Pipewire Microphone issues
Good day,
got the following problem since switching to 6.5.1-1
  • My microphone (rode podcaster usb) is randomly stopped being recorded. The Input in the OS still works but I can’t get any mic input into any software other than easy effects.
  • Very rarely the audio starts crackling.
Since switching to manjaro I had nothing but issues with microphone input and I cant nail it down to anything. Any help would be appreciated
  Kernel: 6.5.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
    root=UUID=7ce1b6e7-d7af-4c30-883a-1270de5dd75a rw quiet apparmor=1
  Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Desktop System: Gigabyte product: X470 AORUS ULTRA GAMING v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: X470 AORUS ULTRA GAMING-CF
    serial: <superuser required> UEFI: American Megatrends LLC. v: F63c
    date: 07/20/2022
  Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB
    desc: 1x32 MiB
  Speed (MHz): avg: 3505 high: 4833 min/max: 2200/4850 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3684 2: 2925
    3: 3761 4: 3685 5: 3492 6: 3036 7: 3629 8: 3711 9: 3866 10: 3035 11: 3826
    12: 3649 13: 3007 14: 2965 15: 2988 16: 4833 bogomips: 121654
  Type: spec_rstack_overflow mitigation: safe RET, no microcode
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Micro-Star MSI
    driver: nvidia v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-08) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.0 chip-ID: 10de:2484
    class-ID: 0300
  Device-2: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10:4 chip-ID: 046d:0825
    class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.70x13.50")
    s-diag: 693mm (27.28")
  Monitor-1: Unknown-1 mapped: HDMI-0 res: 1920x1080 dpi: 82
    size: 598x336mm (23.54x13.23") modes: 1024x768
  API: OpenGL v: 4.6.0 NVIDIA 535.104.05 renderer: NVIDIA GeForce RTX
    3070/PCIe/SSE2 direct-render: Yes
  Device-1: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
    link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.1 chip-ID: 10de:228b
    class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
    bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
  Device-4: RODE Microphones Podcaster v2
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 5-4:3 chip-ID: 19f7:0008 class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.5.1-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:3
    chip-ID: 0a12:0001 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0
    lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c0104
  Local Storage: total: 4.09 TiB used: 1.3 TiB (31.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: MP400
    lanes: 4 tech: SSD serial: <filter> fw-rev: ECFM53.0 temp: 42.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 970 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 40.9 C
  ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000BX500SSD1
    tech: SSD serial: <filter> fw-rev: 056 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DX002-2DV164
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC41 scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 916.04 GiB (98.37%)
    used: 164.47 GiB (18.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
    used: 304 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  System Temperatures: cpu: 63.2 C mobo: 41.0 C gpu: nvidia temp: 56 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 0 fan-3: 0 gpu: nvidia fan: 0%
  Power: 12v: N/A 5v: N/A 3.3v: 3.36 vbat: 2.96
  Processes: 361 Uptime: 2h 38m wakeups: 0 Memory: total: 32 GiB
  available: 31.26 GiB used: 7.36 GiB (23.6%) Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 11/12
  clang: 16.0.6 Packages: 1979 pm: pacman pkgs: 1964 libs: 495 tools: pamac,yay
  pm: flatpak pkgs: 12 pm: snap pkgs: 3 Shell: Zsh v: 5.9 default: Bash
  v: 5.1.16 running-in: konsole inxi: 3.3.29
Welcome.
Did you try an LTS kernel like 6.1?
Switching kernels is pretty easy on Manjaro:
Yeah I did. I migrated from LTS 6.1 because I had the same issue.
Quick update: I fixed the audio crackling issue. But I am not sure about the microphone. Needs further testing
