NVIDIA(0): "CRT-0:nvidia-auto-select"
[ 8.677] (II) NVIDIA(0): Virtual screen size determined to be 1360 x 768
[ 8.679] (--) NVIDIA(0): DPI set to (84, 84); computed from "UseEdidDpi" X config
[ 8.679] (--) NVIDIA(0): option
[ 8.679] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[ 8.679] (II) NVIDIA: access.
[ 8.681] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 8.681] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 8.681] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 8.681] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 8.681] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 8.681] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 8.681] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 8.681] (II) NVIDIA(0): Config Options in the README.
[ 8.700] (II) NVIDIA(0): Setting mode "CRT-0:nvidia-auto-select"
[ 8.730] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 8.730] (==) NVIDIA(0): Backing store enabled
[ 8.730] (==) NVIDIA(0): Silken mouse disabled
[ 8.730] (**) NVIDIA(0): DPMS enabled
[ 8.731] (WW) NVIDIA(0): Option "NoLogo" is not used
[ 8.731] (II) Loading sub module "dri2"
[ 8.731] (II) LoadModule: "dri2"
[ 8.731] (II) Module "dri2" already built-in
[ 8.731] (II) NVIDIA(0): [DRI2] Setup complete
[ 8.731] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 8.731] (II) Initializing extension Generic Event Extension
[ 8.731] (II) Initializing extension SHAPE
[ 8.731] (II) Initializing extension MIT-SHM
[ 8.731] (II) Initializing extension XInputExtension
[ 8.731] (II) Initializing extension XTEST
[ 8.731] (II) Initializing extension BIG-REQUESTS
[ 8.731] (II) Initializing extension SYNC
[ 8.731] (II) Initializing extension XKEYBOARD
[ 8.731] (II) Initializing extension XC-MISC
[ 8.731] (II) Initializing extension SECURITY
[ 8.731] (II) Initializing extension XFIXES
[ 8.731] (II) Initializing extension RENDER
[ 8.731] (II) Initializing extension RANDR
[ 8.731] (II) Initializing extension COMPOSITE
[ 8.731] (II) Initializing extension DAMAGE
[ 8.731] (II) Initializing extension MIT-SCREEN-SAVER
[ 8.731] (II) Initializing extension DOUBLE-BUFFER
[ 8.731] (II) Initializing extension RECORD
[ 8.731] (II) Initializing extension DPMS
[ 8.731] (II) Initializing extension Present
[ 8.731] (II) Initializing extension DRI3
[ 8.731] (II) Initializing extension X-Resource
[ 8.731] (II) Initializing extension XVideo
[ 8.731] (II) Initializing extension XVideo-MotionCompensation
[ 8.731] (II) Initializing extension GLX
[ 8.731] (II) Indirect GLX disabled.
[ 8.731] (II) GLX: Another vendor is already registered for screen 0
[ 8.731] (II) Initializing extension XFree86-VidModeExtension
[ 8.731] (II) Initializing extension XFree86-DGA
[ 8.731] (II) Initializing extension XFree86-DRI
[ 8.731] (II) Initializing extension DRI2
[ 8.731] (II) Initializing extension NV-GLX
[ 8.731] (II) Initializing extension NV-CONTROL
[ 8.731] (II) Initializing extension XINERAMA
[ 8.787] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 8.787] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 8.787] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 8.787] (**) Power Button: Applying InputClass "system-keyboard"
[ 8.787] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 8.787] (II) LoadModule: "libinput"
[ 8.787] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 8.795] (II) Module libinput: vendor="X.Org Foundation"
[ 8.795] compiled for 1.20.8, module version = 0.30.0
[ 8.795] Module class: X.Org XInput Driver
[ 8.795] ABI class: X.Org XInput driver, version 24.1
[ 8.795] (II) Using input driver 'libinput' for 'Power Button'
[ 8.796] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 34 paused 0
[ 8.796] (**) Power Button: always reports core events
[ 8.796] (**) Option "Device" "/dev/input/event1"
[ 8.796] (**) Option "_source" "server/udev"
[ 8.802] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 8.802] (II) event1 - Power Button: device is a keyboard
[ 8.802] (II) event1 - Power Button: device removed
[ 8.802] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 8.802] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 8.802] (**) Option "xkb_layout" "us,ir"
[ 8.802] (**) Option "xkb_variant" ","
[ 8.802] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 8.829] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 8.829] (II) event1 - Power Button: device is a keyboard
[ 8.830] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 8.830] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 8.830] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 8.830] (**) Power Button: Applying InputClass "system-keyboard"
[ 8.830] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 8.830] (II) Using input driver 'libinput' for 'Power Button'
[ 8.831] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 37 paused 0
[ 8.831] (**) Power Button: always reports core events
[ 8.831] (**) Option "Device" "/dev/input/event0"
[ 8.831] (**) Option "_source" "server/udev"
[ 8.833] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 8.833] (II) event0 - Power Button: device is a keyboard
[ 8.833] (II) event0 - Power Button: device removed
[ 8.833] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 8.833] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 8.833] (**) Option "xkb_layout" "us,ir"
[ 8.833] (**) Option "xkb_variant" ","
[ 8.833] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 8.834] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 8.834] (II) event0 - Power Button: device is a keyboard
[ 8.835] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event8)
[ 8.835] (II) No input driver specified, ignoring this device.
