Hello, thanks for the answer!
Here is the output of the command
Kernel: 6.12.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=c55ec5cd-2f00-4b16-be1b-5d32795931e6 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.13.0
Type: Laptop System: LENOVO product: 21HF000SFR v: ThinkPad P14s Gen 4
Mobo: LENOVO model: 21HF000SFR v: SDK0T76530 WIN
serial: <superuser required> part-nu: LENOVO_MT_21HF_BU_Think_FM_ThinkPad
P14s Gen 4 uuid: <superuser required> UEFI: LENOVO v: N3QET40W (1.40 )
date: 11/22/2023
ID-1: BAT0 charge: 47.1 Wh (96.7%) condition: 48.7/52.5 Wh (92.8%)
power: 20.8 W volts: 16.9 min: 15.5 model: SMP 5B11M90026 type: Li-poly
serial: <filter> status: discharging cycles: 209
System RAM: total: 32 GiB available: 31.01 GiB used: 6.83 GiB (22.0%)
Array-1: capacity: 32 GiB slots: 8 modules: 8 EC: None
max-module-size: 4 GiB note: est.
Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
size: 4 GiB speed: spec: 6400 MT/s actual: 4800 MT/s volts: curr: 0.5
width (bits): data: 16 total: 16 manufacturer: Samsung
part-no: K3KL9L90CM-MGCT serial: N/A
Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
Info: model: 13th Gen Intel Core i7-1360P bits: 64 type: MST AMCP
arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xBA (186) stepping: 2 microcode: 0x4124
Topology: cpus: 1x dies: 1 clusters: 6 cores: 12 threads: 16 mt: 4 tpc: 2
st: 8 smt: enabled cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32
KiB, 8x64 KiB L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 2456 min/max: 400/5000:3700 scaling:
driver: intel_pstate governor: powersave cores: 1: 2456 2: 2456 3: 2456
4: 2456 5: 2456 6: 2456 7: 2456 8: 2456 9: 2456 10: 2456 11: 2456 12: 2456
13: 2456 14: 2456 15: 2456 16: 2456 bogomips: 83584
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
xtopology xtpr
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: Lenovo driver: i915
v: kernel alternate: xe arch: Xe process: Intel 7 (10nm) built: 2022+ ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:a7a0 class-ID: 0300
Device-2: NVIDIA GA107GLM [RTX A500 Laptop GPU] vendor: Lenovo
driver: nvidia v: 570.144 alternate: nouveau,nvidia_drm
non-free: 550-570.xx+ status: current (as of 2025-04; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 03:00.0 chip-ID: 10de:25bb class-ID: 0302
Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:4 chip-ID: 5986:118c
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 7040x1440 s-dpi: 96 s-size: 1859x380mm (73.19x14.96")
s-diag: 1897mm (74.7")
Monitor-1: eDP-1 model: AU Optronics 0xd291 built: 2020 res:
mode: 1920x1200 hz: 60 scale: 100% (1) dpi: 162 gamma: 1.2 chroma: red:
x: 0.655 y: 0.333 green: x: 0.290 y: 0.616 blue: x: 0.137 y: 0.055 white:
x: 0.322 y: 0.349 size: 301x188mm (11.85x7.4") diag: 355mm (14")
ratio: 16:10 modes: 1920x1200
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau drv: nvidia
platforms: device: 0 drv: nvidia device: 1 drv: nouveau device: 2 drv: iris
device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11:
drv: iris inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.0.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (RPL-P)
device-ID: 8086:a7a0 memory: 15.14 GiB unified: yes
API: Vulkan v: 1.4.309 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
RTX A500 Laptop GPU driver: nvidia v: 570.144 device-ID: 10de:25bb
surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel Iris Xe
Graphics (RPL-P) driver: mesa intel v: 25.0.4-arch1.1 device-ID: 8086:a7a0
surfaces: xcb,xlib
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Lenovo
driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51ca class-ID: 0403
API: ALSA v: k6.12.25-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0dc6 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
IF-ID-1: br-15a7a4e67dd7 state: down mac: <filter>
IF-ID-2: br-282b6a47cefd state: down mac: <filter>
IF-ID-3: br-529c80eca775 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-4: br-818c4082904a state: down mac: <filter>
IF-ID-5: br-94e42c528def state: down mac: <filter>
IF-ID-6: br-95b7995929de state: down mac: <filter>
IF-ID-7: br-ad0f8a7737e5 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-8: br-b090097007de state: down mac: <filter>
IF-ID-9: br-dd9a4d94d052 state: down mac: <filter>
IF-ID-10: br-e697f7936f6c state: down mac: <filter>
IF-ID-11: br-e918697cb93b state: down mac: <filter>
IF-ID-12: br-f2cb02b08c5f state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-13: docker0 state: down mac: <filter>
IF-ID-14: veth5b9a2ae state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-15: vethb5fe098 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-16: vethba770e1 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-17: vethc98a0d1 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-18: vethf8a6df2 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:6 chip-ID: 8087:0033
class-ID: e001
Local Storage: total: 953.87 GiB used: 204.78 GiB (21.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 5106APLA temp: 24.9 C
scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%)
used: 204.78 GiB (21.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: c55ec5cd-2f00-4b16-be1b-5d32795931e6
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 3139-FC4E
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:2 info: Logitech USB Receiver type: mouse,keyboard,HID
lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c547 class-ID: 0300
Device-2: 3-3:19 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 27c6:6594 class-ID: ef00 serial: <filter>
Device-3: 3-4:4 info: Bison Integrated Camera type: video driver: uvcvideo
interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 5986:118c class-ID: fe01 serial: <filter>
Device-4: 3-8:5 info: Generic EMV Smartcard Reader type: smart card
mode: 1.1 power: 50mA chip-ID: 2ce3:9563 class-ID: 0b00
Device-5: 3-10:6 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0033 class-ID: e001
System Temperatures: cpu: 43.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 1894
Packages: pm: pacman pkgs: 1637 libs: 488 tools: pamac pm: flatpak pkgs: 0
1: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
2: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
3: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://linorg.usp.br/manjaro/stable/$repo/$arch
5: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
