journalctl -b-1 -p5 --no-pager
Jun 21 12:52:02 archlinux kernel: Linux version 5.15.46-1-MANJARO (builduser@fv-az186-238) (gcc (GCC) 12.1.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Thu Jun 9 09:54:17 UTC 2022
Jun 21 12:52:02 archlinux kernel: ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20210730/tbfadt-615)
Jun 21 12:52:02 archlinux kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=9e4329fd-22f7-49dd-a204-2747a5a78520 rw quiet apparmor=1 security=apparmor udev.log_priority=3
Jun 21 12:52:02 archlinux kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64", will be passed to user space.
Jun 21 12:52:02 archlinux kernel: tsc: Unable to calibrate against PIT
Jun 21 12:52:02 archlinux kernel: audit: type=2000 audit(1655841119.169:1): state=initialized audit_enabled=0 res=1
Jun 21 12:52:02 archlinux kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Jun 21 12:52:02 archlinux kernel: SCSI subsystem initialized
Jun 21 12:52:02 archlinux kernel: VFS: Disk quotas dquot_6.6.0
Jun 21 12:52:02 archlinux kernel: Initialise system trusted keyrings
Jun 21 12:52:02 archlinux kernel: Key type blacklist registered
Jun 21 12:52:02 archlinux kernel: Key type asymmetric registered
Jun 21 12:52:02 archlinux kernel: Asymmetric key parser 'x509' registered
Jun 21 12:52:02 archlinux kernel: [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
Jun 21 12:52:02 archlinux kernel: Loading compiled-in X.509 certificates
Jun 21 12:52:02 archlinux kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 6551b71b65e44a69be546551634a6ae29142d98f'
Jun 21 12:52:02 archlinux kernel: Key type ._fscrypt registered
Jun 21 12:52:02 archlinux kernel: Key type .fscrypt registered
Jun 21 12:52:02 archlinux kernel: Key type fscrypt-provisioning registered
Jun 21 12:52:02 archlinux kernel: ata11.00: ATA Identify Device Log not supported
Jun 21 12:52:02 archlinux kernel: scsi 10:0:0:0: Direct-Access ATA KINGSTON SH103S3 BBF0 PQ: 0 ANSI: 5
Jun 21 12:52:02 archlinux kernel: sd 10:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
Jun 21 12:52:02 archlinux kernel: sd 10:0:0:0: [sda] Write Protect is off
Jun 21 12:52:02 archlinux kernel: sd 10:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 21 12:52:02 archlinux kernel: scsi 11:0:0:0: Direct-Access ATA KINGSTON SA400S3 B1D2 PQ: 0 ANSI: 5
Jun 21 12:52:02 archlinux kernel: sd 11:0:0:0: [sdb] 468862128 512-byte logical blocks: (240 GB/224 GiB)
Jun 21 12:52:02 archlinux kernel: sd 11:0:0:0: [sdb] Write Protect is off
Jun 21 12:52:02 archlinux kernel: sd 11:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 21 12:52:02 archlinux kernel: sd 11:0:0:0: [sdb] Attached SCSI disk
Jun 21 12:52:02 archlinux kernel: sd 10:0:0:0: [sda] Attached SCSI disk
Jun 21 12:52:02 archlinux kernel: usb: port power management may be unreliable
Jun 21 12:52:02 archlinux kernel: random: lvm: uninitialized urandom read (4 bytes read)
Jun 21 12:52:02 archlinux kernel: sd 10:0:0:0: Attached scsi generic sg0 type 0
Jun 21 12:52:02 archlinux kernel: sd 11:0:0:0: Attached scsi generic sg1 type 0
Jun 21 12:52:02 archlinux kernel: audit: type=1130 audit(1655841122.279:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 12:52:02 archlinux kernel: audit: type=1400 audit(1655841122.309:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=363 comm="apparmor_parser"
Jun 21 12:52:02 archlinux kernel: audit: type=1400 audit(1655841122.312:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=364 comm="apparmor_parser"
Jun 21 12:52:02 archlinux kernel: audit: type=1400 audit(1655841122.312:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=364 comm="apparmor_parser"
Jun 21 12:52:02 archlinux kernel: audit: type=1400 audit(1655841122.329:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=365 comm="apparmor_parser"
Jun 21 12:52:02 archlinux kernel: audit: type=1400 audit(1655841122.345:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=367 comm="apparmor_parser"
Jun 21 12:52:02 archlinux kernel: audit: type=1400 audit(1655841122.359:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-bgqd" pid=366 comm="apparmor_parser"
Jun 21 12:52:02 archlinux kernel: audit: type=1400 audit(1655841122.575:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=368 comm="apparmor_parser"
Jun 21 12:52:02 archlinux kernel: audit: type=1400 audit(1655841122.575:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=368 comm="apparmor_parser"
Jun 21 12:52:02 archlinux systemd-random-seed[357]: Kernel entropy pool is not initialized yet, waiting until it is.
Jun 21 12:52:02 archlinux systemd-journald[372]: File /var/log/journal/2157e4a246f841eda7526e43fb57f027/system.journal corrupted or uncleanly shut down, renaming and replacing.
Jun 21 12:52:02 archlinux kernel: ccp 0000:07:00.2: ccp enabled
Jun 21 12:52:02 archlinux systemd-udevd[408]: could not read from '/sys/module/fjes/initstate': No such device
Jun 21 12:52:03 archlinux kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Jun 21 12:52:03 archlinux kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Jun 21 12:52:03 archlinux kernel: random: crng init done
Jun 21 12:52:03 archlinux kernel: kvm: disabled by bios
Jun 21 12:52:03 archlinux kernel: amdgpu: SRAT table not found
Jun 21 12:52:03 archlinux kernel: thermal thermal_zone0: failed to read out thermal zone (-61)
Jun 21 12:52:03 archlinux polkitd[610]: Loading rules from directory /etc/polkit-1/rules.d
Jun 21 12:52:03 archlinux polkitd[610]: Loading rules from directory /usr/share/polkit-1/rules.d
Jun 21 12:52:03 archlinux polkitd[610]: Finished loading, compiling and executing 8 rules
Jun 21 12:52:03 archlinux polkitd[610]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Jun 21 12:52:03 archlinux kernel: iwlwifi 0000:04:00.0: iwlmvm doesn't allow to disable HW crypto, check swcrypto module parameter
Jun 21 12:52:03 archlinux kernel: iwlwifi 0000:04:00.0: iwlmvm doesn't allow to disable BT Coex, check bt_coex_active module parameter
Jun 21 12:52:03 archlinux kernel: ACPI: \: failed to evaluate _DSM (0x1001)
Jun 21 12:52:04 archlinux kernel: kvm: disabled by bios
Jun 21 12:52:04 archlinux kernel: kauditd_printk_skb: 81 callbacks suppressed
Jun 21 12:52:04 archlinux kernel: audit: type=1100 audit(1655841124.922:66): pid=790 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Jun 21 12:52:04 archlinux kernel: audit: type=1101 audit(1655841124.922:67): pid=790 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Jun 21 12:52:04 archlinux kernel: audit: type=1103 audit(1655841124.925:68): pid=790 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Jun 21 12:52:04 archlinux kernel: audit: type=1130 audit(1655841124.989:69): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@962 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 12:52:05 archlinux systemd[792]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Jun 21 12:52:05 archlinux kernel: audit: type=1101 audit(1655841125.002:70): pid=792 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 12:52:05 archlinux kernel: audit: type=1103 audit(1655841125.002:71): pid=792 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Jun 21 12:52:05 archlinux kernel: audit: type=1006 audit(1655841125.002:72): pid=792 uid=0 subj==unconfined old-auid=4294967295 auid=962 tty=(none) old-ses=4294967295 ses=1 res=1
Jun 21 12:52:05 archlinux kernel: audit: type=1300 audit(1655841125.002:72): arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7ffe33e62dd0 a2=3 a3=7ffe33e62ae5 items=0 ppid=1 pid=792 auid=962 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd" subj==unconfined key=(null)
Jun 21 12:52:05 archlinux kernel: audit: type=1327 audit(1655841125.002:72): proctitle="(systemd)"
Jun 21 12:52:05 archlinux kernel: audit: type=1105 audit(1655841125.005:73): pid=792 uid=0 auid=962 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 12:52:05 archlinux systemd[792]: xdg-user-dirs-update.service: Main process exited, code=exited, status=1/FAILURE
Jun 21 12:52:05 archlinux systemd[792]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Jun 21 12:52:05 archlinux systemd[792]: Failed to start Update XDG user dir configuration.
Jun 21 12:52:05 archlinux sddm-greeter[801]: QFont::fromString: Invalid description '(empty)'
Jun 21 12:52:05 archlinux sddm-greeter[801]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffdc8063170), parent's thread is QThread(0x561c4e343090), current thread is QThread(0x561c4e498bb0)
Jun 21 12:52:05 archlinux sddm-greeter[801]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Jun 21 12:52:05 archlinux udisksd[824]: udisks daemon version 2.9.4 starting
Jun 21 12:52:06 archlinux udisksd[824]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Jun 21 12:52:06 archlinux sddm-greeter[801]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Jun 21 12:52:06 archlinux sddm-greeter[801]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Jun 21 12:52:06 archlinux sddm-greeter[801]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Jun 21 12:52:07 archlinux sddm-greeter[801]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Jun 21 12:52:07 archlinux sddm-greeter[801]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.23'
Jun 21 12:52:07 archlinux kernel: Bridge firewalling registered
Jun 21 12:52:13 archlinux kernel: kauditd_printk_skb: 172 callbacks suppressed
Jun 21 12:52:13 archlinux kernel: audit: type=1131 audit(1655841133.692:138): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 12:52:33 archlinux kernel: audit: type=1131 audit(1655841153.879:139): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 12:52:34 archlinux kernel: audit: type=1334 audit(1655841154.039:140): prog-id=0 op=UNLOAD
Jun 21 12:52:34 archlinux kernel: audit: type=1334 audit(1655841154.039:141): prog-id=0 op=UNLOAD
Jun 21 12:52:34 archlinux kernel: audit: type=1334 audit(1655841154.039:142): prog-id=0 op=UNLOAD
Jun 21 12:52:40 archlinux kernel: audit: type=1131 audit(1655841160.458:143): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 12:52:40 archlinux kernel: audit: type=1334 audit(1655841160.518:144): prog-id=0 op=UNLOAD
Jun 21 12:52:40 archlinux kernel: audit: type=1334 audit(1655841160.518:145): prog-id=0 op=UNLOAD
Jun 21 12:52:40 archlinux kernel: audit: type=1334 audit(1655841160.518:146): prog-id=0 op=UNLOAD