[ 8.835] (II) This device may have been added with another device file.
[ 8.835] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event9)
[ 8.836] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event3)
[ 8.836] (II) No input driver specified, ignoring this device.
[ 8.836] (II) This device may have been added with another device file.
[ 8.836] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event4)
[ 8.837] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event5)
[ 8.837] (II) No input driver specified, ignoring this device.
[ 8.837] (II) This device may have been added with another device file.
[ 8.837] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event6)
[ 8.838] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event7)
[ 8.838] (II) No input driver specified, ignoring this device.
[ 8.838] (II) This device may have been added with another device file.
[ 8.839] (II) config/udev: Adding input device MOSART Semi. Wireless Mouse (/dev/input/event10)
[ 8.839] (**) MOSART Semi. Wireless Mouse: Applying InputClass "evdev pointer catchall"
[ 8.839] (**) MOSART Semi. Wireless Mouse: Applying InputClass "libinput pointer catchall"
[ 8.839] (II) Using input driver 'libinput' for 'MOSART Semi. Wireless Mouse'
[ 8.840] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 38 paused 0
[ 8.840] (**) MOSART Semi. Wireless Mouse: always reports core events
[ 8.840] (**) Option "Device" "/dev/input/event10"
[ 8.840] (**) Option "_source" "server/udev"
[ 8.842] (II) event10 - MOSART Semi. Wireless Mouse: is tagged by udev as: Mouse
[ 8.842] (II) event10 - MOSART Semi. Wireless Mouse: device is a pointer
[ 8.843] (II) event10 - MOSART Semi. Wireless Mouse: device removed
[ 8.843] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5.1/2-1.5.1:1.1/0003:0458:0185.0002/input/input10/event10"
[ 8.843] (II) XINPUT: Adding extended input device "MOSART Semi. Wireless Mouse" (type: MOUSE, id 8)
[ 8.843] (**) Option "AccelerationScheme" "none"
[ 8.843] (**) MOSART Semi. Wireless Mouse: (accel) selected scheme none/0
[ 8.843] (**) MOSART Semi. Wireless Mouse: (accel) acceleration factor: 2.000
[ 8.843] (**) MOSART Semi. Wireless Mouse: (accel) acceleration threshold: 4
[ 8.845] (II) event10 - MOSART Semi. Wireless Mouse: is tagged by udev as: Mouse
[ 8.845] (II) event10 - MOSART Semi. Wireless Mouse: device is a pointer
[ 8.846] (II) config/udev: Adding input device MOSART Semi. Wireless Mouse (/dev/input/mouse0)
[ 8.846] (II) No input driver specified, ignoring this device.
[ 8.846] (II) This device may have been added with another device file.
[ 8.847] (II) config/udev: Adding input device MOSART Semi. Wireless Mouse Consumer Control (/dev/input/event11)
[ 8.847] (**) MOSART Semi. Wireless Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 8.847] (**) MOSART Semi. Wireless Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 8.847] (**) MOSART Semi. Wireless Mouse Consumer Control: Applying InputClass "system-keyboard"
[ 8.847] (**) MOSART Semi. Wireless Mouse Consumer Control: Applying InputClass "Keyboard Defaults"
[ 8.847] (II) Using input driver 'libinput' for 'MOSART Semi. Wireless Mouse Consumer Control'
[ 8.848] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 39 paused 0
[ 8.848] (**) MOSART Semi. Wireless Mouse Consumer Control: always reports core events
[ 8.848] (**) Option "Device" "/dev/input/event11"
[ 8.848] (**) Option "_source" "server/udev"
[ 8.850] (II) event11 - MOSART Semi. Wireless Mouse Consumer Control: is tagged by udev as: Keyboard
[ 8.850] (II) event11 - MOSART Semi. Wireless Mouse Consumer Control: device is a keyboard
[ 8.850] (II) event11 - MOSART Semi. Wireless Mouse Consumer Control: device removed
[ 8.850] (II) libinput: MOSART Semi. Wireless Mouse Consumer Control: needs a virtual subdevice
