Hi all,
I have a pretty fresh install of Manjaro-KDE (/lost+found date is 2023-01-11), and ever since my very first boot (to the best of my recollection), I’ve had an issue with a phantom (unwanted) Dvorak keyboard layout popping up.
The first symptom is that the keyboard layout switcher would pop up on the panel, even though I don’t have any alternate layouts installed. When I right click on the keyboard layout icon in the systray, it shows English (US) and English (Dvorak). when I select “Configure Keyboard Layout” [widget], then click on “Layouts: [Configure…],” it only shows English (US) in the Layouts tab. No Dvorak.
If I manually add Dvorak and then delete it, the layout switcher will go away, but then comes back by itself.
The big problem I’m having is trying to run KSP, and it’s setting itself up as Dvorak, which really messes with the keybinds.
Any ideas? I’m running KDE-X11 and I just updated all of the packages today (and logged out and back in, just for good measure).
I’ve been able to get things set up ok for now, but it does keep popping up time and again.
inxi output
$ inxi -Fxxxza --no-host
Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=b7887177-a906-4e57-a1b4-ab61b86ae43f rw quiet
cryptdevice=UUID=50e84c44-c88f-4510-b2f7-1ba000eacf58:luks-50e84c44-c88f-4510-b2f7-1ba000eacf58
root=/dev/mapper/luks-50e84c44-c88f-4510-b2f7-1ba000eacf58 splash
resume=/dev/mapper/luks-41345911-b30a-4da7-878b-6c5ca9dd482e
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LG product: 17Z90Q-K.ADC9U1 v: 0.1
serial: <superuser required> Chassis: type: 10 v: 0.1
Mobo: LG model: 17Z90Q v: FAB1 serial: <superuser required> UEFI: Phoenix
v: A1ZG0395 X64 date: 08/17/2022
ID-1: CMB0 charge: 63.7 Wh (79.6%) condition: 80.0/80.0 Wh (100.0%)
volts: 8.2 min: 7.7 model: LG LGES-LG type: Li-ion serial: <filter>
status: discharging cycles: 8
Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x424
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 1046 high: 1588 min/max: 400/4700:3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 940 2: 1383 3: 1138
4: 643 5: 433 6: 1588 7: 1110 8: 1113 9: 984 10: 930 11: 1298 12: 1086
13: 853 14: 1129 15: 1077 16: 1046 bogomips: 79888
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-P Integrated Graphics vendor: LG driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46a6
class-ID: 0300
Device-2: Luxvisions Innotech LGE Camera type: USB driver: uvcvideo
bus-ID: 3-2:2 chip-ID: 30c9:0084 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
s-diag: 798mm (31.43")
Monitor-1: eDP-1 model: LG Display 0x06ea built: 2021 res: 2560x1600
hz: 60 dpi: 178 gamma: 1.2 size: 366x229mm (14.41x9.02") diag: 432mm (17")
ratio: 16:10 modes: 2560x1600
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: Mesa Intel Graphics (ADL GT2)
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: LG
driver: sof-audio-pci-intel-tgl bus-ID: 00:1f.3 chip-ID: 8086:51c8
class-ID: 0401
Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.64 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:3
chip-ID: 8087:0033 class-ID: e001
Local Storage: total: 953.87 GiB used: 187.17 GiB (19.6%)
model: MZVL21T0HCLR-00B00 size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: GXA7601Q temp: 47.9 C scheme: GPT
ID-1: / raw-size: 919.39 GiB size: 903.88 GiB (98.31%)
used: 187.16 GiB (20.7%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-50e84c44-c88f-4510-b2f7-1ba000eacf58
used: 472 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 34.18 GiB used: 9.8 MiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-41345911-b30a-4da7-878b-6c5ca9dd482e
Src: /sys System Temperatures: cpu: 53.0 C mobo: N/A
Processes: 352 Uptime: 4d 18h 55m wakeups: 57829 Memory: 31.07 GiB
used: 11.09 GiB (35.7%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1403 libs: 363 tools: pamac,yay Shell: Bash v: 5.1.16
running-in: lxterminal inxi: 3.3.24