Jun 21 12:52:50 archlinux kernel: audit: type=1100 audit(1655841170.024:147): pid=1090 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="cody" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Jun 21 12:52:50 archlinux kernel: audit: type=1101 audit(1655841170.024:148): pid=1090 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="cody" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Jun 21 12:52:50 archlinux kernel: audit: type=1103 audit(1655841170.024:149): pid=1090 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="cody" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Jun 21 12:52:50 archlinux kernel: audit: type=1006 audit(1655841170.024:150): pid=1090 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
Jun 21 12:52:50 archlinux kernel: audit: type=1300 audit(1655841170.024:150): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7fff8ce433a0 a2=4 a3=7fff8ce430b4 items=0 ppid=693 pid=1090 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" subj==unconfined key=(null)
Jun 21 12:52:50 archlinux kernel: audit: type=1327 audit(1655841170.024:150): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746864323361356664652D323630362D346366612D626239632D386332613461313063323363002D2D69640031002D2D7374617274002F7573722F6C69622F706C61736D612D646275732D72756E2D7365
Jun 21 12:52:50 archlinux NetworkManager[658]: <warn> [1655841170.0416] device (wlp4s0): no secrets: No agents were available for this request.
Jun 21 12:52:50 archlinux NetworkManager[658]: <warn> [1655841170.0422] device (wlp4s0): Activation: failed for connection 'ATTZ36Fspi'
Jun 21 12:52:50 archlinux kernel: audit: type=1130 audit(1655841170.060:151): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 12:52:50 archlinux systemd[1092]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[cody] ruser=[<unknown>] rhost=[<unknown>]
Jun 21 12:52:50 archlinux kernel: audit: type=1101 audit(1655841170.067:152): pid=1092 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="cody" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 12:52:50 archlinux kernel: audit: type=1103 audit(1655841170.067:153): pid=1092 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="cody" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Jun 21 12:52:50 archlinux kernel: audit: type=1006 audit(1655841170.067:154): pid=1092 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
Jun 21 12:52:50 archlinux systemd-journald[372]: File /var/log/journal/2157e4a246f841eda7526e43fb57f027/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Jun 21 12:52:52 archlinux klauncher[1133]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jun 21 12:52:52 archlinux polkitd[610]: Registered Authentication Agent for unix-session:2 (system bus name :1.39 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Jun 21 12:52:52 archlinux backlighthelper[1343]: org.kde.powerdevil: no kernel backlight interface found
Jun 21 12:52:52 archlinux udisksd[824]: Mounted /dev/sda3 at /run/media/cody/50e136c9-2d97-43e4-b769-3a59955822a0 on behalf of uid 1000
Jun 21 12:52:53 archlinux pulseaudio[1288]: stat('/etc/pulse/default.pa.d'): No such file or directory
Jun 21 12:52:53 archlinux pulseaudio[1288]: Could not find org.bluez.BatteryProviderManager1.RegisterBatteryProvider(), is bluetoothd started with experimental features enabled (-E flag)?
Jun 21 12:53:00 archlinux systemd[793]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Jun 21 12:53:00 archlinux kernel: kauditd_printk_skb: 20 callbacks suppressed
Jun 21 12:53:00 archlinux kernel: audit: type=1131 audit(1655841180.187:169): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@962 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 12:53:00 archlinux kernel: audit: type=1131 audit(1655841180.250:170): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@962 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 12:53:03 archlinux kernel: audit: type=1131 audit(1655841183.541:171): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 12:53:21 archlinux kernel: audit: type=1131 audit(1655841201.041:172): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 12:53:21 archlinux kernel: audit: type=1334 audit(1655841201.147:173): prog-id=0 op=UNLOAD
Jun 21 12:53:21 archlinux kernel: audit: type=1334 audit(1655841201.147:174): prog-id=0 op=UNLOAD
Jun 21 12:53:21 archlinux kernel: audit: type=1334 audit(1655841201.147:175): prog-id=0 op=UNLOAD
Jun 21 12:57:10 archlinux kernel: audit: type=1334 audit(1655841430.468:176): prog-id=28 op=LOAD
Jun 21 12:57:10 archlinux kernel: audit: type=1334 audit(1655841430.468:177): prog-id=29 op=LOAD
Jun 21 12:57:10 archlinux kernel: audit: type=1334 audit(1655841430.468:178): prog-id=30 op=LOAD
Jun 21 12:57:10 archlinux kernel: audit: type=1130 audit(1655841430.511:179): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 12:57:40 archlinux kernel: audit: type=1131 audit(1655841460.547:180): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 12:57:40 archlinux kernel: audit: type=1334 audit(1655841460.604:181): prog-id=0 op=UNLOAD
Jun 21 12:57:40 archlinux kernel: audit: type=1334 audit(1655841460.604:182): prog-id=0 op=UNLOAD
Jun 21 12:57:40 archlinux kernel: audit: type=1334 audit(1655841460.604:183): prog-id=0 op=UNLOAD
Jun 21 13:07:03 archlinux kernel: audit: type=1130 audit(1655842023.772:184): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 13:07:03 archlinux kernel: audit: type=1131 audit(1655842023.772:185): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 13:57:33 archlinux dolphin[4935]: Cannot initialize model with data QJsonObject(). missing: QJsonValue(string, "urls")
Jun 21 13:57:34 archlinux dolphin[4935]: qt.qpa.wayland: setGrabPopup called with a parent, QtWaylandClient::QWaylandXdgSurface(0x55699dc39560) which does not match the current topmost grabbing popup, QtWaylandClient::QWaylandXdgSurface(0x55699df54a00) According to the xdg-shell protocol, this is not allowed. The wayland QPA plugin is currently handling it by setting the parent to the topmost grabbing popup. Note, however, that this may cause positioning errors and popups closing unxpectedly because xdg-shell mandate that child popups close before parents