[ 8.851] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5.1/2-1.5.1:1.1/0003:0458:0185.0002/input/input11/event11"
[ 8.851] (II) XINPUT: Adding extended input device "MOSART Semi. Wireless Mouse Consumer Control" (type: MOUSE, id 9)
[ 8.851] (**) Option "AccelerationScheme" "none"
[ 8.851] (**) MOSART Semi. Wireless Mouse Consumer Control: (accel) selected scheme none/0
[ 8.851] (**) MOSART Semi. Wireless Mouse Consumer Control: (accel) acceleration factor: 2.000
[ 8.851] (**) MOSART Semi. Wireless Mouse Consumer Control: (accel) acceleration threshold: 4
[ 8.853] (II) event11 - MOSART Semi. Wireless Mouse Consumer Control: is tagged by udev as: Keyboard
[ 8.853] (II) event11 - MOSART Semi. Wireless Mouse Consumer Control: device is a keyboard
[ 8.854] (II) config/udev: Adding input device MOSART Semi. Wireless Mouse System Control (/dev/input/event12)
[ 8.854] (**) MOSART Semi. Wireless Mouse System Control: Applying InputClass "evdev keyboard catchall"
[ 8.854] (**) MOSART Semi. Wireless Mouse System Control: Applying InputClass "libinput keyboard catchall"
[ 8.854] (**) MOSART Semi. Wireless Mouse System Control: Applying InputClass "system-keyboard"
[ 8.854] (**) MOSART Semi. Wireless Mouse System Control: Applying InputClass "Keyboard Defaults"
[ 8.854] (II) Using input driver 'libinput' for 'MOSART Semi. Wireless Mouse System Control'
[ 8.855] (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 40 paused 0
[ 8.855] (**) MOSART Semi. Wireless Mouse System Control: always reports core events
[ 8.855] (**) Option "Device" "/dev/input/event12"
[ 8.855] (**) Option "_source" "server/udev"
[ 8.857] (II) event12 - MOSART Semi. Wireless Mouse System Control: is tagged by udev as: Keyboard
[ 8.857] (II) event12 - MOSART Semi. Wireless Mouse System Control: device is a keyboard
[ 8.857] (II) event12 - MOSART Semi. Wireless Mouse System Control: device removed
[ 8.857] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5.1/2-1.5.1:1.1/0003:0458:0185.0002/input/input12/event12"
[ 8.857] (II) XINPUT: Adding extended input device "MOSART Semi. Wireless Mouse System Control" (type: KEYBOARD, id 10)
[ 8.857] (**) Option "xkb_layout" "us,ir"
[ 8.857] (**) Option "xkb_variant" ","
[ 8.857] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 8.859] (II) event12 - MOSART Semi. Wireless Mouse System Control: is tagged by udev as: Keyboard
[ 8.859] (II) event12 - MOSART Semi. Wireless Mouse System Control: device is a keyboard
[ 8.860] (II) config/udev: Adding input device MOSART Semi. Wireless Mouse (/dev/input/event13)
[ 8.860] (II) No input driver specified, ignoring this device.
[ 8.860] (II) This device may have been added with another device file.
[ 8.861] (II) config/udev: Adding input device SINO WEALTH USB KEYBOARD (/dev/input/event14)
[ 8.861] (**) SINO WEALTH USB KEYBOARD: Applying InputClass "evdev keyboard catchall"
[ 8.861] (**) SINO WEALTH USB KEYBOARD: Applying InputClass "libinput keyboard catchall"
[ 8.861] (**) SINO WEALTH USB KEYBOARD: Applying InputClass "system-keyboard"
[ 8.861] (**) SINO WEALTH USB KEYBOARD: Applying InputClass "Keyboard Defaults"
[ 8.861] (II) Using input driver 'libinput' for 'SINO WEALTH USB KEYBOARD'
[ 8.862] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 41 paused 0
[ 8.862] (**) SINO WEALTH USB KEYBOARD: always reports core events
[ 8.862] (**) Option "Device" "/dev/input/event14"
[ 8.862] (**) Option "_source" "server/udev"
[ 8.864] (II) event14 - SINO WEALTH USB KEYBOARD: is tagged by udev as: Keyboard
[ 8.864] (II) event14 - SINO WEALTH USB KEYBOARD: device is a keyboard
[ 8.864] (II) event14 - SINO WEALTH USB KEYBOARD: device removed
[ 8.864] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5.3/2-1.5.3:1.0/0003:258A:0001.0003/input/input14/event14"
[ 8.864] (II) XINPUT: Adding extended input device "SINO WEALTH USB KEYBOARD" (type: KEYBOARD, id 11)
