Hi, I am Elisabetta. I am not new to linux having used Debian based distro for years but I am new to Manjaro.
I am running latest version of manjaro on an HP laptop.
[ec1977 ec1977]# cat /etc/lsb-release
DISTRIB_ID=ManjaroLinux
DISTRIB_RELEASE=21.3.2
DISTRIB_CODENAME=Ruah
DISTRIB_DESCRIPTION="Manjaro Linux"
[ec1977 ec1977]# inxi -v7azy
Kernel: 5.15.50-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=abd10849-e803-4e20-ac98-ac264f5353bb rw quiet apparmor=1
security=apparmor resume=UUID=2eed7c12-729a-489b-8dfe-5510ba160d1f
udev.log_priority=3
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HP product: HP 250 G6 Notebook PC
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 84D4 v: 94.22 serial: <filter> UEFI: Insyde v: F.52
date: 03/04/2019
ID-1: BAT1 charge: 30.2 Wh (100.0%) condition: 30.2/31.1 Wh (97.3%)
volts: 12.4 min: 10.9 model: COMPAL PABAS0241231 type: Li-ion
serial: <filter> status: full
RAM: total: 3.67 GiB used: 2.44 GiB (66.5%)
Array-1: capacity: 16 GiB slots: 2 EC: None max-module-size: 8 GiB
note: est.
Device-1: Bottom-slot 1(left) type: DDR4 detail: synchronous size: 4 GiB
speed: 2400 MT/s volts: N/A width (bits): data: 8 total: 8
manufacturer: Samsung part-no: M471A5244CB0-CTD serial: <filter>
Device-2: Bottom-slot 2(right) type: no module installed
Info: model: Intel Celeron N4000 socket: U3E1 bits: 64 type: MCP
arch: Goldmont Plus built: 2017 process: Intel 14nm family: 6
model-id: 0x7A (122) stepping: 1 microcode: 0x3A
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1002 high: 1032 min/max: 800/2600 base/boost: 1100/1100
scaling: driver: intel_cpufreq governor: schedutil volts: 0.7 V
ext-clock: 100 MHz cores: 1: 1032 2: 973 bogomips: 4378
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
arch_perfmon art bts cat_l2 cdp_l2 clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts erms est fpu
fsgsbase fxsr ht ibpb ibrs ibrs_enhanced ida intel_pt lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdpid
rdrand rdseed rdt_a rdtscp rep_good sdbg sep sha_ni smap smep ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust
tsc_deadline_timer tsc_known_freq umip vme x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel GeminiLake [UHD Graphics 600] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3185 class-ID: 0300
Device-2: Quanta HP Webcam type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0408:5220 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15db built: 2015 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_apl bus-ID: 00:0e.0
chip-ID: 8086:3198 class-ID: 0403
Sound Server-1: ALSA v: k5.15.50-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Intel Gemini Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:0c.0 chip-ID: 8086:31dc class-ID: 0280
IF: wlo1 state: down mac: <filter>
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 1000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-9:4 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 465.76 GiB used: 9.8 GiB (2.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000LPCX-60VHAT1 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A03 scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVDRW DA8AESH rev: XH6M
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 457.39 GiB size: 449.14 GiB (98.20%) used: 9.8 GiB (2.2%)
fs: ext4 block-size: 4096 B dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: abd10849-e803-4e20-ac98-ac264f5353bb
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: NO_LABEL uuid: D2D8-BFF8
ID-1: swap-1 type: partition size: 8.07 GiB used: 524 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: 2eed7c12-729a-489b-8dfe-5510ba160d1f
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0
Device-1: 1-2:2 info: Logitech Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Device-2: 1-5:3 info: Quanta HP Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0408:5220
Device-3: 1-9:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 7 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 44.0 C mobo: N/A
Processes: 215 Uptime: 1h 19m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: pacman: 1111 lib: 324 flatpak: 0 Shell: Bash (su) v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.19
[ec1977 ec1977]# mhwd-kernel -li
Currently running: 5.15.50-1-MANJARO (linux515)
* linux515
I installed lamp stack (PHP 7, MariaDB, Apache) and configured everything following guides taken from this very forum.
PHP works, Apache works, Firewall is correctly set to allow http
PHPMyAdmin when visited on a browser gives me a blank page.
