My PBP was reinstalled with fresh Manjaro distro 2 hours ago via manjaro flasher. After it PBP started to main OS screen with amber LED color, but in process it was this message with:
htt ps://i.ibb.co/QnXvGmX/2.jpg (remove space character after htt)
Also, it was with blinking at the bottom of the screen. Previuos version of Manjaro, when PBP just arrived, had not this artifacts and text. Is this normal? How to fix it? Why LED is amber?
By the way, I have a problem with boot from cd, I need to stop this screen, type "boot’ and after it OS at SD card starts (but not always).
if load ${devtype} ${devnum}:${bootpart} ${kernel_addr_r} /boot/Image; then
if load ${devtype} ${devnum}:${bootpart} ${fdt_addr_r} /boot/${fdtfile}; then
fdt addr ${fdt_addr_r}
fdt resize
fdt set /ethernet@fe300000 local-mac-address “[${macaddr}]”
if load ${devtype} ${devnum}:${bootpart} ${ramdisk_addr_r} /boot/initramfs-linux.img; then
# This upstream Uboot doesn’t support compresses cpio initrd, use kernel option to
# load initramfs
setenv bootargs ${bootargs} initrd=${ramdisk_addr_r},20M ramdisk_size=10M
fi;
booti ${kernel_addr_r} - ${fdt_addr_r};
fi;
fi