[ 8.864] (**) Option "xkb_layout" "us,ir"
[ 8.864] (**) Option "xkb_variant" ","
[ 8.865] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 8.866] (II) event14 - SINO WEALTH USB KEYBOARD: is tagged by udev as: Keyboard
[ 8.866] (II) event14 - SINO WEALTH USB KEYBOARD: device is a keyboard
[ 8.867] (II) config/udev: Adding input device SINO WEALTH USB KEYBOARD System Control (/dev/input/event15)
[ 8.867] (**) SINO WEALTH USB KEYBOARD System Control: Applying InputClass "evdev keyboard catchall"
[ 8.868] (**) SINO WEALTH USB KEYBOARD System Control: Applying InputClass "libinput keyboard catchall"
[ 8.868] (**) SINO WEALTH USB KEYBOARD System Control: Applying InputClass "system-keyboard"
[ 8.868] (**) SINO WEALTH USB KEYBOARD System Control: Applying InputClass "Keyboard Defaults"
[ 8.868] (II) Using input driver 'libinput' for 'SINO WEALTH USB KEYBOARD System Control'
[ 8.869] (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 42 paused 0
[ 8.869] (**) SINO WEALTH USB KEYBOARD System Control: always reports core events
[ 8.869] (**) Option "Device" "/dev/input/event15"
[ 8.869] (**) Option "_source" "server/udev"
[ 8.871] (II) event15 - SINO WEALTH USB KEYBOARD System Control: is tagged by udev as: Keyboard
[ 8.871] (II) event15 - SINO WEALTH USB KEYBOARD System Control: device is a keyboard
[ 8.871] (II) event15 - SINO WEALTH USB KEYBOARD System Control: device removed
[ 8.871] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5.3/2-1.5.3:1.1/0003:258A:0001.0004/input/input15/event15"
[ 8.871] (II) XINPUT: Adding extended input device "SINO WEALTH USB KEYBOARD System Control" (type: KEYBOARD, id 12)
[ 8.871] (**) Option "xkb_layout" "us,ir"
[ 8.871] (**) Option "xkb_variant" ","
[ 8.871] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 8.873] (II) event15 - SINO WEALTH USB KEYBOARD System Control: is tagged by udev as: Keyboard
[ 8.873] (II) event15 - SINO WEALTH USB KEYBOARD System Control: device is a keyboard
[ 8.874] (II) config/udev: Adding input device SINO WEALTH USB KEYBOARD Consumer Control (/dev/input/event16)
[ 8.874] (**) SINO WEALTH USB KEYBOARD Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 8.874] (**) SINO WEALTH USB KEYBOARD Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 8.874] (**) SINO WEALTH USB KEYBOARD Consumer Control: Applying InputClass "system-keyboard"
[ 8.874] (**) SINO WEALTH USB KEYBOARD Consumer Control: Applying InputClass "Keyboard Defaults"
[ 8.874] (II) Using input driver 'libinput' for 'SINO WEALTH USB KEYBOARD Consumer Control'
[ 8.875] (II) systemd-logind: got fd for /dev/input/event16 13:80 fd 43 paused 0
[ 8.875] (**) SINO WEALTH USB KEYBOARD Consumer Control: always reports core events
[ 8.875] (**) Option "Device" "/dev/input/event16"
[ 8.876] (**) Option "_source" "server/udev"
[ 8.877] (II) event16 - SINO WEALTH USB KEYBOARD Consumer Control: is tagged by udev as: Keyboard
[ 8.878] (II) event16 - SINO WEALTH USB KEYBOARD Consumer Control: device is a keyboard
[ 8.878] (II) event16 - SINO WEALTH USB KEYBOARD Consumer Control: device removed
[ 8.878] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5.3/2-1.5.3:1.1/0003:258A:0001.0004/input/input16/event16"
[ 8.878] (II) XINPUT: Adding extended input device "SINO WEALTH USB KEYBOARD Consumer Control" (type: KEYBOARD, id 13)
[ 8.878] (**) Option "xkb_layout" "us,ir"
[ 8.878] (**) Option "xkb_variant" ","
[ 8.878] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 8.880] (II) event16 - SINO WEALTH USB KEYBOARD Consumer Control: is tagged by udev as: Keyboard
[ 8.880] (II) event16 - SINO WEALTH USB KEYBOARD Consumer Control: device is a keyboard
[ 8.880] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[ 8.880] (II) No input driver specified, ignoring this device.
[ 8.880] (II) This device may have been added with another device file.
