plank hide issue
#1
i did a clean install of manjaro kde 18.0.4 - updates are installed, now comes the fine tuning part.
unfortunately, a few things don't work as expected anymore.
plank & autohide (my preferred setup): still works, but clicking on icons has no effect at all (won't open programs anymore)?
with preferences on strg+right mbutton it is just about the same, now it needs to be triggered from the konsole in order to show up: plank --preferences
switching to intellyhide seems a workaround (icons are clickable), as long as no application is opened maximized, then its behaviour is exactly the same: no effect on clicking icons after unhiding the dock anymore.
any clues are very welcome.
#2
nevermind - got it sorted.
when using hide-delay 50+, all is back to normal just as before.
#3
Curious as to why you use Plank instead of Latte-Dock?
#4
latte is great though not so ressource-friendly - and plank (and its bugs) is just fine for me.
#5
While Latte is quite an accomplished app, I personally use plank instead since I find its animations far smoother than Latte, and I find its autohide and appearance animations just a tad more instantaneous...
every now and then i give latte a try. i was disappointed to see the recent version eating up memory like never before.
a latte-light version with a limited feature-set (!?) but a plank-wise memory consumption would be very nice to have.
