Permission denied on changing the LCD brightness
I install a script called brillo that changes the brightness but this error always show:
Error: open '/sys/class/backlight/intel_backlight/brightness': Permission denied
Error: execution failed
the command sudo brillo -q -A 10 works but in this video he can do it without the sudo.
I tried the chmod a+x /sys/class/backlight/intel_backlight/brightness
the command brillo -q -A 5 works but when I restart, the problem goes back again.
How can I make it permanent so that I can change the brightness without sudo?
According to readme if you are in video group you should be able execute this command. Check if you are in video:
groups
If you aren’t add yourself:
sudo usermod -aG video <username>
and relogin or reboot.
I got the solution at this link.
