So I configured Fusuma to let me use pinching for zooming. However, it doesn’t seem like pinching on the touchpad itself is recognised by the system. How do I go about fixing this?
For reference, I’m using KDE Plasma.
Is fusuma up and running?
How looks your ~/.config/fusuma/config.yml ?
Mine looks like:
pinch:
2:
in:
sendkey: LEFTCTRL+KPPLUS # Zoom in
out:
sendkey: LEFTCTRL+KPMINUS # Zoom out
threshold:
swipe: 0.5
pinch: 0.2
interval:
swipe: 0.2
pinch: 0.6
plugin:
inputs:
libinput_command_input: # options for lib/plugin/inputs/libinput_command_input
enable-tap: true # click to tap
enable-dwt: true # disable tap while typing
show-keycodes: true # https://github.com/iberianpig/fusuma-plugin-keypress#add-show-keycode-option
I’m using KDE Plasma, too, and it works fine for me.
Yes it is. Here’s my file.
swipe:
3:
left:
sendkey: 'LEFTALT+TAB'
right:
sendkey: 'LEFTALT+LEFTSHIFT+TAB'
up:
window:
maximized: add
down:
window:
maximized: remove
4:
left:
workspace: 'next'
right:
workspace: 'prev'
up:
window:
fullscreen: add
down:
window:
fullscreen: remove
pinch:
in:
sendkey: 'LEFTCTRL+KPPLUS'
out:
sendkey: 'LEFTCTRL+KPMINUS'
threshold:
swipe: 0.5
pinch: 0.2
interval:
swipe: 0.2
pinch: 0.6
I dual boot with windows and can confirm that the touchpad itself is just fine.
UPDATE: Okay so it works, but it’s kinda hard to get it to work. It’s usually confuses it all with scrolling with 2 fingers, and when I actually get it to work it’s a bit too sensitive. What to do?
Also might as well ask, is there a way I can make it so that if I swipe down on a restored window it minimizes and if I swipe up on a minimized window it first restores it?