Jun 21 13:57:35 archlinux dolphin[4935]: qt.qpa.wayland: setGrabPopup called with a parent, QtWaylandClient::QWaylandXdgSurface(0x55699dc39560) which does not match the current topmost grabbing popup, QtWaylandClient::QWaylandXdgSurface(0x55699df54a00) According to the xdg-shell protocol, this is not allowed. The wayland QPA plugin is currently handling it by setting the parent to the topmost grabbing popup. Note, however, that this may cause positioning errors and popups closing unxpectedly because xdg-shell mandate that child popups close before parents
Jun 21 15:19:31 archlinux kate[8506]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_aspell.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_aspell.so: (libaspell.so.15: cannot open shared object file: No such file or directory)"
Jun 21 15:19:31 archlinux kate[8506]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so: (libhspell.so.0: cannot open shared object file: No such file or directory)"
Jun 21 15:19:31 archlinux kate[8506]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so: (libvoikko.so.1: cannot open shared object file: No such file or directory)"
Jun 21 15:19:31 archlinux kate[8506]: kf.sonnet.core: No language dictionaries for the language: "en_US" trying to load en_US as default
Jun 21 15:19:31 archlinux kate[8506]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
Jun 21 15:23:09 archlinux dolphin[4935]: qt.qpa.wayland: setGrabPopup called with a parent, QtWaylandClient::QWaylandXdgSurface(0x55699dc39560) which does not match the current topmost grabbing popup, QtWaylandClient::QWaylandXdgSurface(0x55699dd66e80) According to the xdg-shell protocol, this is not allowed. The wayland QPA plugin is currently handling it by setting the parent to the topmost grabbing popup. Note, however, that this may cause positioning errors and popups closing unxpectedly because xdg-shell mandate that child popups close before parents
Jun 21 15:23:10 archlinux dolphin[4935]: qt.qpa.wayland: setGrabPopup called with a parent, QtWaylandClient::QWaylandXdgSurface(0x55699dc39560) which does not match the current topmost grabbing popup, QtWaylandClient::QWaylandXdgSurface(0x55699dd66e80) According to the xdg-shell protocol, this is not allowed. The wayland QPA plugin is currently handling it by setting the parent to the topmost grabbing popup. Note, however, that this may cause positioning errors and popups closing unxpectedly because xdg-shell mandate that child popups close before parents
Jun 21 17:33:46 archlinux xdg-desktop-portal-kde[1440]: QWindow::fromWinId(): platform plugin does not support foreign windows.
Jun 21 17:35:00 archlinux dolphin[4935]: qt.qpa.wayland: setGrabPopup called with a parent, QtWaylandClient::QWaylandXdgSurface(0x55699dc39560) which does not match the current topmost grabbing popup, QtWaylandClient::QWaylandXdgSurface(0x55699e20e510) According to the xdg-shell protocol, this is not allowed. The wayland QPA plugin is currently handling it by setting the parent to the topmost grabbing popup. Note, however, that this may cause positioning errors and popups closing unxpectedly because xdg-shell mandate that child popups close before parents
Jun 21 17:35:01 archlinux dolphin[4935]: qt.qpa.wayland: setGrabPopup called with a parent, QtWaylandClient::QWaylandXdgSurface(0x55699dc39560) which does not match the current topmost grabbing popup, QtWaylandClient::QWaylandXdgSurface(0x55699e20e510) According to the xdg-shell protocol, this is not allowed. The wayland QPA plugin is currently handling it by setting the parent to the topmost grabbing popup. Note, however, that this may cause positioning errors and popups closing unxpectedly because xdg-shell mandate that child popups close before parents
Jun 21 17:41:19 archlinux dolphin[4935]: qt.qpa.wayland: setGrabPopup called with a parent, QtWaylandClient::QWaylandXdgSurface(0x55699dc39560) which does not match the current topmost grabbing popup, QtWaylandClient::QWaylandXdgSurface(0x55699e561a10) According to the xdg-shell protocol, this is not allowed. The wayland QPA plugin is currently handling it by setting the parent to the topmost grabbing popup. Note, however, that this may cause positioning errors and popups closing unxpectedly because xdg-shell mandate that child popups close before parents
Jun 21 19:39:00 archlinux kernel: audit: type=1111 audit(1655865540.718:186): pid=658 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="enp3s0" ifindex=2 args=500 pid=22268 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Jun 21 19:39:00 archlinux kernel: audit: type=1111 audit(1655865540.731:187): pid=658 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="wlp4s0" ifindex=3 args=500 pid=22268 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Jun 21 19:39:00 archlinux kernel: audit: type=1334 audit(1655865540.761:188): prog-id=31 op=LOAD
Jun 21 19:39:00 archlinux kernel: audit: type=1334 audit(1655865540.761:189): prog-id=32 op=LOAD
Jun 21 19:39:00 archlinux kernel: audit: type=1334 audit(1655865540.761:190): prog-id=33 op=LOAD
Jun 21 19:39:00 archlinux kernel: audit: type=1111 audit(1655865540.788:191): pid=658 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="wlp4s0" ifindex=3 args=500 pid=22268 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Jun 21 19:39:00 archlinux kernel: audit: type=1130 audit(1655865540.844:192): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 19:39:30 archlinux kernel: audit: type=1131 audit(1655865570.878:193): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 21 19:39:31 archlinux kernel: audit: type=1334 audit(1655865571.024:194): prog-id=0 op=UNLOAD
Jun 21 19:39:31 archlinux kernel: audit: type=1334 audit(1655865571.024:195): prog-id=0 op=UNLOAD
Jun 21 19:39:31 archlinux kernel: audit: type=1334 audit(1655865571.024:196): prog-id=0 op=UNLOAD
Jun 22 00:00:12 archlinux kernel: audit: type=1334 audit(1655881212.703:197): prog-id=34 op=LOAD