[ 8.885] (**) MOSART Semi. Wireless Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 8.885] (**) MOSART Semi. Wireless Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 8.885] (**) MOSART Semi. Wireless Mouse Consumer Control: Applying InputClass "system-keyboard"
[ 8.885] (**) MOSART Semi. Wireless Mouse Consumer Control: Applying InputClass "Keyboard Defaults"
[ 8.885] (II) Using input driver 'libinput' for 'MOSART Semi. Wireless Mouse Consumer Control'
[ 8.885] (II) systemd-logind: returning pre-existing fd for /dev/input/event11 13:75
[ 8.885] (**) MOSART Semi. Wireless Mouse Consumer Control: always reports core events
[ 8.885] (**) Option "Device" "/dev/input/event11"
[ 8.885] (**) Option "_source" "_driver/libinput"
[ 8.885] (II) libinput: MOSART Semi. Wireless Mouse Consumer Control: is a virtual subdevice
[ 8.885] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5.1/2-1.5.1:1.1/0003:0458:0185.0002/input/input11/event11"
[ 8.885] (II) XINPUT: Adding extended input device "MOSART Semi. Wireless Mouse Consumer Control" (type: KEYBOARD, id 14)
[ 8.885] (**) Option "xkb_layout" "us,ir"
[ 8.885] (**) Option "xkb_variant" ","
[ 8.885] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 8.887] (II) config/udev: removing device SINO WEALTH USB KEYBOARD System Control
[ 8.887] (**) Option "fd" "42"
[ 8.887] (II) event15 - SINO WEALTH USB KEYBOARD System Control: device removed
[ 8.887] (II) UnloadModule: "libinput"
[ 8.887] (II) systemd-logind: releasing fd for 13:79
[ 8.895] (II) config/udev: Adding input device SINO WEALTH USB KEYBOARD System Control (/dev/input/event15)
[ 8.895] (**) SINO WEALTH USB KEYBOARD System Control: Applying InputClass "evdev keyboard catchall"
[ 8.896] (**) SINO WEALTH USB KEYBOARD System Control: Applying InputClass "libinput keyboard catchall"
[ 8.896] (**) SINO WEALTH USB KEYBOARD System Control: Applying InputClass "system-keyboard"
[ 8.896] (**) SINO WEALTH USB KEYBOARD System Control: Applying InputClass "Keyboard Defaults"
[ 8.896] (II) Using input driver 'libinput' for 'SINO WEALTH USB KEYBOARD System Control'
[ 8.897] (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 36 paused 0
[ 8.897] (**) SINO WEALTH USB KEYBOARD System Control: always reports core events
[ 8.897] (**) Option "Device" "/dev/input/event15"
[ 8.897] (**) Option "_source" "server/udev"
[ 8.899] (II) event15 - SINO WEALTH USB KEYBOARD System Control: is tagged by udev as: Keyboard
[ 8.899] (II) event15 - SINO WEALTH USB KEYBOARD System Control: device is a keyboard
[ 8.899] (II) event15 - SINO WEALTH USB KEYBOARD System Control: device removed
[ 8.899] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5.3/2-1.5.3:1.1/0003:258A:0001.0004/input/input15/event15"
[ 8.899] (II) XINPUT: Adding extended input device "SINO WEALTH USB KEYBOARD System Control" (type: KEYBOARD, id 12)
[ 8.899] (**) Option "xkb_layout" "us,ir"
[ 8.899] (**) Option "xkb_variant" ","
[ 8.899] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 8.901] (II) event15 - SINO WEALTH USB KEYBOARD System Control: is tagged by udev as: Keyboard
[ 8.901] (II) event15 - SINO WEALTH USB KEYBOARD System Control: device is a keyboard
[ 8.901] (II) config/udev: removing device SINO WEALTH USB KEYBOARD
[ 8.902] (**) Option "fd" "41"
[ 8.902] (II) event14 - SINO WEALTH USB KEYBOARD: device removed
[ 8.902] (II) UnloadModule: "libinput"
[ 8.902] (II) systemd-logind: releasing fd for 13:78
[ 8.905] (II) config/udev: Adding input device SINO WEALTH USB KEYBOARD (/dev/input/event14)
[ 8.905] (**) SINO WEALTH USB KEYBOARD: Applying InputClass "evdev keyboard catchall"
[ 8.906] (**) SINO WEALTH USB KEYBOARD: Applying InputClass "libinput keyboard catchall"
[ 8.906] (**) SINO WEALTH USB KEYBOARD: Applying InputClass "system-keyboard"
[ 8.906] (**) SINO WEALTH USB KEYBOARD: Applying InputClass "Keyboard Defaults"
[ 8.906] (II) Using input driver 'libinput' for 'SINO WEALTH USB KEYBOARD'
[ 8.907] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 41 paused 0
[ 8.908] (**) SINO WEALTH USB KEYBOARD: always reports core events
[ 8.908] (**) Option "Device" "/dev/input/event14"
[ 8.908] (**) Option "_source" "server/udev"
[ 8.911] (II) event14 - SINO WEALTH USB KEYBOARD: is tagged by udev as: Keyboard
[ 8.911] (II) event14 - SINO WEALTH USB KEYBOARD: device is a keyboard
