Im trying to use a multiple monitor setup that used to work before but after a reinstall in a new ssd it wont work.
I have 2 gpu an Nvidia gt 730 and my integrated intel graphics
1 display its connected via VGA to the nvidia card while the other display its connected directly to the motherboard also through VGA
xrandr wont detect the second display
Screen 0: minimum 8 x 8, current 1366 x 768, maximum 16384 x 16384
VGA-0 connected 1366x768+0+0 (normal left inverted right x axis y axis) 410mm x 230mm
1366x768 59.79*+
1280x720 60.00
1024x768 75.03 60.00
800x600 75.00 60.32 56.25
640x480 75.00 59.94
DVI-D-0 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)
This is the output of xrandr command
xrandr --listproviders gives me this output
Providers: number : 1
Provider 0: id: 0x278 cap: 0x1, Source Output crtcs: 4 outputs: 3 associated providers: 0 name:NVIDIA-0
also i tried looking for the intel graphics with inxi -G and gives me this output
Graphics: Device-1: NVIDIA GK208B [GeForce GT 730] driver: nvidia v: 470.63.01
Display: x11 server: X.Org 1.20.13 driver: loaded: nvidia resolution: 1366x768~60Hz
OpenGL: renderer: NVIDIA GeForce GT 730/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
also tried the lspci command and it gives me this output witch it only shows 1 VGA compatible controller
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04)
00:16.0 Communication controller: Intel Corporation 7 Series/C216 Chipset Family MEI Controller #1 (rev 04)
00:19.0 Ethernet controller: Intel Corporation 82579V Gigabit Network Connection (rev 04)
00:1a.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 7 Series/C216 Chipset Family PCI Express Root Port 1 (rev c4)
00:1c.1 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 2 (rev c4)
00:1c.3 PCI bridge: Intel Corporation 7 Series/C216 Chipset Family PCI Express Root Port 4 (rev c4)
00:1c.4 PCI bridge: Intel Corporation 82801 PCI Bridge (rev c4)
00:1c.7 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 8 (rev c4)
00:1d.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation Z77 Express Chipset LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 7 Series/C210 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 7 Series/C216 Chipset Family SMBus Controller (rev 04)
01:00.0 VGA compatible controller: NVIDIA Corporation GK208B [GeForce GT 730] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GK208 HDMI/DP Audio Controller (rev a1)
03:00.0 Network controller: Qualcomm Atheros AR9287 Wireless Network Adapter (PCI-Express) (rev 01)
04:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 01)
05:00.0 PCI bridge: ASMedia Technology Inc. ASM1083/1085 PCIe to PCI Bridge (rev 03)
07:00.0 USB controller: ASMedia Technology Inc. ASM1042 SuperSpeed USB Host Controller
Im not quite sure what to do my last hope was to find the pci id and try to force the display into the xorg config file
if im not mistaken i got it working before with optimus-manager but for some reason if i install it rn it prevent my system from booting i entered a live environment mounted my sdd and chrooted into it and had to uninstall it
any help its greatly aprecciate it
and sorry if this is a stupid question have a nice day!
