Hi!
So i’m using manjaro with the qtile WM, and everything is working fine except for when I try setting a compositor. At first when i ran it from dmenu it would start fine until i restarted ofcourse, so i created a .sh script assosiated with the qtile config file, and from that time I don’t seem to be able to get the compositor running, even when trying to run it from the command line.
Here is the .sh script:
#!/bin/sh
pidgin &
dropbox start &
picom &
The Qtile config.py script:
@hook.subscribe.startup
def autostart():
Do the other two programs start correctly?
Can you start picom
from the terminal?
My command to start picom is:
picom \
--daemon \
--experimental-backends \
--backend glx \
--config ~/.config/picom.conf
(So with additional arguments like the path to the config file.)
Just a guess…try using it with -b
argument as I do in my dwm install:
# start compositor
picom -b &
picom -h
-b
Daemonize process.
I don’t really know… I didn’t even put them there tbh.
Can you start picom from the terminal?
When I type “picom” in the terminal it seems like it starts fine, i guess. I hit enter and I get no errors, but when i try searching for it in htop it don’t see it.
I did try your script. Still nothing. I haven’t changed the config file of picom at all. Im pretty sure im doing something wrong here…
I have also tried that with no luck
Is your script executable? If not then make it executable and try running it from the terminal:
chmod +x ./path_to_script
./path_to_script &
I believe it already was, but i did it anyway.
I ran the script and i still don’t see picom running.
What exactly happens if you start picom
from the terminal?
I’m posting a screenshot because i don’t know how to explain it.
Excuse the name too!
Did you figure anything out by the screenshot?
So, I guess it’s running. However, probably you need a config file or some kind of configuration.
Is there something in the journal? Open two terminals, run journalctl -f
in the one and picom
in the other. Maybe there is something logged.
Or it might be in a file ~/.Xsession-errors
(or similarily named), or in /var/log/Xorg.0.log
