Hi!
A few days ago I decided to change my keyboard layout. I’m running the i3wm minimal edition, which comes without Manjaro Settings Manager, but I remember that that had a good GUI for changing layouts and installed it. Obviously it works, but there doesn’t seem to be a way to make the change permanent - as soon as I reboot the machine, I’m back with the layout I chose at install time.
Running
sudo setxkbmap -layout us
as the exact same effect.
How do I make the change permanent?
Thanks in advance!
