when I try to open Qt designer in the menu, it came out thar error. Then I tried to open it in pycharm it report “Error running ‘Py Qt Designer’: Cannot run program “/usr/bin/designer” (in directory “/run/media/bran/TOSHIBA EXT/Code/PycharmProj/MM1”): error=2, …”. Then I go to the “/usr/bin/designer” dir, can’t find the designer. But IT WAS FINE yesterday, so confused.
Sorry for my bad English:(
this file is installed by qt5-tools
package
verify by pacman -Qo /usr/bin/designer
- if file not exists then re-install this package
THANKS for your help I did removed the qt5-tools for some reason that I read from another blog.