Jun 22 00:00:12 archlinux kernel: audit: type=1334 audit(1655881212.713:198): prog-id=35 op=LOAD
Jun 22 00:00:12 archlinux kernel: audit: type=1130 audit(1655881212.717:199): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 22 00:00:12 archlinux kernel: audit: type=1131 audit(1655881212.753:200): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 22 00:00:12 archlinux kernel: audit: type=1130 audit(1655881212.787:201): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 22 00:00:12 archlinux kernel: audit: type=1131 audit(1655881212.787:202): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 22 00:00:12 archlinux kernel: audit: type=1334 audit(1655881212.850:203): prog-id=0 op=UNLOAD
Jun 22 00:00:13 archlinux kernel: audit: type=1130 audit(1655881213.027:204): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pkgfile-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 22 00:00:13 archlinux kernel: audit: type=1131 audit(1655881213.027:205): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pkgfile-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 22 00:00:13 archlinux kernel: audit: type=1334 audit(1655881213.103:206): prog-id=0 op=UNLOAD
Jun 22 00:01:01 archlinux anacron[24473]: Anacron started on 2022-06-22
Jun 22 00:01:01 archlinux anacron[24473]: Normal exit (0 jobs run)
Jun 22 01:01:01 archlinux anacron[24769]: Anacron started on 2022-06-22
Jun 22 01:01:01 archlinux anacron[24769]: Normal exit (0 jobs run)
Jun 22 02:01:01 archlinux anacron[25052]: Anacron started on 2022-06-22
Jun 22 02:01:01 archlinux anacron[25052]: Normal exit (0 jobs run)
Jun 22 03:01:02 archlinux anacron[25348]: Anacron started on 2022-06-22
Jun 22 03:01:02 archlinux anacron[25348]: Will run job `cron.daily' in 37 min.
Jun 22 03:01:02 archlinux anacron[25348]: Will run job `cron.weekly' in 57 min.
Jun 22 03:01:02 archlinux anacron[25348]: Jobs will be executed sequentially
Jun 22 03:38:02 archlinux anacron[25348]: Job `cron.daily' started
Jun 22 03:38:02 archlinux anacron[25348]: Job `cron.daily' terminated
Jun 22 03:58:02 archlinux anacron[25348]: Job `cron.weekly' started
Jun 22 03:58:02 archlinux anacron[25348]: Job `cron.weekly' terminated
Jun 22 03:58:02 archlinux anacron[25348]: Normal exit (2 jobs run)
Jun 22 07:53:23 archlinux kernel: audit: type=1334 audit(1655909603.481:207): prog-id=36 op=LOAD
Jun 22 07:53:24 archlinux kernel: audit: type=1130 audit(1655909604.781:208): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 22 07:53:24 archlinux kernel: audit: type=1131 audit(1655909604.781:209): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 22 07:53:24 archlinux kernel: audit: type=1334 audit(1655909604.861:210): prog-id=0 op=UNLOAD
Jun 22 11:05:18 archlinux kernel: audit: type=1400 audit(1655921118.289:211): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=29592 comm="snap-confine" capability=12 capname="net_admin"
Jun 22 11:05:18 archlinux kernel: audit: type=1400 audit(1655921118.289:211): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=29592 comm="snap-confine" capability=38 capname="perfmon"
Jun 22 11:05:18 archlinux kernel: audit: type=1334 audit(1655921118.289:211): prog-id=37 op=LOAD
Jun 22 11:05:18 archlinux kernel: audit: type=1300 audit(1655921118.289:211): arch=c000003e syscall=321 success=yes exit=9 a0=5 a1=7fff38530f00 a2=90 a3=1000 items=0 ppid=1232 pid=29592 auid=1000 uid=1000 gid=1000 euid=0 suid=0 fsuid=0 egid=0 sgid=1000 fsgid=0 tty=tty2 ses=2 comm="snap-confine" exe="/usr/lib/snapd/snap-confine" subj==/usr/lib/snapd/snap-confine (enforce) key=(null)
Jun 22 11:05:18 archlinux kernel: audit: type=1327 audit(1655921118.289:211): proctitle=2F7573722F6C69622F736E6170642F736E61702D636F6E66696E65002D2D6261736500636F7265313800736E61702E73706F746966792E73706F74696679002F7573722F6C69622F736E6170642F736E61702D657865630073706F74696679
Jun 22 11:05:18 archlinux kernel: audit: type=1400 audit(1655921118.306:212): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=29592 comm="snap-confine" capability=4 capname="fsetid"
Jun 22 11:05:18 archlinux kernel: audit: type=1300 audit(1655921118.306:212): arch=c000003e syscall=91 success=yes exit=0 a0=b a1=3ff a2=0 a3=0 items=0 ppid=1232 pid=29592 auid=1000 uid=1000 gid=1000 euid=0 suid=0 fsuid=0 egid=1000 sgid=1000 fsgid=1000 tty=tty2 ses=2 comm="snap-confine" exe="/usr/lib/snapd/snap-confine" subj==/usr/lib/snapd/snap-confine (enforce) key=(null)
Jun 22 11:05:18 archlinux kernel: audit: type=1327 audit(1655921118.306:212): proctitle=2F7573722F6C69622F736E6170642F736E61702D636F6E66696E65002D2D6261736500636F7265313800736E61702E73706F746966792E73706F74696679002F7573722F6C69622F736E6170642F736E61702D657865630073706F74696679
Jun 22 11:05:20 archlinux kernel: audit: type=1400 audit(1655921120.466:213): apparmor="DENIED" operation="open" profile="snap.spotify.spotify" name="/sys/devices/virtual/dmi/id/sys_vendor" pid=29592 comm=436F726520546872656164 requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Jun 22 11:05:20 archlinux kernel: audit: type=1300 audit(1655921120.466:213): arch=c000003e syscall=257 success=no exit=-13 a0=ffffff9c a1=28de74 a2=0 a3=0 items=0 ppid=1232 pid=29592 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=tty2 ses=2 comm=436F726520546872656164 exe="/snap/spotify/60/usr/share/spotify/spotify" subj==snap.spotify.spotify (enforce) key=(null)
Jun 22 11:05:23 archlinux kernel: kauditd_printk_skb: 46 callbacks suppressed
Jun 22 11:05:23 archlinux kernel: audit: type=1326 audit(1655921123.833:241): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:23 archlinux kernel: audit: type=1326 audit(1655921123.833:242): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:23 archlinux kernel: audit: type=1326 audit(1655921123.919:243): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:23 archlinux kernel: audit: type=1326 audit(1655921123.919:244): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify:gdrv0" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:24 archlinux kernel: audit: type=1326 audit(1655921123.999:245): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:24 archlinux kernel: audit: type=1326 audit(1655921123.999:246): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:24 archlinux kernel: audit: type=1326 audit(1655921124.059:247): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:24 archlinux kernel: audit: type=1326 audit(1655921124.059:248): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:24 archlinux kernel: audit: type=1326 audit(1655921124.156:249): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:24 archlinux kernel: audit: type=1326 audit(1655921124.156:250): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:29 archlinux kernel: kauditd_printk_skb: 36 callbacks suppressed
Jun 22 11:05:29 archlinux kernel: audit: type=1326 audit(1655921129.523:287): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:29 archlinux kernel: audit: type=1326 audit(1655921129.523:288): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:29 archlinux kernel: audit: type=1326 audit(1655921129.723:289): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:29 archlinux kernel: audit: type=1326 audit(1655921129.723:290): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:30 archlinux kernel: audit: type=1326 audit(1655921130.323:291): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:30 archlinux kernel: audit: type=1326 audit(1655921130.323:292): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:30 archlinux kernel: audit: type=1326 audit(1655921130.413:293): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:30 archlinux kernel: audit: type=1326 audit(1655921130.413:294): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify:gdrv0" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:30 archlinux kernel: audit: type=1326 audit(1655921130.526:295): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:30 archlinux kernel: audit: type=1326 audit(1655921130.526:296): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify:gdrv0" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:34 archlinux kernel: kauditd_printk_skb: 34 callbacks suppressed
Jun 22 11:05:34 archlinux kernel: audit: type=1326 audit(1655921134.606:331): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:34 archlinux kernel: audit: type=1326 audit(1655921134.606:332): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify:gdrv0" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:34 archlinux kernel: audit: type=1326 audit(1655921134.716:333): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:34 archlinux kernel: audit: type=1326 audit(1655921134.716:334): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:36 archlinux kernel: audit: type=1326 audit(1655921136.056:335): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:36 archlinux kernel: audit: type=1326 audit(1655921136.066:336): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify:gdrv0" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:36 archlinux kernel: audit: type=1326 audit(1655921136.156:337): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:36 archlinux kernel: audit: type=1326 audit(1655921136.156:338): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify:gdrv0" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:36 archlinux kernel: audit: type=1326 audit(1655921136.256:339): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:36 archlinux kernel: audit: type=1326 audit(1655921136.256:340): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify:gdrv0" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:43 archlinux kernel: kauditd_printk_skb: 22 callbacks suppressed
Jun 22 11:05:43 archlinux kernel: audit: type=1326 audit(1655921143.529:363): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:43 archlinux kernel: audit: type=1326 audit(1655921143.533:364): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:49 archlinux kernel: audit: type=1326 audit(1655921149.530:365): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:49 archlinux kernel: audit: type=1326 audit(1655921149.530:366): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:56 archlinux kernel: audit: type=1326 audit(1655921156.530:367): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:05:56 archlinux kernel: audit: type=1326 audit(1655921156.530:368): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:06:03 archlinux kernel: audit: type=1326 audit(1655921163.533:369): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:06:03 archlinux kernel: audit: type=1326 audit(1655921163.533:370): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:06:09 archlinux kernel: audit: type=1326 audit(1655921169.533:371): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:06:09 archlinux kernel: audit: type=1326 audit(1655921169.533:372): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:06:16 archlinux kernel: audit: type=1326 audit(1655921176.533:373): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:06:16 archlinux kernel: audit: type=1326 audit(1655921176.533:374): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:06:22 archlinux kernel: audit: type=1326 audit(1655921182.533:375): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:06:22 archlinux kernel: audit: type=1326 audit(1655921182.533:376): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:06:29 archlinux kernel: audit: type=1326 audit(1655921189.530:377): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:06:29 archlinux kernel: audit: type=1326 audit(1655921189.533:378): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:06:35 archlinux kernel: audit: type=1326 audit(1655921195.140:379): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:06:35 archlinux kernel: audit: type=1326 audit(1655921195.140:380): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:06:39 