6: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
8: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
9: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
10: http://mirror.fcix.net/manjaro/stable/$repo/$arch
11: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
12: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
13: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
14: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
15: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
16: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
17: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
18: https://mirror.dc.uz/manjaro/stable/$repo/$arch
19: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
20: https://muug.ca/mirror/manjaro/stable/$repo/$arch
21: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
22: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
23: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
24: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
25: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
26: https://manjaro.ynh.ovh/stable/$repo/$arch
27: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
28: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
29: https://mirror.koddos.net/manjaro/stable/$repo/$arch
30: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
31: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
32: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
33: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
34: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
35: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
36: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
37: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
38: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
39: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
40: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
41: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
42: https://mirror.init7.net/manjaro/stable/$repo/$arch
43: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
44: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
45: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
46: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
47: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
48: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
49: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
50: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
51: https://mirrors2.manjaro.org/stable/$repo/$arch
52: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
53: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
54: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
55: https://mirror.easyname.at/manjaro/stable/$repo/$arch
56: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
57: https://mirror.23m.com/manjaro/stable/$repo/$arch
58: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
59: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
60: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
61: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
62: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
63: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
64: https://manjaro.kurdy.org/stable/$repo/$arch
65: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
66: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
67: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
68: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
69: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
70: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
71: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
72: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
73: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
74: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
75: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
76: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
77: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
78: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
79: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
80: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
81: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
82: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
83: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
84: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
85: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
86: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
87: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
88: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
89: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
90: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
91: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
92: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
93: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
94: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
95: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
96: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
97: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
98: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
99: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
100: http://manjaro.grena.ge/stable/$repo/$arch
101: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
102: https://mirrors.manjaro.org/repo/stable/$repo/$arch
103: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 518
1: cpu: 10.4% command: chrome pid: 44984 mem: 291.3 MiB (0.9%)
2: cpu: 5.2% command: chrome pid: 44759 mem: 267.7 MiB (0.8%)
3: cpu: 4.8% command: chrome pid: 44581 mem: 521.7 MiB (1.6%)
4: cpu: 3.5% command: chrome pid: 44628 mem: 259.3 MiB (0.8%)
5: cpu: 1.7% command: chrome pid: 44873 mem: 228.4 MiB (0.7%)
Memory top: 5 of 518
1: mem: 601.3 MiB (1.8%) command: plasmashell pid: 4757 cpu: 0.0%
2: mem: 521.7 MiB (1.6%) command: chrome pid: 44581 cpu: 4.8%
3: mem: 458.2 MiB (1.4%) command: code pid: 16065 cpu: 0.7%
4: mem: 352.3 MiB (1.1%) command: slack pid: 19124 cpu: 0.1%
5: mem: 334.2 MiB (1.0%) command: systemsettings pid: 15723 cpu: 0.0%
Processes: 518 Power: uptime: 21h 56m states: freeze,mem,disk
suspend: s2idle wakeups: 5 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.37 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.38