[ 8.911] (II) event14 - SINO WEALTH USB KEYBOARD: device removed
[ 8.911] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5.3/2-1.5.3:1.0/0003:258A:0001.0003/input/input14/event14"
[ 8.911] (II) XINPUT: Adding extended input device "SINO WEALTH USB KEYBOARD" (type: KEYBOARD, id 11)
[ 8.911] (**) Option "xkb_layout" "us,ir"
[ 8.911] (**) Option "xkb_variant" ","
[ 8.912] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 8.914] (II) event14 - SINO WEALTH USB KEYBOARD: is tagged by udev as: Keyboard
[ 8.914] (II) event14 - SINO WEALTH USB KEYBOARD: device is a keyboard
[ 8.914] (II) config/udev: removing device MOSART Semi. Wireless Mouse System Control
[ 8.914] (**) Option "fd" "40"
[ 8.915] (II) event12 - MOSART Semi. Wireless Mouse System Control: device removed
[ 8.915] (II) UnloadModule: "libinput"
[ 8.915] (II) systemd-logind: releasing fd for 13:76
[ 8.919] (II) config/udev: Adding input device MOSART Semi. Wireless Mouse System Control (/dev/input/event12)
[ 8.919] (**) MOSART Semi. Wireless Mouse System Control: Applying InputClass "evdev keyboard catchall"
[ 8.919] (**) MOSART Semi. Wireless Mouse System Control: Applying InputClass "libinput keyboard catchall"
[ 8.919] (**) MOSART Semi. Wireless Mouse System Control: Applying InputClass "system-keyboard"
[ 8.919] (**) MOSART Semi. Wireless Mouse System Control: Applying InputClass "Keyboard Defaults"
[ 8.919] (II) Using input driver 'libinput' for 'MOSART Semi. Wireless Mouse System Control'
[ 8.921] (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 40 paused 0
[ 8.921] (**) MOSART Semi. Wireless Mouse System Control: always reports core events
[ 8.921] (**) Option "Device" "/dev/input/event12"
[ 8.921] (**) Option "_source" "server/udev"
[ 8.922] (II) event12 - MOSART Semi. Wireless Mouse System Control: is tagged by udev as: Keyboard
[ 8.922] (II) event12 - MOSART Semi. Wireless Mouse System Control: device is a keyboard
[ 8.923] (II) event12 - MOSART Semi. Wireless Mouse System Control: device removed
[ 8.923] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5.1/2-1.5.1:1.1/0003:0458:0185.0002/input/input12/event12"
[ 8.923] (II) XINPUT: Adding extended input device "MOSART Semi. Wireless Mouse System Control" (type: KEYBOARD, id 10)
[ 8.923] (**) Option "xkb_layout" "us,ir"
[ 8.923] (**) Option "xkb_variant" ","
[ 8.923] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 8.925] (II) event12 - MOSART Semi. Wireless Mouse System Control: is tagged by udev as: Keyboard
[ 8.925] (II) event12 - MOSART Semi. Wireless Mouse System Control: device is a keyboard
[ 8.925] (II) config/udev: removing device SINO WEALTH USB KEYBOARD Consumer Control
[ 8.925] (**) Option "fd" "43"
[ 8.925] (II) event16 - SINO WEALTH USB KEYBOARD Consumer Control: device removed
[ 8.925] (II) UnloadModule: "libinput"
[ 8.925] (II) systemd-logind: releasing fd for 13:80
[ 8.962] (II) config/udev: Adding input device SINO WEALTH USB KEYBOARD Consumer Control (/dev/input/event16)
[ 8.962] (**) SINO WEALTH USB KEYBOARD Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 8.962] (**) SINO WEALTH USB KEYBOARD Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 8.962] (**) SINO WEALTH USB KEYBOARD Consumer Control: Applying InputClass "system-keyboard"
[ 8.962] (**) SINO WEALTH USB KEYBOARD Consumer Control: Applying InputClass "Keyboard Defaults"
[ 8.962] (II) Using input driver 'libinput' for 'SINO WEALTH USB KEYBOARD Consumer Control'
[ 8.964] (II) systemd-logind: got fd for /dev/input/event16 13:80 fd 42 paused 0
[ 8.964] (**) SINO WEALTH USB KEYBOARD Consumer Control: always reports core events
[ 8.964] (**) Option "Device" "/dev/input/event16"
[ 8.964] (**) Option "_source" "server/udev"
[ 8.967] (II) event16 - SINO WEALTH USB KEYBOARD Consumer Control: is tagged by udev as: Keyboard
[ 8.968] (II) event16 - SINO WEALTH USB KEYBOARD Consumer Control: device is a keyboard
[ 8.968] (II) event16 - SINO WEALTH USB KEYBOARD Consumer Control: device removed
[ 8.968] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5.3/2-1.5.3:1.1/0003:258A:0001.0004/input/input16/event16"
[ 8.968] (II) XINPUT: Adding extended input device "SINO WEALTH USB KEYBOARD Consumer Control" (type: KEYBOARD, id 13)
[ 8.968] (**) Option "xkb_layout" "us,ir"
[ 8.968] (**) Option "xkb_variant" ","