archlinux kernel: audit: type=1326 audit(1655921199.480:381): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:06:39 archlinux kernel: audit: type=1326 audit(1655921199.480:382): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:06:46 archlinux kernel: audit: type=1326 audit(1655921206.474:383): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:06:46 archlinux kernel: audit: type=1326 audit(1655921206.474:384): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:06:53 archlinux kernel: audit: type=1326 audit(1655921213.477:385): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:06:53 archlinux kernel: audit: type=1326 audit(1655921213.477:386): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:07:00 archlinux kernel: audit: type=1326 audit(1655921220.470:387): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:07:00 archlinux kernel: audit: type=1326 audit(1655921220.470:388): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:07:06 archlinux kernel: audit: type=1326 audit(1655921226.470:389): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:07:06 archlinux kernel: audit: type=1326 audit(1655921226.470:390): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:07:13 archlinux kernel: audit: type=1326 audit(1655921233.477:391): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:07:13 archlinux kernel: audit: type=1326 audit(1655921233.477:392): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:07:20 archlinux kernel: audit: type=1326 audit(1655921240.477:393): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:07:20 archlinux kernel: audit: type=1326 audit(1655921240.477:394): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:07:27 archlinux kernel: audit: type=1326 audit(1655921247.477:395): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:07:27 archlinux kernel: audit: type=1326 audit(1655921247.481:396): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:07:33 archlinux kernel: audit: type=1326 audit(1655921253.477:397): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:07:33 archlinux kernel: audit: type=1326 audit(1655921253.477:398): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:07:40 archlinux kernel: audit: type=1326 audit(1655921260.478:399): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:07:40 archlinux kernel: audit: type=1326 audit(1655921260.478:400): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:07:47 archlinux kernel: audit: type=1326 audit(1655921267.478:401): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:07:47 archlinux kernel: audit: type=1326 audit(1655921267.481:402): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:07:53 archlinux kernel: audit: type=1326 audit(1655921273.481:403): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:07:53 archlinux kernel: audit: type=1326 audit(1655921273.481:404): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:08:00 archlinux kernel: audit: type=1326 audit(1655921280.478:405): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:08:00 archlinux kernel: audit: type=1326 audit(1655921280.478:406): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:08:07 archlinux kernel: audit: type=1326 audit(1655921287.478:407): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:08:07 archlinux kernel: audit: type=1326 audit(1655921287.478:408): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:08:14 archlinux kernel: audit: type=1326 audit(1655921294.478:409): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:08:14 archlinux kernel: audit: type=1326 audit(1655921294.478:410): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:08:20 archlinux kernel: audit: type=1326 audit(1655921300.481:411): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:08:20 archlinux kernel: audit: type=1326 audit(1655921300.481:412): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:08:27 archlinux kernel: audit: type=1326 audit(1655921307.478:413): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:08:27 archlinux kernel: audit: type=1326 audit(1655921307.478:414): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:08:34 archlinux kernel: audit: type=1326 audit(1655921314.478:415): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:08:34 archlinux kernel: audit: type=1326 audit(1655921314.478:416): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:08:41 archlinux kernel: audit: type=1326 audit(1655921321.478:417): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:08:41 archlinux kernel: audit: type=1326 audit(1655921321.478:418): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:08:47 archlinux kernel: audit: type=1326 audit(1655921327.472:419): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:08:47 archlinux kernel: audit: type=1326 audit(1655921327.472:420): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:08:54 archlinux kernel: audit: type=1326 audit(1655921334.478:421): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:08:54 archlinux kernel: audit: type=1326 audit(1655921334.478:422): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:09:01 archlinux kernel: audit: type=1326 audit(1655921341.482:423): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:09:01 archlinux kernel: audit: type=1326 audit(1655921341.482:424): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:09:07 archlinux kernel: audit: type=1326 audit(1655921347.482:425): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:09:07 archlinux kernel: audit: type=1326 audit(1655921347.482:426): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:09:14 archlinux kernel: audit: type=1326 audit(1655921354.482:427): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:09:14 archlinux kernel: audit: type=1326 audit(1655921354.482:428): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:09:20 archlinux kernel: audit: type=1326 audit(1655921360.479:429): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:09:20 