Pinebook Pro USB-C dock with HDMI. No Display
Using a USB-C dock with a new pinebook. The other ports on the hub function. However there is no HDMI output.
When examining the "display configuration" GUI window (KDE) there is a second window called "DP-1" when the dock is plugged in, irregardless of whether a HDMI is plugged in or not.
When inserting the USB-C cable the other way around, the Display Configuration does not show any extra monitors irregardless of HDMI. It does not display the "DP-1" window in this case either.
HDMI on the USB-C dock works when connected to other devices
Hello and welcome to the community,
Can you share the model of your dock?
Afaik, not sure of all types of dock work out of the box, but the one I have works fine, mine is cheap unbranded chinese all in one type c dock.
This one.
Thanks for the reply. An amazon link to the product.
I have the exact same problem (Pinebook Pro, Manjaro ARM KDE, same symptoms) with the following usb c dock:
@coolmule0 - any luck on finding a solution since posting?
