Permanently disabling touchpad
Hello Manjarins
I want to permanently disable my touchpad - managed to disable it in xinput, but on next startup it’s active again.
Thank you and let me know if you require more info to help me
Charl
Hi @charl, and welcome!
Have you checked if you can disable it in BIOS/UEFI?
ELSE:
I don’t know if this is the right way, but one way would be to create a systemd unit that runs on startup that runs the command to disable the touchpad…
If you use KDE, there is an option in Settings–> Input Devices–> Touchpad to disable touchpad.