[ 8.968] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 8.971] (II) event16 - SINO WEALTH USB KEYBOARD Consumer Control: is tagged by udev as: Keyboard
[ 8.971] (II) event16 - SINO WEALTH USB KEYBOARD Consumer Control: device is a keyboard
[ 8.972] (II) config/udev: removing device MOSART Semi. Wireless Mouse
[ 8.972] (**) Option "fd" "38"
[ 8.972] (II) event10 - MOSART Semi. Wireless Mouse: device removed
[ 8.972] (II) UnloadModule: "libinput"
[ 8.972] (II) systemd-logind: releasing fd for 13:74
[ 8.999] (II) config/udev: Adding input device MOSART Semi. Wireless Mouse (/dev/input/event10)
[ 8.999] (**) MOSART Semi. Wireless Mouse: Applying InputClass "evdev pointer catchall"
[ 8.999] (**) MOSART Semi. Wireless Mouse: Applying InputClass "libinput pointer catchall"
[ 9.000] (II) Using input driver 'libinput' for 'MOSART Semi. Wireless Mouse'
[ 9.002] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 38 paused 0
[ 9.002] (**) MOSART Semi. Wireless Mouse: always reports core events
[ 9.002] (**) Option "Device" "/dev/input/event10"
[ 9.002] (**) Option "_source" "server/udev"
[ 9.005] (II) event10 - MOSART Semi. Wireless Mouse: is tagged by udev as: Mouse
[ 9.005] (II) event10 - MOSART Semi. Wireless Mouse: device is a pointer
[ 9.006] (II) event10 - MOSART Semi. Wireless Mouse: device removed
[ 9.006] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5.1/2-1.5.1:1.1/0003:0458:0185.0002/input/input10/event10"
[ 9.006] (II) XINPUT: Adding extended input device "MOSART Semi. Wireless Mouse" (type: MOUSE, id 8)
[ 9.006] (**) Option "AccelerationScheme" "none"
[ 9.006] (**) MOSART Semi. Wireless Mouse: (accel) selected scheme none/0
[ 9.006] (**) MOSART Semi. Wireless Mouse: (accel) acceleration factor: 2.000
[ 9.006] (**) MOSART Semi. Wireless Mouse: (accel) acceleration threshold: 4
[ 9.008] (II) event10 - MOSART Semi. Wireless Mouse: is tagged by udev as: Mouse
[ 9.009] (II) event10 - MOSART Semi. Wireless Mouse: device is a pointer
[ 9.009] (II) config/udev: Adding input device MOSART Semi. Wireless Mouse (/dev/input/event13)
[ 9.009] (II) No input driver specified, ignoring this device.
[ 9.009] (II) This device may have been added with another device file.
[ 9.010] (II) config/udev: removing device MOSART Semi. Wireless Mouse Consumer Control
[ 9.010] (**) Option "fd" "39"
[ 9.010] (II) UnloadModule: "libinput"
[ 9.010] (II) systemd-logind: not releasing fd for 13:75, still in use
[ 9.010] (II) event11 - MOSART Semi. Wireless Mouse Consumer Control: device removed
[ 9.010] (II) systemd-logind: releasing fd for 13:75
[ 9.025] (II) config/udev: Adding input device MOSART Semi. Wireless Mouse Consumer Control (/dev/input/event11)
[ 9.025] (**) MOSART Semi. Wireless Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 9.026] (**) MOSART Semi. Wireless Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 9.026] (**) MOSART Semi. Wireless Mouse Consumer Control: Applying InputClass "system-keyboard"
[ 9.026] (**) MOSART Semi. Wireless Mouse Consumer Control: Applying InputClass "Keyboard Defaults"
[ 9.026] (II) Using input driver 'libinput' for 'MOSART Semi. Wireless Mouse Consumer Control'
[ 9.027] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 39 paused 0
[ 9.027] (**) MOSART Semi. Wireless Mouse Consumer Control: always reports core events
[ 9.027] (**) Option "Device" "/dev/input/event11"
[ 9.028] (**) Option "_source" "server/udev"
[ 9.030] (II) event11 - MOSART Semi. Wireless Mouse Consumer Control: is tagged by udev as: Keyboard
[ 9.030] (II) event11 - MOSART Semi. Wireless Mouse Consumer Control: device is a keyboard
[ 9.030] (II) event11 - MOSART Semi. Wireless Mouse Consumer Control: device removed
[ 9.030] (II) libinput: MOSART Semi. Wireless Mouse Consumer Control: needs a virtual subdevice
[ 9.030] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5.1/2-1.5.1:1.1/0003:0458:0185.0002/input/input11/event11"
[ 9.030] (II) XINPUT: Adding extended input device "MOSART Semi. Wireless Mouse Consumer Control" (type: MOUSE, id 9)
[ 9.030] (**) Option "AccelerationScheme" "none"
[ 9.031] (**) MOSART Semi. Wireless Mouse Consumer Control: (accel) selected scheme none/0
[ 9.031] (**) MOSART Semi. Wireless Mouse Consumer Control: (accel) acceleration factor: 2.000
[ 9.031] (**) MOSART Semi. Wireless Mouse Consumer Control: (accel) acceleration threshold: 4
[ 9.033] (II) event11 - MOSART Semi. Wireless Mouse Consumer Control: is tagged by udev as: Keyboard
