Pinebook kernel compile howto?
#1
Hi, I have a pinebook and I would to know how to compile my own kernel, but I have two problems:
1- I don’t know entire process to compile kernel for arm. I only did on x86 before. For example, U-boot and more stuff… I don’t have enough knowledge and resources for learn it.
2- Specific compile kernel method on Arch Linux, i’m n00b with is distro but I have strong experience on linux/bsd systems.
Any tips or advices please?
#2
Manjaro ARM uses this kernel for the pinebook.
It’s compiled by cloning that repo on your Pinebook, cd into the folder and then running makepkg -sc.
Our kernel is a slightly modified version of anarsouls kernel.
Why would you want to compile your own kernel, btw?
#3
Thanks for the info XD
KVM enable.
All test I did show not enable ;(
I don’t know if is enable by default.
If not, I would like to compile to do it.
#4
I’m not sure it’s possible to use Virtualization on ARM…
You are welcome to try it out though.
#5
Trying it with your recomendations and https://wiki.archlinux.org/index.php/Kernel/Arch_Build_System
:stuck_out_tongue:
#6
It will ofcourse only work, if you build it on the device itself. :slight_smile:
#7
While pinebook was compiling kernel y see that is enable by default with current one… :stuck_out_tongue_winking_eye:
manjaro@archlinux  ~  zgrep CONFIG_KVM /proc/config.gz
CONFIG_KVM_MMIO=y
CONFIG_KVM_VFIO=y
CONFIG_KVM_GENERIC_DIRTYLOG_READ_PROTECT=y
CONFIG_KVM=y
CONFIG_KVM_ARM_HOST=y
CONFIG_KVM_ARM_PMU=y
CONFIG_KVM_INDIRECT_VECTORS=y
But I want to know kernel compiling process anyway :stuck_out_tongue:
#8
Happy compiling. :stuck_out_tongue:
#9
I don’t know if to make a grub env like x86 is possible on arm
I don’t want to make my system unbootable
any tips or suggestions?
#10
Grub will not work on ARM.
ARM boards use special bootloaders. Most of them is some sort of uboot.
Using anything else, will result in a non-booting system.
#11
Why a tested kernel isn’t on official manjaro arm repo?
Where I can ask for this feature?
I can do my own kernel, but will be great all users can get it.
#12
What tested Arch Linux ARM kernel are you referring to?
#13
enabling KVM on 4.20.0-1-MANJARO-ARM
I create it but I don’t test because I don’t know how to configure uboot correctly to start.
I don’t want to break laptop with a corrupt kernel boot and reinstall system.
#14
Just use the uboot already on the Manjaro ARM image. Or does KVM require a specific uboot too?
#15
It is possible :slight_smile: https://twitter.com/astr0baby/status/1085655477839482880
#16
Yep, I read these post before and for this reason I would like to enable KVM on my pinebook using manjaro.
I don’t want to use sd card every time I want to test a different distro for pinebook :stuck_out_tongue_winking_eye:
