I have the PinePhone connected to an usb-c dock to be able to control it with a wireless logiteck K400 keyboard.
I want to flash the PinePhone from an USB stick attached.
If I boot the phone with this stick attached the Pine attempts to boot from the stick as the stick is seen as /dev/sda but of course the boot fail. The stick a bootable usb with a grub bootloader - intended for multiboot.
Note:
Default pin code for Manjaro PinePhone editions
123456
Note:
The mainline version of python-pyqt5
does not work. As per advise from @Strit in another place you need to install python-es2-pyqt5
and after that you need to reinstall manjaro-arm-flasher
Selecting a image to download leads to an 404 Not Found message for the images.
Note:
Lomiri edition
In the flasher it is not possible to navigate to attached USB stick.
The stick is available as sda - but trying to mount it from terminal asks for password which is hard to get accepted - maybe it is locked by a desktop timeout?