This are the contents of the error logs:
Access logs:
127.0.0.1 - - [07/Jul/2022:06:55:02 +0200] "GET / HTTP/1.1" 200 291
127.0.0.1 - - [07/Jul/2022:06:55:02 +0200] "GET /favicon.ico HTTP/1.1" 404 1143
127.0.0.1 - - [07/Jul/2022:06:58:29 +0200] "GET / HTTP/1.1" 200 291
127.0.0.1 - - [07/Jul/2022:07:23:02 +0200] "GET / HTTP/1.1" 200 291
127.0.0.1 - - [07/Jul/2022:07:23:02 +0200] "GET /favicon.ico HTTP/1.1" 404 1154
127.0.0.1 - - [07/Jul/2022:07:23:20 +0200] "GET /test.php HTTP/1.1" 200 71156
127.0.0.1 - - [07/Jul/2022:07:23:34 +0200] "GET /phpmyadmin/ HTTP/1.1" 200 -
127.0.0.1 - - [07/Jul/2022:07:28:16 +0200] "GET /phpmyadmin/%20goes%20to%20blanck%20page%20while%20apache%20and%20php%20are%20correctly%20working%20manjaro HTTP/1.1" 404 1002
127.0.0.1 - - [07/Jul/2022:07:32:36 +0200] "GET /phpmyadmin/ HTTP/1.1" 200 -
127.0.0.1 - - [07/Jul/2022:08:01:21 +0200] "GET / HTTP/1.1" 200 291
127.0.0.1 - - [07/Jul/2022:08:50:34 +0200] "GET / HTTP/1.1" 304 -
127.0.0.1 - - [07/Jul/2022:08:50:42 +0200] "GET /test.php HTTP/1.1" 200 71159
127.0.0.1 - - [07/Jul/2022:09:06:31 +0200] "GET /phpmyadmin/ HTTP/1.1" 200 -
127.0.0.1 - - [07/Jul/2022:09:07:22 +0200] "GET /favicon.ico HTTP/1.1" 404 1176
127.0.0.1 - - [07/Jul/2022:09:07:32 +0200] "GET /test.php HTTP/1.1" 200 71160
Error Log:
AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
[Thu Jul 07 06:53:32.299339 2022] [mpm_event:notice] [pid 3376:tid 140685460761536] AH00489: Apache/2.4.54 (Unix) configured -- resuming normal operations
[Thu Jul 07 06:53:32.299467 2022] [core:notice] [pid 3376:tid 140685460761536] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
[Thu Jul 07 07:07:01.199607 2022] [mpm_event:notice] [pid 3376:tid 140685460761536] AH00491: caught SIGTERM, shutting down
[Thu Jul 07 07:16:31.262554 2022] [mpm_prefork:notice] [pid 5110] AH00163: Apache/2.4.54 (Unix) PHP/7.4.29 configured -- resuming normal operations
[Thu Jul 07 07:16:31.262640 2022] [core:notice] [pid 5110] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
[Thu Jul 07 07:20:38.022610 2022] [mpm_prefork:notice] [pid 5110] AH00170: caught SIGWINCH, shutting down gracefully
[Thu Jul 07 07:21:34.990349 2022] [mpm_prefork:notice] [pid 617] AH00163: Apache/2.4.54 (Unix) PHP/7.4.29 configured -- resuming normal operations
[Thu Jul 07 07:21:34.990428 2022] [core:notice] [pid 617] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
[Thu Jul 07 07:37:10.001646 2022] [mpm_prefork:notice] [pid 617] AH00169: caught SIGTERM, shutting down
[Thu Jul 07 07:42:44.361322 2022] [mpm_prefork:notice] [pid 3185] AH00163: Apache/2.4.54 (Unix) PHP/7.4.29 configured -- resuming normal operations
[Thu Jul 07 07:42:44.361401 2022] [core:notice] [pid 3185] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
[Thu Jul 07 07:58:24.594543 2022] [mpm_prefork:notice] [pid 3185] AH00170: caught SIGWINCH, shutting down gracefully
[Thu Jul 07 07:59:11.228297 2022] [mpm_prefork:notice] [pid 609] AH00163: Apache/2.4.54 (Unix) PHP/7.4.29 configured -- resuming normal operations
[Thu Jul 07 07:59:11.233113 2022] [core:notice] [pid 609] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
[Thu Jul 07 09:07:11.637800 2022] [mpm_prefork:notice] [pid 609] AH00170: caught SIGWINCH, shutting down gracefully
[Thu Jul 07 09:07:11.805810 2022] [mpm_prefork:notice] [pid 3380] AH00163: Apache/2.4.54 (Unix) PHP/7.4.29 configured -- resuming normal operations
[Thu Jul 07 09:07:11.805893 2022] [core:notice] [pid 3380] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
Note that I also configured a global servername to 127.0.0.1 on port 80 and this seems to make no difference.
What can be causing this issue? How can I understand what parameter got messed up to fix the issue?
Thanks for the kind help!
Elisabetta
