What I like about the service (not the service with a script, the service that start docker directly.), it acts like an old real service application. You can use the same tools, you would use to control a webserver or something like that. You even get the logs in you journal. You can have service dependencies. No need to run any docker commands. Also the image can be updated automatically. You can remove the container on stop, but it is not a requirement, it is if you update the image automatically.
Since it is with a service more like a normal application you install, you don’t need to know anything about docker, you can even use podman.
In your container, but with the contend you mount from your System into the container. The path that is used on your system depends on your command.
For example
-v ${PWD}/searx:/etc/searx
Depends on the folder from which you started the commands. You should know that pwd does. If not, you might want run echo ${PWD} from different folders to see what it does.
Well thank you for all this : this thread is a University degree to me !
@linux-aarhus : I installed all this system wide, was I wrong, should I reinstall on my user ? (I’m the only user, here, but I could, later on, self-host and share my searX with my Manjaro, my Debian, My CalyxOS & my son’s MacOS & iOS)
Both approaches (should at least ) start the docker container on boot.
It is more a philosophical and administrative question: Who should be responsible for long-running processes? Is it systemd that does this for all other daemons/service on your system, or does docker itself handle the starting policies of itself.
It’s up to you.
I don’t mind - despite creating it for my own usage - anyone is welcome use it - hence the domain - I have been running it on a local domain out of raspberry pi and decided to move it to a public.
Let me know when/if it gets throttled - after all - searx is - sort of - leeching on existing search engines.
Hi ! I wanted to update my install, everything seems fine, I can use my updated SearX on localhost:8888 but I can’t use it from Firefox’s search bar anymore : it leads me to https://localhost/search which gives me a connection error…
➜ ~ docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
cc81c8f86f5c searx/searx "/sbin/tini -- /usr/…" 2 hours ago Up 2 hours 0.0.0.0:8888->8080/tcp, :::8888->8080/tcp 0823_searx
➜ ~ curl -I http://localhost:8888
HTTP/1.1 200 OK
Content-Type: text/html; charset=utf-8
Content-Length: 10458
Server-Timing: total;dur=3.871
X-Content-Type-Options: nosniff
X-XSS-Protection: 1; mode=block
X-Download-Options: noopen
X-Robots-Tag: noindex, nofollow
Referrer-Policy: no-referrer
Connection: close
To create the new instance I did docker run --restart=always -d -v ${PWD}/searx/settings.yml:/etc/searx/settings.yml -v ${PWD}/searx:/etc/searx -p 8888:8080 -e BASE_URL=http://localhost:8888/ --name 0823_searx searx/searx