archlinux kernel: audit: type=1326 audit(1655921360.479:430): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:09:27 archlinux kernel: audit: type=1326 audit(1655921367.479:431): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:09:27 archlinux kernel: audit: type=1326 audit(1655921367.479:432): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:09:34 archlinux kernel: audit: type=1326 audit(1655921374.479:433): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:09:34 archlinux kernel: audit: type=1326 audit(1655921374.479:434): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:09:40 archlinux kernel: audit: type=1326 audit(1655921380.479:435): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:09:40 archlinux kernel: audit: type=1326 audit(1655921380.479:436): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:09:47 archlinux kernel: audit: type=1326 audit(1655921387.479:437): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:09:47 archlinux kernel: audit: type=1326 audit(1655921387.479:438): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:09:54 archlinux kernel: audit: type=1326 audit(1655921394.479:439): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:09:54 archlinux kernel: audit: type=1326 audit(1655921394.479:440): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:10:00 archlinux kernel: audit: type=1326 audit(1655921400.482:441): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:10:00 archlinux kernel: audit: type=1326 audit(1655921400.482:442): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:10:07 archlinux kernel: audit: type=1326 audit(1655921407.479:443): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:10:07 archlinux kernel: audit: type=1326 audit(1655921407.479:444): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:10:14 archlinux kernel: audit: type=1326 audit(1655921414.479:445): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:10:14 archlinux kernel: audit: type=1326 audit(1655921414.479:446): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:10:20 archlinux kernel: audit: type=1326 audit(1655921420.479:447): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:10:20 archlinux kernel: audit: type=1326 audit(1655921420.479:448): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:10:27 archlinux kernel: audit: type=1326 audit(1655921427.479:449): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:10:27 archlinux kernel: audit: type=1326 audit(1655921427.479:450): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:10:33 archlinux kernel: audit: type=1326 audit(1655921433.483:451): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:10:33 archlinux kernel: audit: type=1326 audit(1655921433.483:452): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:10:40 archlinux kernel: audit: type=1326 audit(1655921440.479:453): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:10:40 archlinux kernel: audit: type=1326 audit(1655921440.479:454): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:10:47 archlinux kernel: audit: type=1326 audit(1655921447.479:455): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:10:47 archlinux kernel: audit: type=1326 audit(1655921447.479:456): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:10:51 archlinux kernel: audit: type=1326 audit(1655921451.963:457): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:10:51 archlinux kernel: audit: type=1326 audit(1655921451.966:458): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:10:58 archlinux kernel: audit: type=1326 audit(1655921458.973:459): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:10:58 archlinux kernel: audit: type=1326 audit(1655921458.973:460): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:11:05 archlinux kernel: audit: type=1326 audit(1655921465.973:461): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:11:05 archlinux kernel: audit: type=1326 audit(1655921465.973:462): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:11:12 archlinux kernel: audit: type=1326 audit(1655921472.973:463): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:11:12 archlinux kernel: audit: type=1326 audit(1655921472.973:464): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:11:18 archlinux kernel: audit: type=1326 audit(1655921478.963:465): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:11:18 archlinux kernel: audit: type=1326 audit(1655921478.963:466): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:11:25 archlinux kernel: audit: type=1326 audit(1655921485.967:467): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:11:25 archlinux kernel: audit: type=1326 audit(1655921485.967:468): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:11:32 archlinux kernel: audit: type=1326 audit(1655921492.973:469): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:11:32 archlinux kernel: audit: type=1326 audit(1655921492.973:470): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:11:39 archlinux kernel: audit: type=1326 audit(1655921499.970:471): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:11:39 archlinux kernel: audit: type=1326 audit(1655921499.970:472): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:11:46 archlinux kernel: audit: type=1326 audit(1655921506.970:473): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:11:46 archlinux kernel: audit: type=1326 audit(1655921506.970:474): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:11:52 archlinux kernel: audit: type=1326 audit(1655921512.967:475): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
Jun 22 11:11:52 archlinux kernel: audit: type=1326 audit(1655921512.967:476): auid=1000 uid=1000 gid=1000 ses=2 subj==snap.spotify.spotify (enforce) pid=29692 comm="spotify" exe="/snap/spotify/60/usr/share/spotify/spotify" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7f83ca168c7f code=0x50000
