error: failed to synchronize all databases (invalid or corrupted database (PGP signature))
Hi and welcome,
I have a script for this…
You can inspect or download it from here or just run it remotely like so;
bash <(curl -s https://gitlab.com/cscs/mapare/-/raw/main/mapare) -K
Do let me know if it helps you or if there are further problems.
Also attached below is a link that will include guidance on how to format code and so on;
I tried to use your script and it went through the entire process fine and then the last lines of code show this.
`error: GPGME error: No data
core 139.2 KiB 1301 KiB/s 00:00 [##################################] 100%
extra 8.1 MiB 17.6 MiB/s 00:00 [##################################] 100%
multilib 143.7 KiB 1529 KiB/s 00:00 [##################################] 100%
Done
Finished!`
i just decided to do a fresh install of manjaro and that fixed it.