[ 9.033] (II) event11 - MOSART Semi. Wireless Mouse Consumer Control: device is a keyboard
[ 9.033] (**) MOSART Semi. Wireless Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 9.033] (**) MOSART Semi. Wireless Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 9.033] (**) MOSART Semi. Wireless Mouse Consumer Control: Applying InputClass "system-keyboard"
[ 9.033] (**) MOSART Semi. Wireless Mouse Consumer Control: Applying InputClass "Keyboard Defaults"
[ 9.033] (II) Using input driver 'libinput' for 'MOSART Semi. Wireless Mouse Consumer Control'
[ 9.034] (II) systemd-logind: returning pre-existing fd for /dev/input/event11 13:75
[ 9.034] (**) MOSART Semi. Wireless Mouse Consumer Control: always reports core events
[ 9.034] (**) Option "Device" "/dev/input/event11"
[ 9.034] (**) Option "_source" "_driver/libinput"
[ 9.034] (II) libinput: MOSART Semi. Wireless Mouse Consumer Control: is a virtual subdevice
[ 9.034] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5.1/2-1.5.1:1.1/0003:0458:0185.0002/input/input11/event11"
[ 9.034] (II) XINPUT: Adding extended input device "MOSART Semi. Wireless Mouse Consumer Control" (type: KEYBOARD, id 14)
[ 9.034] (**) Option "xkb_layout" "us,ir"
[ 9.034] (**) Option "xkb_variant" ","
[ 9.034] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 9.035] (II) config/udev: Adding input device MOSART Semi. Wireless Mouse (/dev/input/mouse0)
[ 9.035] (II) No input driver specified, ignoring this device.
[ 9.035] (II) This device may have been added with another device file.
[ 9.531] (--) NVIDIA(GPU-0): Samsung SMB1930N (CRT-0): connected
[ 9.531] (--) NVIDIA(GPU-0): Samsung SMB1930N (CRT-0): 400.0 MHz maximum pixel clock
[ 9.531] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 9.531] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 9.531] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 9.532] (--) NVIDIA(GPU-0):
[ 9.532] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 9.532] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 9.532] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 16.974] (**) Option "fd" "34"
[ 16.974] (II) event1 - Power Button: device removed
[ 16.975] (**) Option "fd" "37"
[ 16.975] (II) event0 - Power Button: device removed
[ 16.975] (**) Option "fd" "36"
[ 16.975] (II) event15 - SINO WEALTH USB KEYBOARD System Control: device removed
[ 16.975] (**) Option "fd" "41"
[ 16.975] (II) event14 - SINO WEALTH USB KEYBOARD: device removed
[ 16.975] (**) Option "fd" "40"
[ 16.975] (II) event12 - MOSART Semi. Wireless Mouse System Control: device removed
[ 16.975] (**) Option "fd" "42"
[ 16.975] (II) event16 - SINO WEALTH USB KEYBOARD Consumer Control: device removed
[ 16.976] (**) Option "fd" "38"
[ 16.976] (II) event10 - MOSART Semi. Wireless Mouse: device removed
[ 16.976] (**) Option "fd" "39"
[ 16.976] (II) event11 - MOSART Semi. Wireless Mouse Consumer Control: device removed
[ 17.062] (II) systemd-logind: got pause for 13:74
[ 17.062] (II) systemd-logind: got pause for 13:78
[ 17.062] (II) systemd-logind: got pause for 13:65
[ 17.062] (II) systemd-logind: got pause for 13:76
[ 17.062] (II) systemd-logind: got pause for 13:64
[ 17.062] (II) systemd-logind: got pause for 13:80
[ 17.062] (II) systemd-logind: got pause for 13:79
[ 17.062] (II) systemd-logind: got pause for 13:75
[ 23.458] (II) UnloadModule: "libinput"
[ 23.459] (II) systemd-logind: not releasing fd for 13:75, still in use
[ 23.459] (II) UnloadModule: "libinput"
[ 23.460] (II) systemd-logind: releasing fd for 13:75
[ 23.477] (II) UnloadModule: "libinput"
[ 23.477] (II) systemd-logind: releasing fd for 13:74
[ 23.493] (II) UnloadModule: "libinput"
[ 23.494] (II) systemd-logind: releasing fd for 13:80
[ 23.506] (II) UnloadModule: "libinput"
[ 23.506] (II) systemd-logind: releasing fd for 13:76
[ 23.521] (II) UnloadModule: "libinput"
[ 23.521] (II) systemd-logind: releasing fd for 13:78
[ 23.527] (II) UnloadModule: "libinput"
[ 23.527] (II) systemd-logind: releasing fd for 13:79
[ 23.538] (II) UnloadModule: "libinput"
[ 23.539] (II) systemd-logind: releasing fd for 13:64
[ 23.555] (II) UnloadModule: "libinput"
[ 23.556] (II) systemd-logind: releasing fd for 13:65
[ 23.598] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 23.605] (II) Server terminated successfully (0). Closing log file.
