Is there code for the CLI that will allow me to install this?
Wait for the stable update and it will come to you when you update your system.
I was wanting to test it out
If you want to be part of the testing community, you should switch to testing branch.
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
That should get you switched and updated.
Excellent Thank you!
In addition to the above, there’s a nifty tool to keep track of packages:
- type “plasma-desktop” in the search at Manjaro’s Branch Compare.
Also you can follow progress via this forum by watching the Announcements category.
These Forums/Categories have RSS Feeds too.
