use sudo in linux command script in mnajaro
i wrote a small script but was not able to open files from other harddrive partion
So wanted to change the script i tried sudo but i dont want to put pasword
I am using it for eagle program
#!/bin/bash
cd /home/swaraj/Downloads/eagle-9.6.2
echo “i am in eagle folder”
Hello raavan,
In the terminal, I was abe to change the environment variable without sudo.
[julius@Pinebook ~]$ QT_XCB_GL_INTEGRATION=xcb_egl
it seems to me that your file .eagle might not be executable.
try sudo chmod +x ~/Downloads/eagle-9.6.2/eagle in a terminal.
This will allow the user to execute the file.
Best Regards, Julius
[quote=“julius-gu, post:3, topic:9360”]
[/quote] eagle is executable file when i run it gives me sandbox error
and the changes that u said didnt work
and i wanna ask whats wrong with manjaro forom i hate it
could you please post the error that it gives you?
are you referring to the QT_XCB_GL_INTEGRATION=xcb_egl?
there was a problem with something like a botched update on their server and as a result the forum was in such a mess that they wanted to start from scratch. The forum team wanted to change a few things and as far as I know, the way the forum is at the moment is not final. I would recommend being patient.
note that you can still access the old stuff by putting archived. in from of the forum in the adress bar.
Dont know about ‘eagle’ itself … but that script is certainly broken.
(and you really dont want to be using sudo in your home)
And the complaint isnt about sandbox … thats just information.
The complaint is it cant find this file
So again … thats back to your script, how you installed/configured eagle, or eagle itself.
