There is horizontal line that appears to divide the screen sometimes especially during videos. I am guessing it is an issue with frame rates because for normal static use of computer, this doesn’t happen. So mostly when playing a video, this line appears. I can’t take a screenshot because it’s not permanent and while pausing it disappears. I have a dual boot with windows as well, there this issue doesnt occur. I think it’s an issue with display drivers. Attaching images of display drivers. PLease help. I use Manjaro 21.1.5 with i3wm. I have installed propreitary drivers from nvidia
>> glxinfo | grep OpenGL
OpenGL vendor string: Intel
OpenGL renderer string: Mesa Intel(R) UHD Graphics 630 (CFL GT2)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 21.2.3
OpenGL core profile shading language version string: 4.60
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.6 (Compatibility Profile) Mesa 21.2.3
OpenGL shading language version string: 4.60
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 21.2.3
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
